Xray T4'14
#1861
Thanks for the response guys, looks like I have the standard 1.5mm ECS shafts. When I bought the car used it came with the 50mm Hudy DCJs, otherwise I would have looked towards something cheaper since they all seem to be of about equal quality!
I'm not sure how, but mine became slightly bent where the little nipple on the end of the axle sticks into the driveshaft bone within the coupler between the two. The hole the little nipple goes into has a flat side to it, so it binds on full steering lock. Don't know how it happened, but interesting break/bend nonetheless.
#1862
I would try to fix that problem with a drill bit. Try to round the hole with the tip.
#1865
shocks
hi guys,
im having a little bit of trouble tracking down a fix for my setup.
on a run the car initial feels great, but at the 2-3min mark the handling goes away a bit, and feels not as sharp.
i feel that the shocks are overheating???
what should i do?...just rebuild the shocks or look at piston size, and change the weight of oil.
David.
David.
#1866
hi guys,
David.
David.
#1867
Im using Xceed 400cst all around. its winter down here so ambient temps are around 13-17c
#1869
They look like a brand new product, I noticed them the other day while looking to buy some ecs shafts, in the end though given I have seen zero feedback on them, I went for the Arrowmax V2 ones myself, so I'll see how those go for me.
I only recently got around to doing some running with my T414, it's crazy good out of the box, fair bit of chatter though in the front end with the stock driveshafts, I'd have thought all the brands would be including the ECS is as stock kit build equipment by now.
Also I can't figure out why they don't include the bumper brace, someone spun in front of me last meet, if not for the brace, my chassis would have been done.
#1870
I happened to lokk at myrcm at the latest result from ETS and was surprised to see some teamdrivers running the T3 ´11 instead of the T4. Why's that?
#1871
Yep, fantastic. Half a season down and no wear or other issues. I'm always a bit reluctant to put after-market parts on an Xray as it will usually be a downgrade given the quality of the kit parts. But this is one exception I'll make.
They were the only DCJs I couldn't find negative feedback on. I've snapped Xray ones myself, seen RSD pins snap (plus import duty into the UK), and read that the Spec-R ones develop lots of slop. So I took a punt and it worked out.
#1872
#1873
Protoform mazdaspeed6 lightweight is the most common go-to shell for carpet. Other shells can work well too, in certain conditions, depending on driving style and setup, but speed6 lw is what most people use, the majority of the time.
Just answering because it's pretty late in England, so Skiddins might not see your question until tomorrow and I kind of doubt he'll have a vastly different response than this anyway.
#1874
I would not touch the SpecR ones, seen them break even in stock classes, the Xray ones are a pain with retaining the pins and having to heat shrink them, and the pins seem to snap rather easy.
Saw some of the Arrowmax in the flesh before though, they looks well made, and I like the rebuild kits are easy to get and cheap.
May get some Roche ones though still, actually I'm tempted to get some 50s for the back end, someone said they were really good to use when running Mod.
Actually I did buy one Roche product anyway, their drive blades, a race friend said they were the best.
