Old 12-13-2014, 10:13 PM   #2251
Trader Rating: 100 (100%+)
Send a message via MSN to Texas Postman Send a message via Yahoo to Texas Postman
Has anyone got a good set-up for VTA...new carpet...@80 ft straights?
Texas Postman is offline   Reply With Quote
Old 12-16-2014, 05:53 PM   #2252
3DFLYER's Avatar
Default rear toe
Hey guys just wondering if anyone sees it being an issue to run a 1 degree eccentric bushes in the RR position and a 0 in the RF to reduce to rear to 2 toe degrees out.. was thinking I could do it with .5s in both the RR and RF *in the different orientations obviously* to reduce the load on the pin in the bush or am I over looking it?
Still very new to the kit
3DFLYER is offline   Reply With Quote
Old 12-16-2014, 07:22 PM   #2253
Just make sure you don't cause the bone blades to bottom out in the outdrives. Also, consider shortening the rear wheelbase to compensate for moving the wheels back with the toe change.
Whether you go 1 in on RR, 1 out on RF, or 0.5 on both, pretty much comes down to how wide you want the rear end to be. I can't help you with that.
-Mike
Old 12-16-2014, 07:29 PM   #2254
erchn's Avatar
As Grip said, it's mostly about rear width, I'd recommend .5 in and .5 out. The t4 is already narrower in the rear compared to the front than most cars. Too narrow and it'll make the car more edgy and more likely to traction roll.
Old 12-29-2014, 03:45 PM   #2255
idbdoug's Avatar
Trader Rating: 33 (100%+)
I'm thinking about converting my T4'14 to ARS system. Below are the items that i'm pretty sure are all i need, feel free to correct or add information!!!
1. Aftermarket chassis designed for T4'14 but with added ARS holes in chassis such as Team Tamale's
2. 1 pair of stock rear ARS arms #303170
3. 1 pair of zero degree front c hubs #302369 and #302370
4. 1 pair of ARS aluminum brace post #302201
5. 1 pair of 5mm ball studs #362649
That's it as best as i can figure. I have allot of spare parts for T4'14 to cover such things as turnbuckles, steering blocks,etc. I would like to practice mod with it and after watching the 2015 with ARS on asphalt i feel you definitely need ARS. I'm going to get new chassis for 2014 car anyways and i figured this was allot cheaper for a car i'm going to break allot,LOL
idbdoug
www.serpentamerica.com
www.r1wurks.com
www.falconsekido.com
idbdoug is offline   Reply With Quote
Old 12-29-2014, 03:56 PM   #2256
idbdoug
You'll also need (if you don't already have in your parts box)
- Ball studs for outer toe links (362650)
- rod ends #302663 (8 per package) for inner/outer toe link
- caster block bushings (302291)
- steering knuckles
- 26mm turnbuckles
- assorted screws / set screws / shims
An alternative to the ARS post seems to be to use a long screw, a stack of shims, and a ball like the outer front tie rod, that I can't seem to find on the exploded view.
-Mike
Old 12-29-2014, 04:06 PM   #2257
idbdoug's Avatar
- steering knuckles
- 26mm turnbuckles
-Mike
Yep i have all the above parts except for ball studs(362650) thanks a ton for post
idbdoug
www.r1wurks.com
Old 01-06-2015, 12:46 PM   #2258
Meradin's Avatar
Trader Rating: 19 (100%+)
I need more steering! My car pushes like crazy when on power. I am using the Kit stock setup for reference.
Better than Randy, Adam said so!
Second thought...I don't trust Adams, they make up everything!
"Leave it to Steever", custom paint masks, decals, and paint.
Meradin is offline   Reply With Quote
Old 01-06-2015, 12:47 PM   #2259
Trader Rating: 24 (100%+)
put some foam tires on it... it will be money
Justin Cornett
RC America / XRAY / HUDY / KoPropo / Team EA Motorsports / AVID RC / RSD / ReflexRacing.net
gocoogs is offline   Reply With Quote
Old 01-06-2015, 12:52 PM   #2260
mschumi101's Avatar
Trader Rating: 21 (100%+)
Send a message via Skype™ to mschumi101
Less front droop, stiffer rear suspension (I'd try springs first).
Less droop will keep the front from rising and keep more rubber in contact with the ground. Stiffer rear helps resist weight transfer to the rear tires. Currently you have too much weight transferring to the rear, causing the front to lift up and become light, meaning less front grip.
Associated B5M Reedy 7.5 | Xray T4 ORCA 17.5
Orange Powered!
Previous: B44.2 | TC5R | TC5 | B4.2 | B44 | Slash | E4RS | TA05R | TT01
-Ted
mschumi101 is offline   Reply With Quote
Old 01-06-2015, 01:00 PM   #2261
metalnut's Avatar
R/C Tech Elite Subscriber
Trader Rating: 36 (100%+)
You can also try ackerman shims and/or add front arm sweep, so starting with 0.5 blocks on the front, to make the hinge pins point out. That should add mid/out steering. You could also try anti-squat in the back, which is basically limiting weight transfer to the rear on power.
- Ricky Bobby
Old 01-06-2015, 03:30 PM   #2262
Skiddins's Avatar
As the others have mentioned, also anti-squat
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 01-06-2015, 04:24 PM   #2263
If you're using the kit rear diff oil.... dump that and try 3000. That will probably solve everything. You might lose a bit of mid-corner rotation, but with good on-power steering, the solution to that is... more throttle!
-Mike
Old 01-07-2015, 02:46 AM   #2264
daleburr's Avatar
-Mike
+1, thats probably the place to start if the track you're racing at has decent traction.
Team Xray
Old 01-11-2015, 04:59 PM   #2265
touringdriver's Avatar
Trader Rating: 15 (100%+)
Looking for a good asphalt low traction T4 14 set up if anyone has anything. i fought this car all last summer season and really like to stay with xray but it really tested me and so far i still have it. lol
Proudly Sponsored by: Mr. Crash Racing, RickyRacer lidz & Ebay..
Rock Chalk Jayhawks
2014 Subway Cup & Dee and Mees On-road Race Schedule:
http://www.rctech.net/forum/kansas-m...l#post11891510
touringdriver is offline   Reply With Quote
