Old 04-23-2014, 12:48 AM   #1726
daleburr's Avatar
For the 2015 car I would like to see:
Locator dowels on all of the bulkheads and suspension mounts to key them to the chassis and shock towers for improved accuracy. This renders all of the existing parts obsolete though so maybe we'll have to wait till the T5...
Axle crush tubes. I make my own up and it does remove some play from the bearings.
Open rod-ends, as the kit closed ones now rub the wheels.
Bumper brace included in the kit (or a redesigned plastic bumper). I'm bored of telling everyone to buy this when they do their kit purchase ;-)
2.7 springs included in the kit, since thats what everyone I know runs most of the time.
Stronger ECS shafts. I can't honestly advise people to buy the Xray ones as a I know of too many that have broken, and all in exactly the same place (the dogbones shear off at the axle end).
Mostly pretty dull stuff. The '14 handles fantastic so improving that for the '15 will be very difficult, though I'm sure Xray will manage it.
Team Xray
Old 04-23-2014, 09:42 PM   #1727
Would someone be able to do me a huge favor and post the dimensions ( particularly the inner diameter ) of a 4S spring ( set ), either the progressive or linear. I've googled everywhere and can't seem to find a measurement. I'm looking for "shorter" springs and I believe these are 20mm which would be perfect but I know the new t4 shocks have a larger than average bore (?) so they might be too wide for my application. Thanks much, I really appreciate it.
ZeeFlyingBrick is offline   Reply With Quote
Old 04-23-2014, 10:02 PM   #1728
B00t13g's Avatar
R/C Tech Elite Subscriber
All I want to see for 2015 is for roar, ifmar etc to lower minimum weight to 1350. The 2014 is by far the best touring car I have ever driven. I would prefer to see graphite arms included in the kit, but that's me nit picking.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 04-24-2014, 03:57 AM   #1729
Trader Rating: 57 (100%+)
About 14mm measured with a ruler.
PROMODVETTE is offline   Reply With Quote
Old 04-24-2014, 07:47 AM   #1730
Thanks so much for the help, really appreciate it!
Old 04-24-2014, 11:02 AM   #1731
jlfx car audio's Avatar
Trader Rating: 35 (100%+)
I would like to see active rear toe and thats only improvement that I want.
well maby graphite plastics .. chubs , arms , knuckles.
Make plastic inserts out of softer nylon (lip as broke off a few of mine .
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 04-26-2014, 01:27 PM   #1732
I guess that the 2015 will be equipped with a parallel steering rack like schumacher, to have more precise steering without unnecessary play in the steering rods.
Ed
eded1 is offline   Reply With Quote
Old 04-28-2014, 12:47 PM   #1733
imprsme's Avatar
Trader Rating: 71 (99%+)
I need a little help..lol
Can anyone look and tell me which holes on the body post you have ur Mazada Spped6 mounted?
I have one mounted and everyone is telling me it looks slammed.. it looks low. But when I measure the roof height it is legal per ROAR rules.
Just wondering where everyone else has them mounted.
imprsme is offline   Reply With Quote
Old 04-28-2014, 04:29 PM   #1734
Odin544's Avatar
Trader Rating: 93 (100%+)
Lower is better. As long as you are high enough for the rules and not dragging you are good.
TriCitiesRC.com
Old 04-28-2014, 04:46 PM   #1735
Trader Rating: 13 (100%+)
10th hole on front & 5th hole on rear. My body is centered on mounts.
https://www.gofundme.com/ncontrol
Joe Maxey is offline   Reply With Quote
Old 04-29-2014, 03:42 AM   #1736
niznai's Avatar
Keying the aluminium ware is one of my long standing desires too. But it needn't be so dramatic. Slightly undersized holes in existing hardware and small 3mm steel pins forced in would do the trick nicely without any need for further redesign of the 3D renders. Would be better too than having piddly little aluminium prongs which would add considerably to redesign/machining costs. Tamiya did this on the TRF418 (to some extent - they missed the shock support plates and suspension hingepin mounts) and the little prongs are too small to ensure a tight one-way fit which made it an almost futile exercise.
I make my own spacers (why crush?) from decommissioned bearings' inner races. After all, the bearings wear out, the spacers last forever.
What do you mean by open rod ends? You mean eyelets? Not sure how that would help clearing the wheels?
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 04-29-2014, 04:18 AM   #1737
Skiddins's Avatar
If you use the kit ball ends but with eyelets instead of the kit rod ends the reduced amount of material on top of the ball end provide slightly more clearance.
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 04-29-2014, 06:25 AM   #1738
niznai's Avatar
Right. I was thinking of the track rod ends.
Team Greasy Weasel
Old 04-29-2014, 08:59 AM   #1739
Trader Rating: 31 (100%+)
Wish I had this car:-(
X-ray man is offline   Reply With Quote
Old 04-29-2014, 05:02 PM   #1740
I'd like to see nothing on the '15 at all. That way, I won't end up buying a new car that won't make me a bit faster. Richer, and just as slow as ever ; )
Pipe Killer is offline   Reply With Quote
