Old 08-20-2014, 04:22 AM   #2131
Originally Posted by J-PaP View Post
Anybody have suggestions on counteracting the rear end stepping out on off throttle/neutral turns and changes of direction?
Also having continuous problems with my diff. Seems to leak out of the two halves. This close to putting in a spec r diff. Any suggestions?
I also dont have any problems with the diff leaking , I use the o-ring , but replace it every time I have opened the diff. They are so cheap that I dont re-use them.
Xray T4 2014 / Orca VXX / Orca 5t
Team Xray-shop.dk
johnsen-dk is offline   Reply With Quote
Old 08-20-2014, 05:08 AM   #2132
Skiddins's Avatar
Originally Posted by eded1 View Post
Hi,Skiddins.
You run outdoor or indoor, I like to know i am thinking to buy it for myself.
When I run on RIDE rex34 tires it is some unpredictable on the rear.
It improved stability i hope
Ed
I run indoor on carpet and outdoor on asphalt.
I don't know if the brace will help with rear stability, I think it might reduce rear grip as it is making the top deck less flexible.
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 08-20-2014, 08:19 AM   #2133
PACaSteel's Avatar
Assuming the seals are in right, then one likely issue is the detent isn't seated properly locking to two halves together. If the little bump isn't between the two slots it will leak like a sieve.
PACaSteel is offline   Reply With Quote
Old 08-20-2014, 12:49 PM   #2134
Skiddins
Sorry i described the question for two way,s explanation.
Wat I tried to ask did your car improved on outdoor tracks, this is where my problem occurs.
Ed
eded1 is offline   Reply With Quote
Old 08-20-2014, 01:33 PM   #2135
Skiddins's Avatar
Ed
I don't have the brace that also connects to the top deck, mine just connects the steering posts. I found I did have good steering, but the car is mores sensitive, so if the rear of your car is loose now, it will probably get worse.
Skiddins
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 08-20-2014, 02:07 PM   #2136
daleburr's Avatar
Ed
Give the motor mount post a try instead, that helps a lot with rear stability outdoors.
Team Xray
Old 08-21-2014, 12:12 PM   #2137
Skiddins
Thanks for response Skiddins I give it a try I,ve made one for myself and it is connected to the top deck, I let you know.
Thanks Dalebur, I have already installed the motor mount post and it helps a little bit.
Ed
Old 08-21-2014, 05:43 PM   #2138
Has anyone tried the Arrowmax T4'14 Aluminum chassis?
-Mike
Old 08-21-2014, 06:40 PM   #2139
rangerjkb's Avatar
Trader Rating: 36 (100%+)
Send a message via MSN to rangerjkb
-Mike
Locally, guys are having positive results with it and say it's the same/similar to the Xray aluminum chassis on indoor carpet applications.
Jason Burks
Murfdogg Products~Psycho Cells Racing~Hal's Hobby Warehouse~Avid RC~Kal-Gard~VP Powermaster
rangerjkb is offline   Reply With Quote
Old 08-22-2014, 11:27 PM   #2140
RCknight's Avatar
I've been out of the loop for some time, but what are the best DCJ's for a Xray T3R? Also where's a good online shop that carries Xray parts? My old shop closed down.
RCknight is offline   Reply With Quote
Old 08-23-2014, 10:55 AM   #2141
metalnut's Avatar
R/C Tech Elite Subscriber
I've never had a T3 or T3R, but assuming it uses the same size DCJs as a T4, I can recommend the RSD DCJs for sure. I'm told Tamiya would be equally good. You can also try Spec-R, a lot of people here have run them, though I had trouble with mine. Stay away from the Xray DCJs, they're crap.
For all your Xray/Tamiya/Spec-R needs: http://www.tqrcracing.com/
RSD: http://www.reflexracing.net/
- Ricky Bobby
Old 08-23-2014, 10:59 AM   #2142
If link placing is allowed: The-Border has a realtime stock of Xray parts in the warehouse.
Thaan is offline   Reply With Quote
Old 08-23-2014, 07:09 PM   #2143
TimmyMontoya's Avatar
DiscountRCstore.com they have lots of the spares and options!!
DiscountRCstore.com new distributor of Xray and Hudy
Xray, Hudy, Schumacher, Fantom, Orca
TimmyMontoya is offline   Reply With Quote
Old 08-24-2014, 06:15 AM   #2144
Hello Guys, I am newbie in the 1/10 Electric division, a lot experience in nitro but first time in electric. I recent get a T4 2014 with hobbywing V10 17.5T motor and Hobbywing Xerun Stock Spec V3.1 ESC, my question is......With 64p 100T Spur what pinion you recommended for 17.5T Blinky class in mixed asphalt track ?
Any suggestion help !!!!
Thanks,
Daniel Mazzara
daninter is offline   Reply With Quote
Old 08-24-2014, 06:34 AM   #2145
jlfx car audio's Avatar
Trader Rating: 35 (100%+)
Thanks,
Daniel Mazzara
48-54depending on size of track this should cover most any motors power band
jlfx car audio is offline   Reply With Quote
