Old 06-11-2014, 02:35 AM   #1876
Skiddins's Avatar
Originally Posted by Brokin Racing View Post
Skiddins,
Sorry to single you out mate, what body do you suggest on carpet??
Cheers
Originally Posted by locked View Post
Protoform mazdaspeed6 lightweight is the most common go-to shell for carpet. Other shells can work well too, in certain conditions, depending on driving style and setup, but speed6 lw is what most people use, the majority of the time.
Just answering because it's pretty late in England, so Skiddins might not see your question until tomorrow and I kind of doubt he'll have a vastly different response than this anyway.
What he said
I've tried other bodies that seem pretty good and usually get the same laptimes, but they are simply more difficult to drive.
I always run light weight shells
The only other bodies I've liked on carpet was the Nazda 3 (may need to make the setup a little easier to drive first) and Blitz TSX (on higher grip carpet) but my main choice is the Speed 6 LW just like everyone else
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 06-12-2014, 11:33 AM   #1877
patorz31's Avatar
I was just wondering what would be a good FDR for a 7.5t mod motor for a track with a 100ft straightaway? I am new to brushless mod motors.
Northern Alberta Scale Car Auto Racers Pres. and Promotions
TEAM POWERS, RACE-OPT, SCHUMACHER RACING,R-Factor, Bezerk RC
patorz31 is offline   Reply With Quote
Old 06-12-2014, 11:34 AM   #1878
erchn's Avatar
I'd probably start around 6.
Serpent ; Desoto Racing ; Team Powers USA ; Reflex Racing ; Bezerk RC
Old 06-12-2014, 12:39 PM   #1879
Trader Rating: 20 (100%+)
Boosted or blinky?
www.teamgravityrc.com
Leisure Hours Raceway
Troy Carter is offline   Reply With Quote
Old 06-12-2014, 01:20 PM   #1880
patorz31's Avatar
Originally Posted by Troy Carter View Post
Boosted or blinky?
Blinky to start and if I need more top end I will boost it.
Old 06-12-2014, 02:27 PM   #1881
I would decide first. If you go boosted, I'd gear it at 8:1 to start and add boost as needed. If you go blinky I'd start around 6:1 and gear for motor temps and I wouldn't add boost at this ratio.
Old 06-12-2014, 10:17 PM   #1882
Trader Rating: 11 (100%+)
the pros are running a FDR of 8 t0 8.5 with a 4.5T booted and turbo.
silden is offline   Reply With Quote
Old 06-13-2014, 06:02 AM   #1883
rangerjkb's Avatar
Trader Rating: 36 (100%+)
Send a message via MSN to rangerjkb
+1, I would go with recommended FDR aroung 6 to 6.5. Pull off and check motor temps every few minutes and move from there based on track requirments. For comparison, I gear a 5.5T at 8.1 FDR and add/subtract boost if needed. Hope this is helpful.
Jason Burks
Murfdogg Products~Psycho Cells Racing~Hal's Hobby Warehouse~Avid RC~Kal-Gard~VP Powermaster
rangerjkb is offline   Reply With Quote
Old 06-13-2014, 10:45 AM   #1884
Mechintosh's Avatar
I run a 4.5t Boosted. Gearing is 26/110 for a 8.04. Coming off in the 120's after 6-8 minutes.
Xray T4-14,T4-15, X1
Pro Mini Truggy Mid Motor Mafia Xfactory
Serpent SRX4, 811 TE-e
Kyosho RB6, MP9e TKi
Mechintosh is offline   Reply With Quote
Old 06-13-2014, 05:43 PM   #1885
Brokin Racing's Avatar
R/C Tech Elite Subscriber
Trader Rating: 68 (100%+)
Many thanks...
Xray Since 2007 - LRP - PF - Futaba -
Brokin Racing is offline   Reply With Quote
Old 06-15-2014, 08:49 PM   #1886
metalnut's Avatar
We have two asphalt tracks in my area that I've been racing at this summer. One is always meticulously prepped and sprayed with a mix of grape soda and snow cone syrup, resulting in great traction. The other track is often not prepped at all, which leaves it dusty with very low traction.
My setup works great on the high grip track. I'm basically running the kit asphalt setup but with longest camber links, 2* toe in the back, RSD progressive asphalt springs (green front, silver back: http://www.reflex-sd.com/RSD-20mm-As...ir_p_1735.html), 1* camber all around and 5.5mm ride height. Droop is 2mm in the front and 2.5mm in the back. Kit sway bars.
That setup does not work very well on the low traction track at all. The car pushes into the corner and fishtails out of the corner if I'm not super gentle on the throttle. Basically crap. I know I have to soften the car up, but my question is this: should I be softening up the springs or the sway bars first? Or both?
Thanks!
- Ricky Bobby
Old 06-15-2014, 09:46 PM   #1887
Yes, but 4.5t doesn't need as much boost as slower motors and a 7.5 is a much slower motor. Back in the 17.5 boosted days I think most guys were 6-6.5 FDR with a ton of boost. My 10.5 car I run 7.5 fdr with way more boost than my 4.5t can take. If I gear it higher, say 6.5 fdr it's slower and hotter no matter what boost settings I use.
Old 06-16-2014, 03:08 AM   #1888
maybe i am missing something here but anyone using current limiting to assist in heat management?, granted different tracks may get more or less advantage out of this, but it definitely helped me,.. i run 4.5t boosted geared around 6.5 to 7.0 depending on tyre size ( foam lola class ) on medium /large outdoor asphalt
cheers
oldenuff
oldenuff is offline   Reply With Quote
Old 06-16-2014, 01:48 PM   #1889
chasingthepack's Avatar
Thanks!
youll be better off lowering the roll center to get the car to roll into the corners more as a starting point
2mm inner front and 2/3mm inner rear camberlinks
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 06-16-2014, 02:04 PM   #1890
metalnut's Avatar
Although I see what you're saying, the kit sway bars are pretty stiff. Wouldn't thinner sway bars also result in more roll? Not trying to challenge your opinion, just trying to understand
- Ricky Bobby
