Old 10-16-2013, 07:48 AM   #316
manny021803's Avatar
Thumbs up
just make sure to bring back the car to the supermarket
Originally Posted by MaNoN View Post
We use this machine, adding soda + suggar
+ YouTube Video
NEW YORKERS RACERS TEAM(NYRT)
bruckner hobbies/sweep tire/desoto racing/bu-ku clutch
NYRT#4
NYRCC #124
manny021803 is offline   Reply With Quote
Old 10-16-2013, 07:51 AM   #317
mac853's Avatar
Talking
Did they remove the coin of lock?
mac853 is offline   Reply With Quote
Old 10-16-2013, 07:57 AM   #318
erchn's Avatar
Originally Posted by Skiddins View Post
With the saver mounted at an angle, as you 'turn' left, the end of the link rises as the saver rotates, as you turn right, the end of the link drops relative to the rotation of the saver.
This means the links movement in each direction is not identical.
We're obviously being a bit pedantic here as the required angle (when using the stock xray saver in the top hole) never gets past the point of mattering. I'm just going to agree to disagree.
Serpent ; Desoto Racing ; Team Powers USA ; Reflex Racing ; Bezerk RC
Old 10-16-2013, 08:06 AM   #319
Skiddins's Avatar
Fair enough, you have full lock, and so do I with a few percent difference in EPA's
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 10-16-2013, 09:25 AM   #320
ByteStream's Avatar
Now shipping in the US
RCAmerica | Xray | Hudy | KO Propo | Hobbywing HWNA | R1Wurks | BSR Tires
5280 Raceway - www.5280raceway.com
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
ByteStream is offline   Reply With Quote
Old 10-16-2013, 09:27 AM   #321
Jerz616's Avatar
Trader Rating: 49 (100%+)
Mine just showed up at my LHS in Dallas today. My new orca ESC, motor and batteries will be here Friday. Looks like it will be a good weekend to put a new car together.
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 10-16-2013, 09:48 AM   #322
jlfx car audio's Avatar
Trader Rating: 35 (100%+)
Yea buddy, my sons will be on my door step tomorrow . we excited about the build . he going to be running with the big boys from here out . his 2012 gt car has served him well but its time for some 17.5 racing
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 10-16-2013, 12:19 PM   #323
millbank's Avatar
I have a savox on my t4 and wanted more lock....
No problem with the servo but I had the issue of the spacer hitting the steering arms. Got over this by using a up turned top hat/steering bush with a 1 mm shim on top. Can now get my steering knuckles to touch the c hubs if I require.
Still waiting for my 14 :-(
Will have to use my t4 at cwic this Sunday. see when the 14 arrives as to when I when and if it will be ready for round 2
Xray T2009 / hobbywing v3 120amp /LRP x12 6.5 / wet car
Xray t4'14 / Hobbywing v3 120amp / 13.5/ boost car
Xray t4'15 / Orca Vxx / Orca Rx3 17.5 / blinky car
TEAM DRIVER FOR MMR FLUX
millbank is offline   Reply With Quote
Old 10-16-2013, 01:50 PM   #324
Skiddins's Avatar
The point of the spacer hitting the steering arms is to limit lock to ensure good corner speed and less scrub, ideally you need to make changes to your setup to get the steering by other means.
James, I'll be at CIWC in 13.5 on Sunday as well, but running the new car
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 10-16-2013, 10:47 PM   #325
Jerz616's Avatar
Started on the new car tonight and in the usual xray fashion it's going together very nicely. The new arm mounts look like they will be a good change once you get used to it. I love building new cars. They look so nice and clean.
Ryan Gracey
XRAY XB8'14
Old 10-17-2013, 01:28 AM   #326
I played around with the rear arm slop a bit more. Indeed, pinching the mounts while tightening will get the slop out. But being paranoid I thought a good tap might knock them back to their more natural position. So I put an extra .2mm shim on each arm, and just carefully tightened the mounts to let them settle in, and there's no slop, and the arms are free. There may be just a teeny bit more friction than normal, but they still fall quite freely. I'll see how it does on the track. .1mm would probably be better, but I was out of those.
The front arms have just the tiniest bit of play in them, just like .05mm. They should be just right.
-Mike
Old 10-17-2013, 11:04 AM   #327
My 14 is now in my hands
Justin & Matt Lyons
a800s sanwa m12s
Old 10-17-2013, 11:12 AM   #328
Skiddins's Avatar
Stop typing and get building
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 10-17-2013, 12:26 PM   #329
Well its funny . I am at work but I did manage to sand and seal the chassis wile working and find time to brag about getting it . lol
Justin & Matt Lyons
a800s sanwa m12s
Old 10-17-2013, 12:52 PM   #330
chasingthepack's Avatar
if you think about it,the servo is irrelevant,the saver needs to be at a 90 to the link rod to achieve equal motion each way
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
