Old 09-30-2014, 09:30 PM   #2191
metalnut's Avatar
R/C Tech Elite Subscriber
Trader Rating: 36 (100%+)
Originally Posted by Kane-o View Post
This is great info as well. Thanks for directing me to the app. I just downloaded it.
Although this tends to start heated debates, you can also try a gear diff up front. Gravity RC 2.5 million weight oil feels almost like a spool, but gives you slightly more steering. Something like Spec-R 1 million weight oil gives you a LOT more corner entry steering (what I run), but you do lose a bit corner exit since the car doesn't pull out as hard. Something to consider.
- Ricky Bobby
Old 10-01-2014, 05:24 AM   #2192
Bishop's Avatar
I like the million cst in my front diff right now, I can usually turn a faster lap with the front diff in than without, not all the fluids are equal, I know I use nothing but Mugen silicon oils, the shock oils bleed out super fast, diff oils stay very consistent, seems nit picking, but the oils are not all equal.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 10-01-2014, 06:57 AM   #2193
Trader Rating: 12 (100%+)
I do have a diff sitting here with 2.5 million oil in it. It is for the mod car when I get it together but I will have to throw it in and give it a try!
rcdepot.us
nxgraphics.ca
Kane-o is offline   Reply With Quote
Old 10-20-2014, 02:39 AM   #2194
Trader Rating: 17 (100%+)
I recently got the alloy top deck post and have lost the mounting instructions on what screws to take out , can someone confirm for me please
Team Awesomatix
R1 Wurks
RC Maker.com
Southern Tasmania Model Car Club
lethallee69 is offline   Reply With Quote
Old 10-20-2014, 03:44 AM   #2195
daleburr's Avatar
Remove the 4 screws that go through the top-deck into the layshaft mounts.
Team Xray
Old 10-20-2014, 03:52 AM   #2196
Old 10-29-2014, 03:39 AM   #2197
tudor_47's Avatar
Default Alu or carbon chassi
So a more general question.
I've been slowly grinding away my carbon chassi from my T4_14. And I have been looking into getting a replacement chassi.
There are carbon chassi and the aluminum chassi.
I run mainly asphalt so which one do I choose? (leave it at xray manufactured parts for now)
The alu chassi how big a risk is tweeking the chassi in a crash?
Xray T4-14 (BLS551,4.5T/8.5T, Spectrum), Xray X10-15 (Lajf Racing widened 235 4T, IRS)
Lajf Racing P28(LiPo, spectrum), Lajf Racing P28GT (LiPo, spectrum )
Xray X1(21,5T, spectrum) Tamiya M05(tamiya ESC, silver can, spectrum)
Go 235mm with X10 widening parts from www.lajf.se Get your P28 at www.lajf.se/pshop
tudor_47 is offline   Reply With Quote
Old 10-29-2014, 05:27 AM   #2198
Skiddins's Avatar
I think the alu chassis is better suited to high grip carpet.
I have run it on asphalt (not dead smooth) and it caused the car to be a bit inconsistent.
I would only run the carbon if only running on asphalt.
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 10-29-2014, 05:33 AM   #2199
Trader Rating: 23 (100%+)
Might be a stupid questions but i've heard of aluminium being better on high grip carpet because it flexes more but why is this better? I was under the assumption that usually on high grip it is better to run harder suspension (lower flex)?
Awesomatix A800X | Team SILVERBACK | LRP | R1WURKS | FUTABA
Zhangesh is offline   Reply With Quote
Old 10-29-2014, 06:37 AM   #2200
Mechintosh's Avatar
My experiences are that the Carbon Loads up on high bite and the unload is what causes the car to be very twitchy or inconsistent. With the Aluminum the flex is similar if not a little more but the load and unload of the chassis are smoother and the overall feeling of the car is smoother instilling more confidence to drive it harder and deeper into a corner. I have the Team Tamale Chassis and my lap times were .5 to .75 per lap quicker, no other adjustments on the car. All due to having the ability to drive the car harder in spots where I was unable to before.
I have not tried on asphalt, I use the carbon chassis when I go asphalt. I have a friend who ran at the Worlds with his 3.0 and he like to aluminum chassis better than the carbon. Next time out on Asphalt I will give it a go to see the difference.
Xray T4-14,T4-15, X1
Pro Mini Truggy Mid Motor Mafia Xfactory
Serpent SRX4, 811 TE-e
Kyosho RB6, MP9e TKi
Mechintosh is offline   Reply With Quote
Old 10-29-2014, 07:27 AM   #2201
Skiddins's Avatar
The Alu chassis flexes less, not more.
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 10-29-2014, 08:33 AM   #2202
erchn's Avatar
For the Xray chassis that's true. Not necessarily the TT chassis.
Serpent ; Desoto Racing ; Team Powers USA ; Reflex Racing ; Bezerk RC
erchn is online now   Reply With Quote
Old 10-29-2014, 10:41 AM   #2203
Skiddins's Avatar
Interesting, so why would anyone bother with an alu chassis that flexes more?
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 10-29-2014, 11:07 AM   #2204
erchn's Avatar
I've not run one. But I've been told, as stated above, the flex is more controllable, it unwinds more predictably. The TT chassis also lowers the CG on the car by taking down the battery and electronics about .5mm.
Old 10-29-2014, 02:42 PM   #2205
Trader Rating: 20 (100%+)
The TT chassis flexes more end to end but in a twisting motion flexes less than the carbon chassis.
www.teamgravityrc.com
Leisure Hours Raceway
Troy Carter is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
