Old 01-11-2015, 11:31 PM   #2266
metalnut's Avatar
R/C Tech Elite Subscriber
Trader Rating: 36 (100%+)
Originally Posted by touringdriver View Post
Looking for a good asphalt low traction T4 14 set up if anyone has anything. i fought this car all last summer season and really like to stay with xray but it really tested me and so far i still have it. lol
What was it doing wrong, or what was it not doing? It'd also help if you posted your setup.
- Ricky Bobby
Old 01-12-2015, 02:20 AM   #2267
daleburr's Avatar
The T4'14 generates huge amount of grip, so it should just be a setup issue. Here is my Bedworth setup which was from low-grip conditions at the start of 2014:
http://forum.teamxray.com/xform/inde...&setup=t4_2014
You can go down to 2.5 or 2.6 springs and/or lower the ride-height if the track is smooth, which will improve the grip even more.
Team Xray
Old 01-12-2015, 02:22 AM   #2268
spencehotbodies's Avatar
Default Wet car set up
Hello dale
Would that set up work well for a wet car?
spencehotbodies is offline   Reply With Quote
Old 01-12-2015, 03:01 AM   #2269
Skiddins's Avatar
PM sent
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 01-12-2015, 07:51 AM   #2270
touringdriver's Avatar
Trader Rating: 15 (100%+)
The car felt lazy/sloppy in tight quick left right corners. it just felt slow to respond to fast direction change.
Proudly Sponsored by: Mr. Crash Racing, RickyRacer lidz & Ebay..
Rock Chalk Jayhawks
2014 Subway Cup & Dee and Mees On-road Race Schedule:
http://www.rctech.net/forum/kansas-m...l#post11891510
touringdriver is offline   Reply With Quote
Old 01-12-2015, 07:42 PM   #2271
metalnut's Avatar
A lot of things can impact a car's reaction. Droop, shock oil weight, camber link length, wheelbase, tires, chassis stiffness, etc. The setup that was posted above looks pretty good, where was your different?
- Ricky Bobby
Old 01-13-2015, 02:36 AM   #2272
daleburr's Avatar
Originally Posted by spencehotbodies View Post
Hello dale
It won't be far off, my changes for the wet are:
Drop the springs to 2.5
Split front suspension blocks for more flex
Front camber-link in the middle hole if you need more steering
Team Xray
Old 01-13-2015, 10:31 AM   #2273
springs 3.0-2.8, shock oil 45-40, gear diffs 20,000-2,000, camber links med. length front and rear, all 4 shocks next to inside hole all around.
Rock Chalk Jayhawks
Old 01-13-2015, 02:23 PM   #2274
Skiddins's Avatar
Those springs seem too hard, and a spool would certainly make the car more stable.
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 01-14-2015, 03:12 AM   #2275
daleburr's Avatar
You're miles away from a sensible setup. Use the setup I posted above, then get back to us with how it went.
Team Xray
Old 01-14-2015, 05:15 AM   #2276
and the front diff? go to a million.
freebird is offline   Reply With Quote
Old 01-14-2015, 06:15 AM   #2277
Are you using the longer springs for the T3 (and older) cars?
Stevenkoiter is offline   Reply With Quote
Old 01-14-2015, 08:33 PM   #2278
metalnut's Avatar
I have to agree here. My biggest mistake on my first asphalt season was running a 1 million diff up front. Car pushed like crazy all summer and I never thought of that as the issue. If I race this summer I'll be trying 2.5 million (what I'm running on carpet now), but a spool is certainly a quick test. With the hard springs and the shocks second hole out, it does seem like the setup is fighting itself a bit. Go with the suggested setup and see how it does, or go back to kit asphalt and start from there again.
- Ricky Bobby
Old 01-14-2015, 09:32 PM   #2279
I'm gonna give your setup a try this spring, however from your guy's comments, a spool would not be good to run on asphalt because it'll cause the car to push so would 1 million be good for the front diff? i'll run 1,000 in the rear.
Rock Chalk Jayhawks
Old 01-14-2015, 09:45 PM   #2280
no i'm using Team CSO racing products springs. one of the part numbers is XT-4028.
Rock Chalk Jayhawks
