Old 09-05-2014, 03:29 PM   #2161
chasingthepack's Avatar
looking at marek's car it looks like he has the 13 a arms fitted ,split blocks up front and the new ars
http://rcracingtv.net/2014/08/marek-...s-his-top-off/
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 09-05-2014, 03:31 PM   #2162
erchn's Avatar
Probably 2-hole arms.
Old 09-05-2014, 09:39 PM   #2163
Hi
Was testing yesterday on our local track (grc-Racing.dk) a Low grip asphalt track. Temp was around 20 degress c. Was testing Stock dampere against raceberry Towers with NT1 2014 shocks and yok springs. And the normal size ones from the NT1 gave at lot more grip on that Low grip track. Did the same earlier this week where there were a lot more drivers on the track and then the difference wasnt that Big , but still in favour of the NT1 ones. Anyone Else that have tried Them ??
Xray T4 2014 / Orca VXX / Orca 5t
Team Xray-shop.dk
johnsen-dk is offline   Reply With Quote
Old 09-14-2014, 03:36 PM   #2164
pcar951's Avatar
Trader Rating: 19 (100%+)
Interesting... What pistons, oil and springs were you testing with?
Jim Chapman
PM Hobbycraft | RCAmerica | Xray | Hudy | Reds Racing
pcar951 is offline   Reply With Quote
Old 09-14-2014, 04:58 PM   #2165
erchn's Avatar
Originally Posted by johnsen-dk View Post
Hi
I agree. Except for very high bite, at least on asphalt, I think the nt1 or t3 long shocks are faster around the track.
Serpent ; Desoto Racing ; Team Powers USA ; Reflex Racing ; Bezerk RC
Old 09-15-2014, 03:17 AM   #2166
Essnowyt's Avatar
Send a message via AIM to Essnowyt
What is different with the NT1 shocks? They look like they build the same as the T4 shocks.
Snowy.
Team XRay, RCAmerica, Motiv, Gravity RC, Schacht Design Works.
Drive it, Dont slide it!
Essnowyt is offline   Reply With Quote
Old 09-15-2014, 04:13 AM   #2167
Bishop's Avatar
It's splitting hairs, long vs sort shock debate has been around a while now, regardless what you choose, someone is going to likely beat you with the other, then you'll look for others reasons why you lost, it's all part of racing, you will always think someone else has something that works better than what you have.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 09-15-2014, 08:11 AM   #2168
erchn's Avatar
Snowy.
They are basically the same shock, just longer. ~2mm longer than t3 shocks, an internal spacer works well to take up the difference.
Old 09-15-2014, 07:35 PM   #2169
Diggity's Avatar
Trader Rating: 29 (100%+)
Default Suspension arm stiffener plates
We have just released our version of the suspension arm stiffener/tuning plates. They are 2mm and available as a set or individual front or rear.
Please check out our website for more info -
http://www.diggitydesigns.com/products_Xray_T4.html
www.rcamerica.com - www.teamxray.com - www.powerpushbatteries.com - www.fantomracing.com - www.kimbrough-products.com - www.diggitydesigns.com
Diggity is offline   Reply With Quote
Old 09-16-2014, 03:53 AM   #2170
robk's Avatar
Trader Rating: 22 (100%+)
Hi
A friend was at the Reedy race and was advised by a Tamiya team driver to use the standard shock when the track got greasy instead of the Raceberry towers and short shocks he was running. Sounds like this is a known thing for low grip.
A mutually re-enforcing cascade of failure
"Failior [sic] crowns enterprise." Robert Goddard
I-Lap Scoring Systems http://www.rclapcounter.com/
robk is offline   Reply With Quote
Old 09-16-2014, 06:32 AM   #2171
tudor_47's Avatar
So, I got a T4-14
If I want to run longer shocks, to try and get more grip in slippery conditions, can I get the shocks of a T3 and the shocktower from same car? ??
Xray T4-14 (BLS551,4.5T/8.5T, Spectrum), Xray X10-15 (Lajf Racing widened 235 4T, IRS)
Lajf Racing P28(LiPo, spectrum), Lajf Racing P28GT (LiPo, spectrum )
Xray X1(21,5T, spectrum) Tamiya M05(tamiya ESC, silver can, spectrum)
Go 235mm with X10 widening parts from www.lajf.se Get your P28 at www.lajf.se/pshop
tudor_47 is offline   Reply With Quote
Old 09-16-2014, 07:19 AM   #2172
Geberit's Avatar
Originally Posted by tudor_47 View Post
So, I got a T4-14
No the bulkheads are too far apart on T3. You need aftermarket shock Towers like from Raceberry or some other manufacturer. And NT1 2014 shocks or T3 ...
http://www.fast-webshop.com/tonispor...4-Long-Version
Geberit is offline   Reply With Quote
Old 09-16-2014, 07:30 AM   #2173
daleburr's Avatar
So, I got a T4-14
You'll need the T3 shocks and Raceberry T4 shock towers.
But I'd recommend saving your money. Unlike the Tamikos the Xray is designed around the short shocks, and Xray put a lot of work into them. They work as well as the long ones when the right oil and springs are used, and are lighter and smoother.
A few drivers tried the long shocks in the UK when the T4 first came out (most of our tracks are low/mid grip), but I haven't seen anyone use them in over a year.
In low grip go for 350cst oil with 4x1.1mm pistons and 2.7 springs and the car will be better than any Tamiko.
Team Xray
Old 09-16-2014, 07:30 AM   #2174
erchn's Avatar
BezerkRC is the other place to get them. He's available on Facebook, and has towers already cut and ready to ship.
Ethan
Old 09-16-2014, 07:38 AM   #2175
erchn's Avatar
The problem that I have faced and have seen others face is a low-medium bite track that is also quite hot 130+ heat. In those situations, light oil and stuff springs contribute to over heating tires, especially if it's a spec tire.
The long shocks give more bite and more consistency while being able to run heavier oil. The stock shocks just weren't as quick, IMO.
