Old 03-28-2014, 09:32 AM   #1636
Xpress's Avatar
Originally Posted by jlfx car audio View Post
If any of u guys have bought longer turnbuckles for ur camber links what would/did u get
stock length is 26mm long and need (want) some 30mm just incase I need to run long links in rear.
would be nice to use same wrench for these and others on car .
yokomo has some cheap
lunsford
their was a few others brands I seen as well but not aure of the wrench size
any suggestions
Xray 302615
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
Old 03-28-2014, 10:15 AM   #1637
jlfx car audio's Avatar
Trader Rating: 35 (100%+)
Tks . Ralph told me about those . Was looking to keep them aluminum or Ti. Cause im not sure what the weight difference would be .
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 04-03-2014, 12:36 PM   #1638
Trader Rating: 30 (97%+)
anyone use the aluminum chassis, and how does it handle compared to the carbonfibre one,
zaraz is offline   Reply With Quote
Old 04-03-2014, 01:27 PM   #1639
I have. It's all depends what your looking for.
I can see why it was designed for high traction carpet. It seem's to slow the initial reaction slightly, but makes it get deeper into the corner, and being narrower than the carbon, but 40 grams heavier, it really lets the car go fast through the corner giving a nice feel while planting it down. does make the car smoother and easier to drive, but this is only on high traction.
I think in low traction you would lose to much corner entry.
I raced it on very smooth med-high ashfelt. it was good, but I really felt the extra weight and it was not the feel I was looking for on this particular track. My times were around .2-.4 seconds slower.
However, after the race, for knowledge, I took the top deck completely off, and my!!!
the car was amazing! within a few laps I hit my fastest lap by .2 secs but it was so easy to drive!
And good as it felt like that, I only did it for one pack as I was worried about the belts possibly striping ( although maybe it wont!)
I let a local fast guy have a go and he smashed the lap record on his 2 lap.
go figure!
Andrew S is offline   Reply With Quote
Old 04-03-2014, 01:31 PM   #1640
thanks, I just got a t4 2014 in a trade, wanted to try out the aluminum chassis, so will order it and see how it works for me
Old 04-03-2014, 10:54 PM   #1641
Originally Posted by chasingthepack View Post
i dont get how if they are made from SPRING steel that they snap,and they always go in the same spot,i mostly race on a large open track so having the ecs isnt as important,but ill be racing at (imo) the most technical track in the uk in a few weeks so ill have the ecs in by then
Yeah not sure what constitutes calling something spring but i have seen very stiff springs allmost shatter when pushed past a certain point of deflection. So what is the final concencus on which shafts are best for the front spool? It seems some are happy with stock xray parts, others as is thier want go for aftermarket bits. Should i get some outdrives and shafts as spares? Seems like they break pretty regularly.....
Fly'n Fish is offline   Reply With Quote
Old 04-04-2014, 01:29 AM   #1642
Skiddins's Avatar
I would always have a supply of outdrives ready.
Standard Xray shafts are Ok, but if you do really want ESC style I would go aftermarket as the difference in cost is huge (can also use aftermarket outdrives)
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 04-04-2014, 11:25 AM   #1643
chasingthepack's Avatar
the outdrives,are they known to be weak? i ask as i havn't had a failure yet,only broken the ecs twice,the std shafts just dont break,but do get sloppy
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 04-04-2014, 02:55 PM   #1644
rcmax2's Avatar
We have been racing Xray cars about 4 years now and we have broken the front pins twice and bent the front drive shafts may be 10 times and have the pins work free if I have not put the flat spot inveigh to the grub screw but I find there ecs to be very good quality and I know that thay are more expensive than over brands but I find them value for money .
Xray T4/15 XB4 Northen Beaches Hobbies HEI Walter Hobbies / Castle Hill Raceway
rcmax2 is offline   Reply With Quote
Old 04-04-2014, 11:20 PM   #1645
B00t13g's Avatar
R/C Tech Elite Subscriber
They are all I run and prefer them over any other brand.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 04-06-2014, 04:28 PM   #1646
Trader Rating: 13 (100%+)
Questions?? Help needed
I'm looking for the Xray Aluminum chassis. If anyone has one for sale or knows which US shop has them in stock let me know.
Thanks.
https://www.gofundme.com/ncontrol
Joe Maxey is offline   Reply With Quote
Old 04-06-2014, 04:56 PM   #1647
vabroom's Avatar
Good luck, usually Europe gets items first, then Asia and finally the States.
RC racing is still trying to prove that two solid objects can be in the same place, at the same time.
vabroom is offline   Reply With Quote
Old 04-06-2014, 05:49 PM   #1648
Trader Rating: 22 (100%+)
Thanks.
check out APEX PRO R/C Shop
http://www.apexrcproshop.com/index.p...y&path=146_166
They had them earlier this week.
TEAMORCA.SHOP
MDawson is offline   Reply With Quote
Old 04-06-2014, 05:57 PM   #1649
masterhit's Avatar
Trader Rating: 15 (100%+)
Thanks.
Discount RC Store here in Michigan had them in stock. A couple of their guys were up for a big race last weekend at our track and were sporting them.
*edit* they sold their last one this weekend and can have more in a week or so....
Mike
masterhit is offline   Reply With Quote
Old 04-06-2014, 06:06 PM   #1650
vabroom's Avatar
LOL, guess I don't know what I'm talking about.
Masterhit, was the track carpet or asphalt and how did the chassis perform?
