Old 03-25-2014, 03:00 AM   #1606
Originally Posted by Odin544 View Post
I use X-ray oil and they still swell.
+1
it doesn't matter what brand of oil silicon oil will swell silicon o ring,seal etc
if you want o rings that don't swell you need the o rings made of epdm
ARC R10/2015 - HOBBYWING - PROAMPS - ORCA
BRCCC
elche_83 is offline   Reply With Quote
Old 03-25-2014, 03:13 AM   #1607
That would be just about perfect then. I have to add 40-50 grams just to make minimum weight. Has anyone tried it in lower traction conditions?
Also what kind of changes to setup are you guys having to make when you switch?
Hey Odin and others, where are you putting the 40-50grams in the car. I set my car up and I found it was pretty well balanced left to right but I needed all the extra weight basicaly in line with the servo horn. I custom made a pancake of lead that fitted exactly into that are and got front rear balance perfect but I am wondering where other guys have the weight... thanks!
Fly'n Fish is offline   Reply With Quote
Old 03-25-2014, 03:17 AM   #1608
Originally Posted by elche_83 View Post
+1
Interesting! Is this a fact? I am trying to imagine how rubber absorbs oil, but I guess it is an organic substance. Anyone have any technical insight on this subject? There must be a rubber engineer on this forum somewhere
Old 03-25-2014, 03:49 AM   #1609
Skiddins's Avatar
Interesting, I use Xray oil and my bladders are fine for months at a time
+1
The bladders in Xray shocks are not silicone
Xray T4'16, T4'14 (Wet Car)
Xray X12 2016
Xray X1'16
RCDisco.co.uk
Old 03-25-2014, 04:11 AM   #1610
100% fact, im not sure what the bladders are made off i dont have a issue with the bladders or o rings as well
BRCCC
Old 03-25-2014, 04:22 AM   #1611
morgoth's Avatar
Originally Posted by chasingthepack View Post
can you recommend a set that last more than 3 meetings?
i do prefer them but ive broken 2 shafts and the repair cost put me off
I know... The Xray ones are rubbish. I have the RSD wide axle shafts (52mm) and I'm very happy with them.
I've also heard good things about the Roche shafts, but I think they are 51mm (the 51mm RSD version is also available).
Serpent BeNeLux teamdriver // FX Engines // Nitrolux fuel
My blog: http://scrubbingspeed.wordpress.com
morgoth is offline   Reply With Quote
Old 03-25-2014, 09:51 AM   #1612
Trader Rating: 27 (100%+)
A lot of guys buy a 30g center weight which adds weight straight down the center line of the car
Xray | Airtronics | R1Wurks LiPo | Hobbywing
hyujmn is offline   Reply With Quote
Old 03-25-2014, 10:09 AM   #1613
locked's Avatar
yup. I just have a couple of T4 '13, but both have the 30g center weight. Makes the battery fit a little tighter, so you do want to be careful that it's not tweaking the chassis when you strap your battery in.
On one of my cars I have 83g of extra weight added to just barely make the 1380g minimum we have here. It's not easy finding good places for it all without messing up the left/right balance. It would be nice if they made a center weight out of tungsten.
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 03-25-2014, 12:58 PM   #1614
chasingthepack's Avatar
drop an o ring into some motor cleaner and wait 5 minutes,the o ring will swell to 3 times it size and still keep swelling ,ive seen people wash there shocks with motor cleaner,utter madness i know your were refering to silicon oil but i have had the same bladders for 2 seasons and they havent swelled at all ,i also have a set of cso shocks and they have clear bladders and they haven't swelled either
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 03-25-2014, 01:16 PM   #1615
i dont get how if they are made from SPRING steel that they snap,and they always go in the same spot,i mostly race on a large open track so having the ecs isnt as important,but ill be racing at (imo) the most technical track in the uk in a few weeks so ill have the ecs in by then
Old 03-25-2014, 02:24 PM   #1616
morgoth's Avatar
Yes I know. I have the same problems with the xray ones. I was driving at a high grip carpet track this winter and I had a shaft snap after 5 minutes of driving without hitting something... I think I had one break every month and I don't crash a lot.
The RSD ones hold up much better and are they are half the price.
Old 03-25-2014, 03:33 PM   #1617
The Spec-R v2 universal swing shafts are just as good as any. The clips seem to be the same ones that Christian uses on the RSD ones
Old 03-26-2014, 03:18 AM   #1618
The durability of the Xray is one of the key reasons why I run one, I have never broken a shaft, nor seen one broken but have seen many big hits.
I wonder if there was a bad batch of shafts and you were unlucky enough to get some or there is some other issue with your car or your esc settings? I have seen a few speedo's that momentarily put the motor in reverse while appling the brake.
Bb
bucketboy is offline   Reply With Quote
Old 03-26-2014, 06:10 AM   #1619
Trader Rating: 20 (100%+)
Spec-R v2 has been the most durable for me. Two full years on mine, running mod outside and banging boards in 17.5 inside and they are still fine.
I broke one Xray at the coupling not very long after owning them so they are off the table for me. I can't spend more than 2x on them and have them break that fast.
I do have a set of RSD shafts now as well. They look very nice but I don't have much run time on them yet so I can't comment on how long they will last.
www.teamgravityrc.com
Leisure Hours Raceway
Troy Carter is offline   Reply With Quote
Old 03-27-2014, 02:13 AM   #1620
morgoth's Avatar
Bb
Not sure what's the problem with them but they always break at the same spot. My speedo doesn't have reverse enabled. I run mod (4.5T-5.0T) indoors on carpet. Maybe it are the plastic outdrives that cause this? I thought the plastic outdrive would protect the shafts in case of a crash. But they develop slop so fast, that they cause hard hits on the drive shaft when braking/accelerating. Maybe that's the reason?
I think if xray would go back to 1.6mm pins and capture them instead of using a grub screw, all problems would be gone.
