Xray T4'14
#2116
So what is the verdict with the aluminum chassis? Been thinking of trying one out but still on the fence about it. Going to be running on a medium/high traction carpet track.
#2117
Can anyone tell me what the graphite steering plate does?
http://rcmarket.com.hk/product_info....1f54f9d5ceeaee
#2118
Not everyone who has used it thought it helped.
#2120
So, if I understand correctly, it goes at the top of the steering post to lock them so they flex less, right?
#2121
#2122
Ah cool! Thanks, will try this as it would suit my track I think
#2123
#2125
Anybody have suggestions on counteracting the rear end stepping out on off throttle/neutral turns and changes of direction?
Also having continuous problems with my diff. Seems to leak out of the two halves. This close to putting in a spec r diff. Any suggestions?
#2126
If you're still using the really thin o-ring, throw it away and clamp the diff halves down properly and evenly (criscross tightening pattern). Following advice here, this is how I got mine to stop leaking.
#2127
None of my Xray diffs have leaked at all, rear has the oring, but front I did without, use some slime or equal grease on the outer orings, make sure you do cross tighten it down as evenly as possible, usually do that in stages as well, the plastic and gasket with compress, so you need to let it sit and torque them down just a little more, though be careful not to strip out any screw holes.
If the car is nervous off throttle, maybe thicker rear oil, I always end up thicker rear oil than kit or many drivers, I like the stability going into a turn to feel more solid, the very light oils make it randomly looser rather than one or the other.
#2128
Thicker diff oil will help your stability issues. 2-3k should do it. Less rear droop may also help, as would a bit more rear camber or camber-gain.
#2129
Ash my self ran it Sunday. Really like it, makes the car feel like your running on new boots every run.
#2130
You run outdoor or indoor, I like to know i am thinking to buy it for myself.
When I run on RIDE rex34 tires it is some unpredictable on the rear.
It improved stability i hope
Ed
