Old 08-24-2014, 06:52 AM   #2146
Thanks JFLX !!! With 54 the FDR is 3.52 ........Xray team in spain tell me to start with around FDR 5.00 That mean with 38T pinion.....
daninter is offline   Reply With Quote
Old 08-24-2014, 08:36 AM   #2147
niznai's Avatar
Originally Posted by metalnut View Post
I've never had a T3 or T3R, but assuming it uses the same size DCJs as a T4, I can recommend the RSD DCJs for sure. I'm told Tamiya would be equally good. You can also try Spec-R, a lot of people here have run them, though I had trouble with mine. Stay away from the Xray DCJs, they're crap.
For all your Xray/Tamiya/Spec-R needs: http://www.tqrcracing.com/
RSD: http://www.reflexracing.net/
Xray outdrives have a different ID to Tamiya, etc., so no. The tamiya dogbone end would rattle in the Xray outdrive like a pea in a can.
Another thing you'd know if you used Xray driveshafts, is they're far from crap.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 08-24-2014, 09:15 AM   #2148
ngo8's Avatar
Send a message via ICQ to ngo8
You should start with 4 run it and go from there if you gear it at 3.5 you might over heat the motor and smoke it ..the xray team told you 5 cause its a safe point ....plus run a nice powerful fan on the motor to keep the temps down ...so 4 to 5 is safe to start
Xray|ORCA|Sanwa|Trinity|KoPropo
ngo8 is offline   Reply With Quote
Old 08-24-2014, 09:32 AM   #2149
chasingthepack's Avatar
ive used them and they are crap,they are too weak at the trunion
i use spec r and haven't had a problem since,ive had 2 xray shafts snap while going down the straight
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 08-24-2014, 09:55 AM   #2150
niznai's Avatar
So have I and since 2001 I didn't manage to break any.
Team Greasy Weasel
Old 08-24-2014, 10:20 AM   #2151
Thanks ngo8 !!! I will start with FDR 4.0 and testing temp....
Old 08-24-2014, 10:28 AM   #2152
metalnut's Avatar
R/C Tech Elite Subscriber
Trader Rating: 36 (100%+)
I have a set sitting in my spares box, they fall apart faster than your arguments.
- Ricky Bobby
Old 08-24-2014, 11:20 AM   #2153
Trader Rating: 13 (100%+)
People use the Smokem spool cups with the Tamiya DCJ's.
The general consensus, on this forum anyway, is that the xray's are crap.
Sean B. is offline   Reply With Quote
Old 08-24-2014, 05:27 PM   #2154
niznai's Avatar
Must be all that consensus that makes them crap then.
Someone should alert all those Xray professional drivers that win races they're driving with crap driveshafts, I think. You know, since they're not frequenting brilliant forums like this.
Team Greasy Weasel
Old 08-24-2014, 06:03 PM   #2155
I tried all of them and I thought by far the best and longest lasting in my opinion were the xray ones.
But I HATE paying that much for them!
So I have since gone to the smokem steel outdrives with Tamiya shafts, which come with bearings and spare clips and pins for $35 a PAIR.
These seem even smoother than the xray ones and the bearing is 1mm skinnier for more steering. the benefit of running no plastic boot on the outdrive side means less maintenance too! Very happy with this setup!
Andrew S is offline   Reply With Quote
Old 08-24-2014, 06:09 PM   #2156
RobS's Avatar
Although I have gone through a couple Xray ECS shafts through the years, I wouldn't go as far as saying they are crap. Expensive yes, but when built correctly I've never had to take them apart again. Just add some anti wear grease every now and then and they last forever.
Rob Say
Action Hobbies Kingsville
"In racing you never really lose. You either win, or learn."
RobS is offline   Reply With Quote
Old 08-24-2014, 06:13 PM   #2157
Or non fling bike chain lube! Works a treat!!
Old 08-25-2014, 02:10 AM   #2158
nerdling's Avatar
... Because that's a strong argument.
I've been running XRAY since 2001. Always used XRAY's drive shafts. Never had a problem.
nerdling is offline   Reply With Quote
Old 08-25-2014, 07:13 AM   #2159
Airflow's Avatar
I had a t2 2009 before. Aluminum outdrives wear out fast even with blades. Now on my spec r s1, I've no problems with the steel outdrives, more than a year of heavy use and no signs of outdrive wear. But I use xray blades on my S1.
Airflow is offline   Reply With Quote
Old 09-01-2014, 01:24 PM   #2160
Dusttt's Avatar
Trader Rating: 121 (100%+)
Any word on the next version? t4/15?
"Whiskey Tango Foxtrot"
Dusttt is offline   Reply With Quote
