Old 06-09-2014, 09:05 AM   #1846
erchn's Avatar
Originally Posted by tiago890 View Post
Hey guys,
Thanks for all the input, I bought the bumper brace and a few spares, I'm running on a small technical track with high grip, any suggestions on springs
Thanks once again
The kit 2.5 springs should be a good fit. Take a look at the teamxray.com setup sheets, there you will find many solid setup options from top team drivers, maybe even some from the track(s) at which you plan on racing.
Serpent ; Desoto Racing ; Team Powers USA ; Reflex Racing ; Bezerk RC
Old 06-09-2014, 10:17 AM   #1847
tiago890's Avatar
Sponsors: DaWife Racing and Team Myjob
tiago890 is offline   Reply With Quote
Old 06-09-2014, 11:00 AM   #1848
metalnut's Avatar
R/C Tech Elite Subscriber
Trader Rating: 36 (100%+)
Hey guys,
Thanks once again
I really like 2.9 front and 2.7 back on our high grip carpet, but this is for VTA 25.5 with HPI vintage tires.
- Ricky Bobby
Old 06-10-2014, 03:08 PM   #1849
mschumi101's Avatar
Trader Rating: 21 (100%+)
Send a message via Skype™ to mschumi101
With the Hudy ECS shafts, what is the difference between the 2mm pin, and the regular. I notice both types available online. If the pins are different sizes, which pin is 2mm? Is it the pin into the differential, or the pins in the joints. I ask because I would like to replace 1 50mm ECS driveshaft bone, as mine has a small bend, and slightly binds at full lock. So how do I know which ones I have, and which one I need to buy to replace?
These are the two parts for reference:
2mm: http://www.amain.com/product_info.ph...t-Bone-2mm-Pin
Normal: http://www.amain.com/product_info.ph...ft-Bone-50mm-1
Associated B5M Reedy 7.5 | Xray T4 ORCA 17.5
Orange Powered!
Previous: B44.2 | TC5R | TC5 | B4.2 | B44 | Slash | E4RS | TA05R | TT01
-Ted
mschumi101 is offline   Reply With Quote
Old 06-10-2014, 03:43 PM   #1850
Jerz616's Avatar
Trader Rating: 49 (100%+)
Its referring to the 2 pins that holds the ESC together at the coupler. The one you have listed as normal is a 1.5mm pin. You just need to know if yours is a 1.5 or a 2mm pin. Its pretty easy to tell the difference as the 2mm pin is obviously bigger.
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 06-10-2014, 03:43 PM   #1851
The 2mm pin version was supposed to be a stronger alternative. I have personally found that it just makes them break in a different location.
Ricky Garner
Sponsors: My Wife and AVID RC
Mclarein is offline   Reply With Quote
Old 06-10-2014, 03:54 PM   #1852
erchn's Avatar
Agreed, that's why I run RSD DCJs. :-)
Old 06-10-2014, 05:31 PM   #1853
Brokin Racing's Avatar
Trader Rating: 68 (100%+)
Skiddins,
Sorry to single you out mate, what body do you suggest on carpet??
Cheers
Xray T4'17 - LRP - PF - Futaba - Muchmore
Brokin Racing is offline   Reply With Quote
Old 06-10-2014, 05:58 PM   #1854
locked's Avatar
Protoform mazdaspeed6 lightweight is the most common go-to shell for carpet. Other shells can work well too, in certain conditions, depending on driving style and setup, but speed6 lw is what most people use, the majority of the time.
Just answering because it's pretty late in England, so Skiddins might not see your question until tomorrow and I kind of doubt he'll have a vastly different response than this anyway.
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 06-10-2014, 06:01 PM   #1855
I bought the rsd's thinking it would be better, I ran into bent pins and lost clips. I got tired of replacing clips and then went to heat shrink. I got tired of that, so back to xray's for now.
Ricky Garner
Old 06-10-2014, 06:49 PM   #1856
erchn's Avatar
The clips can be a touch finicky at times, but once they are on there you don't need to remove, I've run nearly a season on one set without rebuild...just grease from the outside.
If you are willing to try them again, I think you'll be happy, the latest batch are the easiest to build yet...
Old 06-10-2014, 06:49 PM   #1857
jeff jenkins's Avatar
Trader Rating: 74 (100%+)
ive heard the roche dcj's are pretty good. any input on this?
jeff jenkins is offline   Reply With Quote
Old 06-10-2014, 06:50 PM   #1858
Odin544's Avatar
Trader Rating: 93 (100%+)
Agreed. MS6 or LTCR. Depending on driving style and how tight the track is.
TriCitiesRC.com
Old 06-10-2014, 06:55 PM   #1859
Odin544's Avatar
I had some experience with the RSD V1's on a TC6 and hated them.The clips were always popping off and then everything would come apart. That was at least 2 years ago. Bought some of the latest version for my Xray this last fall for mod and had zero issues with them. I put the 2mm Xray ones in another car for 17.5 and had zero issues with them as well. And I've hit a ton of stuff with no broken parts.
I find nothing wrong with the Xray ones. But I also find nothing wrong with the RSD ones at half the cost. When I build the new car this fall, I will get either the RSD or possibly the Roche.
TriCitiesRC.com
Old 06-10-2014, 07:03 PM   #1860
metalnut's Avatar
I have the Xray DCJs and I've had the same one lose a set screw twice, chewing up my caster hub with the pin (though the pin stayed partially in, so I didn't lose it at least). A few days ago I pulled both DCJs out, motor sprayed the crap out of all the parts, used a good amount of loctite on all the set screws, let them sit, and finally lubed them before installation. I'm hoping this time they'll hold. The other one was always fine, just one of them was giving me trouble.
- Ricky Bobby
