Old 11-08-2014, 02:06 AM   #2236
There's a lot going on with driveshafts that most people probably don't understand. I'd love to hear Cristian chime in, as I think he knows more than most.
-Mike
Old 11-08-2014, 09:03 AM   #2237
CristianTabush's Avatar
Trader Rating: 11 (100%+)
The plunge of the driveshaft affects the suspension and drive line bind under power. A longer shaft plunges deeper, which makes the car more resistant to rolling under power which should translate into a "stiffer" front end. To me, it is sort of similar to arm sweep or moving the diff to a lower position. It basically keeps the car flatter through the corner.
Now, being honest, I can't tell much of a difference. I prefer our 51mm ones becUse of the narrower axle. Moving the coupling further out makes the car smoother as the angle it needs to turn is less extreme. This leads to longer durability and less re-builds, at the expense of having to replace the narrower bearings a little more often.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 11-15-2014, 09:42 AM   #2238
dMITIj's Avatar
im new to this T4 so could you drop some parts numbers for this?
TLR 22-4.
ORION VORTEX R10.1 Pro ESC.
ORION VORTEX VST2 PRO 7.5T.
ORION CARBON PRO 4500 100C 7.4V SHORTY PACK x3.
Sanwa MT4S Radio/RX-481 receiver & Xpert RC PI-3402 Brushless Servo.
dMITIj is offline   Reply With Quote
Old 11-15-2014, 09:14 PM   #2239
metalnut's Avatar
R/C Tech Elite Subscriber
Trader Rating: 36 (100%+)
http://www.reflexracing.net/RSD-XRAY...cs_p_1673.html
- Ricky Bobby
Old 11-21-2014, 07:48 PM   #2240
Can anyone comment on Paul's carpet setups for the t4'14, compared to the kit setup?
There's a trend from 2013 IIC -> Snowbirds -> Canadian Nats -> ROAR Nats towards a softer front end with less front end damping. I'm most interested in the ROAR Nats setup, because we use the same tires, and Kody came home and kicked our asses with his setup from that event.
But looking at it, it just doesn't make sense to me. It seems like it'd be really lazy and drag the chassis on the carpet everywhere.
-Mike
Old 11-21-2014, 08:56 PM   #2241
Essnowyt's Avatar
Send a message via AIM to Essnowyt
-Mike
What class are you running? Can you post links to the setups your referencing?
Snowy.
Team XRay, RCAmerica, Motiv, Gravity RC, Schacht Design Works.
Drive it, Dont slide it!
Essnowyt is offline   Reply With Quote
Old 11-21-2014, 09:28 PM   #2242
Snowy.
Mod TC on Carpet. Although I was considering trying it on my 2nd car (Stock TC) just for practice to see what it felt like.
IIC 2013:
http://forum.teamxray.com/xform/inde...&setup=t4_2014
Snowbirds:
ROAR Nats:
Canadian Nats:
Maybe they're not worth trying at all. I don't have a Speed6 (only have LTC-R at the moment), and I only have 4* hubs. Everything else I have, though.
EDIT: My front diff is also 2.5M instead of 1M. :/
-Mike
Old 11-22-2014, 05:40 AM   #2243
Essnowyt's Avatar
The thicker rear fluid slows the reaction of the rear end. It can help decrease a late traction roll. Yes Paul has been going to what some call a super soft setup. He has no worries about dragging the chassis.
Snowy.
Old 11-22-2014, 06:26 PM   #2244
Trader Rating: 13 (100%+)
If anyone had a set of raceberry long shock towers for sale I would be interested.
Thanks.
https://www.gofundme.com/ncontrol
Joe Maxey is offline   Reply With Quote
Old 12-09-2014, 11:26 AM   #2245
tudor_47's Avatar
OK, guys
I bought myself a second hand T4-14 and I am trying to remove the centre spur gear, by loosening the orange gear holders, one needs to be removed from under the car,
this is were I get into trouble as it will not loosen, the screws are so tight that I broke one..(Now needs to come out by drilling it).. !? I am using 2mm hex Hudy tool so it shold be a good tool..
any tricks to get them loose?
Xray T4-14 (BLS551,4.5T/8.5T, Spectrum), Xray X10-15 (Lajf Racing widened 235 4T, IRS)
Lajf Racing P28(LiPo, spectrum), Lajf Racing P28GT (LiPo, spectrum )
Xray X1(21,5T, spectrum) Tamiya M05(tamiya ESC, silver can, spectrum)
Go 235mm with X10 widening parts from www.lajf.se Get your P28 at www.lajf.se/pshop
tudor_47 is offline   Reply With Quote
Old 12-09-2014, 11:28 AM   #2246
erchn's Avatar
Originally Posted by tudor_47 View Post
OK, guys
Heat the screw up with the tip of a soldering iron. Generally the aluminum will expand more than the steel and it'll soften any loctite that may have been used.
Serpent ; Desoto Racing ; Team Powers USA ; Reflex Racing ; Bezerk RC
Old 12-13-2014, 12:45 AM   #2247
3DFLYER's Avatar
Hey Guys,
New to Racing again and Xray. broke a rear belt today, which is okay i ran it too tight orginally and had a big tangle with someone else and it broke was i was accelerating away.. anyway. what belts are people running the Stock OEM or the R1? ive heard of people running the ARC R10 belts in them as well
Cheers guys, sorry for the noooob question
3DFLYER is offline   Reply With Quote
Old 12-13-2014, 01:20 AM   #2248
B00t13g's Avatar
Originally Posted by 3DFLYER View Post
Hey Guys,
I run the white low friction belts in stock and mod.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 12-13-2014, 12:22 PM   #2249
daleburr's Avatar
Hey Guys,
BD7 belt on the rear, cheap and very strong
Team Xray
Old 12-13-2014, 06:08 PM   #2250
3DFLYER's Avatar
Beauty thanks guys. My local track is a dealer for yokomo. I'll grab one to try. I do like the look of the white low friction belts. Might try and get a set of them over the next couple races.
