Old 07-24-2014, 08:31 PM   #2086
Team EAM
EAMotorsports's Avatar
Trader Rating: 75 (100%+)
Send a message via AIM to EAMotorsports
Originally Posted by xrayaustin View Post
Well the Tamiya uses a floating mount. Not sure about the screw spacing? Couldn'tI just run the servo with my current servo mount
Yes you can use the Normal servo (the 149.00 version) and it has normal ears just like any other servo.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | ProSpec America | Killer Concepts | AVID | Futaba.
EAMotorsports is offline   Reply With Quote
Old 07-25-2014, 10:49 AM   #2087
metalnut's Avatar
R/C Tech Elite Subscriber
Trader Rating: 36 (100%+)
Smokem Racing T4’14-IIX chassis
- Ricky Bobby
Old 08-03-2014, 11:15 PM   #2088
Trader Rating: 13 (100%+)
Originally Posted by veecee View Post
I run the Smokem spool cups in mine. These let you use the Tamiya DCJ's which are absolutely bulletproof, buttery smooth and are the least expensive DCJ's around (~$35). The Smokem cups are really durable as well (pretty sure they are spring steel). Win-win in my opinion.
Are blades used with this setup?
Sean B. is offline   Reply With Quote
Old 08-04-2014, 09:32 AM   #2089
Trader Rating: 57 (100%+)
No.
PROMODVETTE is offline   Reply With Quote
Old 08-04-2014, 09:58 AM   #2090
Nice job on all the wins in TC at the nats
Jackson RC Raceway, Home of the 2011 Paved On Road Nats!
Horsham RC Raceway,Home of the 2013 and 2015 Carpet On Road Nats!
Awesomatix USA/ Side Piece Racing / TQ Wire / CR Graphics / R1 Wurks / LRP /Jackson RC Raceway / Horsham RC Raceway/RIP Jon Williams
Al Sodano is offline   Reply With Quote
Old 08-08-2014, 12:32 PM   #2091
RC MARKET's Avatar
Trader Rating: 12 (100%+)
XRAY New product release !
Xray T4'14-xr-301351-o.jpg   Xray T4'14-xr-302570.jpg   Xray T4'14-xr-306191.jpg
Old 08-08-2014, 06:34 PM   #2092
Ordered. Thanks.
https://www.gofundme.com/ncontrol
Joe Maxey is offline   Reply With Quote
Old 08-08-2014, 06:47 PM   #2093
I'm still trying to understand the Alu body post stops. It doesn't change the fact that the body clip holes are set positions. What makes it adjustable?
Old 08-08-2014, 07:07 PM   #2094
It had a top cap with a small o ring that you can screw and unscrewed to adjust the body height.
Old 08-09-2014, 09:03 AM   #2095
I understand that part, but it's not like you can change the body clip height as well. It seems that if you lower the stops, the body would be slopping around on the posts.
Old 08-09-2014, 09:49 AM   #2096
Isn't the body held down by the downforce anyways with the clip just being there to keep it in place in case of impact?
halldor is offline   Reply With Quote
Old 08-09-2014, 10:00 AM   #2097
theproffesor's Avatar
Trader Rating: 45 (100%+)
I dont run xray, but for this topicnit doesnt matter. I place small pieces of 1/16 thick foam on top of the body mount platform, some run them on the body, but then you have to make new one with every body. This keeps the body held down tight by the pins and you dont get any shaking of the lexan on the plastic mounts.
Tamiya 419x
Tamiya TA07
Tamiya M05
SMC - Fantom - Motiv - Savox - Spectrum - Exotek.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 08-09-2014, 10:19 AM   #2098
metalnut's Avatar
You're actually supposed to let the body move freely on the mounts. That means slightly oversized body holes, and some play between the clip and the mount platform. If your body is on tight, you're tweaking the car. The body has to move around freely to let the car twist as intended.
- Ricky Bobby
Old 08-09-2014, 10:38 AM   #2099
The body is still free to move. Its extreamly soft foam.
Tamiya 419x
Tamiya TA07
Tamiya M05
Old 08-09-2014, 02:18 PM   #2100
heretic's Avatar
Actually, leaving the body loose on the vertical axis is also a good idea. This way, the body can touch a corner marker and move without taking the car with it. It really works. I will never run my body "pinched" ever again.
Coucou Georges !
I love wedge bodies. I love dish wheels.
heretic is offline   Reply With Quote
SEO by vBSEO 3.5.0
