Old 04-21-2014, 05:26 PM   #1696
Skiddins's Avatar
Originally Posted by ByteStream View Post
Honestly I've never had an issue with the hex's and I've run Xray for many years. I've used these ..
http://www.amain.com/product_info.ph...-Cap-Screws-10
There definitely was an issue with early kits this time. I had problem hexes for the first time ever on an Xray.
Xray T4'16, T4'14 (Wet Car)
Xray X12 2016
Xray X1'16
RCDisco.co.uk
Old 04-21-2014, 05:41 PM   #1697
Trader Rating: 27 (100%+)
Originally Posted by chasingthepack View Post
the t4 15/t5 will have an alloy chassis
Not stock, I think. Xray loves making money on stuff like that.
Xray | Airtronics | R1Wurks LiPo | Hobbywing
hyujmn is offline   Reply With Quote
Old 04-21-2014, 06:07 PM   #1698
theclutch's Avatar
You mean the screws were soft and the hex part strips easily?
Durango DEST210R, XRAY XB4 2014, Vaterra Slick Rock, Durango DEX210, SpeedMerchant REV4, HB TCX, Traxxas EMaxx, HPI RS4 Pro, Tamiya TA02, Yokomo YZ10, Associated RC10 Team Car, Bolink Eliminator 10, Kyosho Optima, Tamiya HotShot, Tamiya Grasshopper
theclutch is offline   Reply With Quote
Old 04-21-2014, 07:41 PM   #1699
Odin544's Avatar
Trader Rating: 93 (100%+)
I agree with bytestream. Updates in '15, new car in '16.
I think we'll see a narrower chassis, lowered CoG, new steering geometry, different sway bar links and new sway bars.
No way are we seeing an aluminum chassis in the kit. Thats only good on high traction in its current form.
Their was an issue with the screws in the hexes, not the hex itself. And that has been taken care of with a new screw, that are clearly different from the old ones. If you are still having issues with them then its because of heavy handed wrenching.
TriCitiesRC.com
Old 04-21-2014, 08:18 PM   #1700
I never had a problem until the '14.
Ricky Garner
Sponsors: My Wife and AVID RC
Mclarein is offline   Reply With Quote
Old 04-21-2014, 09:20 PM   #1701
Trader Rating: 57 (100%+)
The 14 screws for the hex's were too long. If you trimmed a mm off the screw it would have been fine.
PROMODVETTE is offline   Reply With Quote
Old 04-22-2014, 07:55 AM   #1702
Team EAM
EAMotorsports's Avatar
Trader Rating: 75 (100%+)
Send a message via AIM to EAMotorsports
This is my favorite time of the year for watching this thread. I love to watch what everyone wants/thinks the next car is going to be like. Xray does watch this thread and takes your input and thoughts on these things too btw!
This being a worlds year I would expect that we will have stuff a little earlier to run than the normal IIC time frame. **Note** Martin has not said that in any emails just my speculation since the Worlds are the first week of October.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | ProSpec America | Killer Concepts | AVID | Futaba.
EAMotorsports is offline   Reply With Quote
Old 04-22-2014, 08:06 AM   #1703
Im guessing new upper bulkheads with different link mounts, new layshaft holders 1mm lower that top deck, change in steering to allow up to 30 degrees or more, and maybe a little narrower chassis.
Old 04-22-2014, 08:07 AM   #1704
Trader Rating: 20 (100%+)
EA
I particularly like it around February myself. That's when all the people who got the early kits decide they need something different and I can get a deal on the new car!
Er...don't tell anyone that's my game plan...it's a secret!
www.teamgravityrc.com
Leisure Hours Raceway
Troy Carter is offline   Reply With Quote
Old 04-22-2014, 09:16 AM   #1705
Otherwise known as the Xray Optimization!
Alex Leeman
Team RC America
Team EA Motorsports
Progressive R/C
92zero Designs
Leeman#3 is offline   Reply With Quote
Old 04-22-2014, 09:29 AM   #1706
Skiddins's Avatar
...change in steering to allow up to 30 degrees or more...
Highly unlikely as Martin already justified their reason for limiting it to less lock in the first place, it isn't necessary.
Xray X12 2016
Xray X1'16
RCDisco.co.uk
Old 04-22-2014, 09:55 AM   #1707
LOL you and me both! Picked up two used Xray T4's around that time for cheap.
Old 04-22-2014, 10:51 AM   #1708
chasingthepack's Avatar
+1 on that,im running no ackerman shims with 1.5 toe out,the outer wheel turns in at about 20 degrees on mine (this is a rough guess as i have the old hudy system which doesnt measure that angle) and turns in better than with the outer wheel turning in more
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 04-22-2014, 10:57 AM   #1709
+1 ,i was only kidding to see a responce,i doubt it too
but there will be new upper bulkheads as these have been seen on hagbergs car
and hopefully some 0.25 and 0.75 arm mount inserts(are you listening xray )
and maybe im the only one but id like to see the crush tubes to go in the hubs to support the wheel bearings better(like on the tc6) and reduce the slop in the bearings/wheels
another thing id like to see but doubt very much that it would ever happen ,but to reduce slop completely how about a new wheel bearing altogether,a tapered bearing where you have a steel insert that slides into the steering knuckle/hub with a small keyway and then 2 tapered bearings from each side with a crush tube between to stop any binding,that way when a bearing fails/locks up it wont spin in the hub/knuckle rendering that part useless
it would take a company like xray to start the ball rolling on that one for the others to follow
Old 04-22-2014, 11:45 AM   #1710
metalnut's Avatar
R/C Tech Elite Subscriber
Trader Rating: 36 (100%+)
Sorry to derail the 2015 conversation, but I have a 2013/14 question
Do you guys use the stock o-rings in the bottom of your shocks? Do you use the stock membranes?
Even using green slime, I get some oil leaking from the bottom of the shocks. Not horrible, but a little. Also, my stock membranes swell up so much that it's next to impossible to rebuild the shocks properly. I switched to RSD bladders and those swell as well, but do to their design it's still possible to re-use them and squeeze them in. Unfortunately this doesn't result in a dead shock, but the slow rebound is something I can live with.
Just looking for some "best practices" that I may not have found while searching this thread. Thanks!
- Ricky Bobby
SEO by vBSEO 3.5.0
