Old 10-08-2013, 04:53 AM   #166
Skiddins's Avatar
Originally Posted by Boostinswifty38 View Post
Couldn't a person just buy the pivot blocks and that chassis and it would basically be a 2014?
More or less yes.
Pivot pins are different as well, Top deck has that extra narrow section that can take a post up from the motor mount.
T4'13 front wishbones will require an extra 2mm shim at the rear of them to fit the mounts.
Xray T4'16, T4'14 (Wet Car)
Xray X12 2016
Xray X1'16
RCDisco.co.uk
Old 10-08-2013, 05:37 AM   #167
morgoth's Avatar
Yes and the topdeck is slightly different too. But for me it's cheaper to sell my T4 2013 and buy a new T4 2014 than upgrade my old car.
Serpent BeNeLux teamdriver // FX Engines // Nitrolux fuel
My blog: http://scrubbingspeed.wordpress.com
morgoth is offline   Reply With Quote
Old 10-08-2013, 06:51 AM   #168
Trader Rating: 20 (100%+)
Anyone want to sell their '14?
...maybe a bit too early?
www.teamgravityrc.com
Leisure Hours Raceway
Troy Carter is offline   Reply With Quote
Old 10-08-2013, 07:18 AM   #169
Originally Posted by chasingthepack View Post
regarding set ups,has anyone deviated from the basic set up? i have with the shock position and oil and 2.7 springs,diff oil thicker,other than that ive done the rest,will there be a manual explaining what the arm mount positions do and why?
strangly i did the same as you at rug racers, but did not get round to changing the diff oil. looking very promising though I must say
shrek54 is offline   Reply With Quote
Old 10-08-2013, 07:36 AM   #170
tc3team's Avatar
Originally Posted by RCFREAK View Post
Here is a tip to cut the time of swapping out swaybars. Also a way to keep all the mounts from falling on the table or ground resulting in lost time and lost pieces.
Step 1. remove stock screws,(discard over the shoulder) insert longer screws! You will never have to fiddle with the mounts again.. long screws will all you to loosen quite a bit,turn the top mount 90 degrees and remove and insert new sway bars instantly!
Process now takes less than 10 seconds!
Simple but very effective= OPTIMIZED!
Super tip, kudos for sharing!
Better than grease too imo.
I will see how I get on with both ideas but the longer screws is definitely sounding like the better long term optimized option!
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 10-08-2013, 07:59 AM   #171
Trader Rating: 24 (100%+)
Default T4
Does anyone know when purchasing from rc market if it is in your cart will it say if out of stock if the kit is out. Don't want to order kit and it be on back order. Thanks
Rob Gleason
sponsors: NemoracingUSA, Agama A215,Agama A215e, Beta tires
triplejracer is offline   Reply With Quote
Old 10-08-2013, 08:03 AM   #172
Skiddins's Avatar
Did you try kit settings at all?
Xray X12 2016
Xray X1'16
RCDisco.co.uk
Old 10-08-2013, 09:17 AM   #173
Yes, durring practice(when grip was low) and it was awsome, but as grip came up durring the day I was in trouble. went to 2.7 in the front with 450w oil, rear 400w, moved the shocks in 1 hole all round. and it was a lot better, not 100% but defo a lot quicker in the corners than the 2013 with out a doubt
Old 10-08-2013, 11:24 AM   #174
chasingthepack's Avatar
well i managed to get mine on track,albeit a very dirty track as it hasnt been used for 2 weeks,got the leaf blower out and gave it a once over ran 2 packs on old tyres and then went for the full monty with new tyres ,corner speed is up over the 13 but i felt it pushed more on entry,mid and exit is better,with 2.7's allround 400f and 450 rear the rear was loose,but only just,a better driver probably would have loved it but i like the rear to be planted,it was running kit settings apart from the diff oil and shocks/oil/springs and im using the 1.3 front anti roll bar,i put a .5 shim under the fr and removed the layshaft screws and although better initial the rear still wasnt to my liking,with so much steering maybe now i can go back to 3.5 rear toe,hopefully with a better condition track it will be better still,i was mostly gearing a new motor so didnt mess to much with it,this weekend will hopefully prove that it is faster than the 13,it definately carried more corner speed as i was able to get on the power 4/5 ft earlier than i was with the 13,i will be going back to my colder weather set ups,at a guess ill be running 400 f and 350 r seems like it wants to roll more to get the grip,but as everyone wanted more steering i can say it has more
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 10-08-2013, 12:13 PM   #175
AL1983's Avatar
Thumbs up @triplejracer
Yes,
It will say ***out of stock (in red).
AL1983 is offline   Reply With Quote
Old 10-08-2013, 03:11 PM   #176
syndr0me's Avatar
Trader Rating: 32 (100%+)
Does the '14 have any of the stuff designed to keep the bumper from ripping through the chassis? Like the front brace or a taller bumper or whatever?
syndr0me is offline   Reply With Quote
Old 10-08-2013, 03:20 PM   #177
AL1983's Avatar
Post
No,
Bumper brace is still optional!
Old 10-08-2013, 03:23 PM   #178
AL1983's Avatar
Post
Foam bumper still the same dimensions just harder!
Old 10-08-2013, 03:31 PM   #179
syndr0me's Avatar
Hmm, cool, thanks. I'll just go with the tall standoffs and hard bumper from the T3 days.
Old 10-08-2013, 03:34 PM   #180
thats what ive been doing,no need for the optional brace
