Old 10-10-2013, 04:09 AM   #196
Bishop's Avatar
I pre-ordered my T414 today (I like calling it the T414 LOL), Australian stock I think is due Monday or Tuesday, looking forward to getting it, really looking forward to the build, and getting a much closer look at what I think is going to be a fantastic toe/roll design.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 10-10-2013, 05:51 AM   #197
chasingthepack's Avatar
Originally Posted by hyujmn View Post
it's designed for just 25* of steering.
i wish lol,i could only get 27 deg left and 23 right at first,after playing around for far to long i now have 24 deg each way,thats the best i could do
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 10-10-2013, 06:08 AM   #198
morgoth's Avatar
Are your ackerman links the same length left and right? And the servo has full throw?
Serpent BeNeLux teamdriver // FX Engines // Nitrolux fuel
My blog: http://scrubbingspeed.wordpress.com
morgoth is offline   Reply With Quote
Old 10-10-2013, 07:12 AM   #199
Skiddins's Avatar
This is the clearance with my rod ends;
Completed at last;
Using the lower hole in the servo saver I get 24-25deg steering on both sides, despite the fact I had to increase the EPA to increase the motion.
Xray T4'16, T4'14 (Wet Car)
Xray X12 2016
Xray X1'16
RCDisco.co.uk
Old 10-10-2013, 07:32 AM   #200
morgoth's Avatar
You're front bulkheads are missing a few screws Or is that on purporse?
Old 10-10-2013, 08:31 AM   #201
Skiddins's Avatar
There's a technical reason for that.. I forgot to refit them after removing the spool
And no, I hadn't even noticed until you pointed it out
Skiddins
Xray X12 2016
Xray X1'16
RCDisco.co.uk
Old 10-10-2013, 08:45 AM   #202
Skiddins
*face palm*
you have noticed that the battery holders are missing too right?
Old 10-10-2013, 08:48 AM   #203
oh and heres one for ya,since i ran mine its developed a small amount of slop in the rear uprights,they move forward and back on the pivot pins,is this something that needs shimming?at a guess id say a 0.3 shim should make it snug again,but is it worth doing?
Old 10-10-2013, 08:53 AM   #204
yeah,epa is at 120 and all measured with digital calipers,the links are spot on,i moved the saver around a few times and go nowhere,ive got it turning the same amount each way so alls good,if i suffer from a lack of steering ill work more on set up
Old 10-10-2013, 08:57 AM   #205
Completed at last;
just need the orange speedo and the orange orca motor ,i dont think you have enough orange yet
Old 10-10-2013, 09:35 AM   #206
locked's Avatar
Yeah, too much red there Damien. Better fix that. Uniform color is worth at least 0.2s/lap
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 10-10-2013, 10:14 AM   #207
imprsme's Avatar
Trader Rating: 70 (99%+)
Did you put the servo saver in the top hole? If I use the lower hole I can't get full throw. The barrel is no where near hitting. Prob a 2-3 mm gap at full throw. Moved it up and had to take 20% of dual rate out of my radio and backed 10% of EPA out of both sides. More steering than I needed..lol
imprsme is offline   Reply With Quote
Old 10-10-2013, 10:46 AM   #208
Skiddins's Avatar
*face palm*
I never run the holders.
First time I bought an Xray kit that came with them I fitted them, Broke one on the very first run.
Just something else to stick out and make contact with the ground.
Xray X12 2016
Xray X1'16
RCDisco.co.uk
Old 10-10-2013, 11:01 AM   #209
Skiddins's Avatar
Invest in a decent servo.
My Sanwa BLS (with the link in the lower hole on the servo saver) can give me more than enough lock and I'm not at 100% on the radio.
It's circa 27deg on the inside and 19deg on the outside wheel when running around 0.5deg toe out.
Xray X12 2016
Xray X1'16
RCDisco.co.uk
Old 10-10-2013, 12:35 PM   #210
Jerz616's Avatar
Trader Rating: 49 (100%+)
Here is a picture of Matrin Hudy's cars at IIC. Look at the one in the left. The rear upper clamps are different. Anyone see these on any cars. Looks like the inside camber link holes are not in the typical triangle pattern.
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
