Old 10-02-2013, 07:07 AM   #16
yokemad's Avatar
yokemad is offline   Reply With Quote
Old 10-02-2013, 07:18 AM   #17
mkiiina's Avatar
Trader Rating: 69 (100%+)
Thanks for the visual! It looks like the arms could be ground down a little (or spacers removed depending on your setup) on the front to work with the older cars. Looks like you could even retrofit the stiffeners over....
mkiiina is offline   Reply With Quote
Old 10-02-2013, 07:19 AM   #18
mkiiina's Avatar
Originally Posted by EAMotorsports View Post
2mm longer front to rear....not in hinge pin to hinge pin length. Look at the picture. You can see the part where the inner hinge is is longer. The suspension mounts were moved farther apart and instead of having to use 4mm of shims on the hinge pin they made the arm thicker in this area.
EA
Yup I see that now thanks to yoke's post.
Old 10-02-2013, 07:21 AM   #19
Skiddins's Avatar
Originally Posted by yokemad View Post
I see what you mean (didn't notice that when I originally looked at the picture )
Could still use old arms though, just add 2mm of shims.
Pity the pivot pins aren't the same.
I bought some as spares when I first moved over to Xray (just before the '008 came out) and I've used.... one!
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 10-02-2013, 07:30 AM   #20
syndr0me's Avatar
Trader Rating: 32 (100%+)
Interesting, so that top deck that showed up on RCMARKET must be some option part? Presumably there's some corresponding mount that attaches somewhere in front of the motor?
Edit: "Top deck allows installation of optional aluminum stand which changes the car’s flex characteristics."
Doesn't look like the stock top deck allows for that unless I'm missing it in the pics.
syndr0me is offline   Reply With Quote
Old 10-02-2013, 07:32 AM   #21
yokemad's Avatar
True but you know those new arms has some Screw holes for CF Arm Stiffener parts
But on the other hand it might me a marketing gimmick which we will never gonna use
Old 10-02-2013, 07:34 AM   #22
Team EAM
EAMotorsports's Avatar
Trader Rating: 78 (100%+)
Send a message via AIM to EAMotorsports
Yes you can use the old arms. Just add a 2mm shim. That's the only difference other than the holes. No geometry differences.
That's the top deck that comes with the car with that weird open hole in the back for the standoff or belt tensioner.
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | ProSpec America | Killer Concepts | AVID.
EAMotorsports is offline   Reply With Quote
Old 10-02-2013, 07:34 AM   #23
yokemad's Avatar
if you remove some screws from top deck you can use a post like the way on Yokomo Bd7 ...
Old 10-02-2013, 07:36 AM   #24
Team EAM
Nope. Not a marketing gimmick. I've already used them and other factory drives used them as far back as snowbirds this year and they do exactly what they say. You'd be really surprised at how much it does on a high grip track.
Contact Us
Old 10-02-2013, 07:37 AM   #25
syndr0me's Avatar
Edit...
Old 10-02-2013, 07:38 AM   #26
Skiddins's Avatar
Edit: "Top deck allows installation of optional aluminum stand which changes the carís flex characteristics."
Probably the pics are slightly out of date;
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 10-02-2013, 07:41 AM   #27
yokemad's Avatar
thats why I said "maybe"
Many thanx for the info ...
This new kit really deserve a new name =T5 ! Fantastic looking car I must say again...
Old 10-02-2013, 07:50 AM   #28
syndr0me's Avatar
I can't tell from the spec sheet what's new to the 14 and what was new to the T4. It talks about bulkheads being closer together, the motor being moved in, the ability to adjust belt tension and diff height independently, etc.
Old 10-02-2013, 07:51 AM   #29
Skiddins's Avatar
It seems that there is the slightly opaque '2014' moniker in the corner when it's something new to the '14 model.
That caught me out at first. It seems it's basically the first half of those pages is the latest car.
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 10-02-2013, 07:55 AM   #30
Ron-Z's Avatar
I found a very nice upgrades! Can be used in the new xray t4 on!
http://www.zzracing.net/zzracing-t4-...7f3b09d8a0edab
http://www.zzracing.net/http://www.z...rnb-p-401.html
Ron-Z is offline   Reply With Quote
