Old 03-18-2014, 03:48 AM   #1561
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Originally Posted by ChadB. View Post
Do you use these same positions when running on asphalt?
I run on Asphalt 99% of the time, so yes. I don't think it really matters on which surface you race on, you will probably use the same body positions.
Antoni Caretti
Team Schumacher - Team Scorpion - Sweep Racing - Bezerk RC - Adelaide RC
Yokomo_Ant3 is offline   Reply With Quote
Old 03-18-2014, 08:30 AM   #1562
Trader Rating: 12 (100%+)
Was wondering if others have had issues with the screw to hold the t4's hubs not tightening? It isn't even stripped as it doesn't seem to grab in the first place. Seems like all the hubs screw holes were machined too large.
Is it overcome using different screws or a different set of hubs?
I thought I read it within this thread but can no longer find it in a search.
J-PaP is offline   Reply With Quote
Old 03-18-2014, 09:22 AM   #1563
Odin544's Avatar
Trader Rating: 93 (100%+)
If you are referring to the aluminium hex, then yes different screws usually fixes the issue.
TriCitiesRC.com
Old 03-18-2014, 12:09 PM   #1564
I tried searching this thread but couldn't find any info.
Kit went together fine however I have one shock bladder that is deformed and I can't finish the kit until I get a new one.
Anyone of you fellas have Paul's (is this the correct gentlemen?) contact info to see about a replacement?
homerthefourth is offline   Reply With Quote
Old 03-18-2014, 12:46 PM   #1565
If u are in the US contact rcamerica.com and speak to Ralph or one of the other reps and they will help u.
lk2849 is offline   Reply With Quote
Old 03-18-2014, 01:41 PM   #1566
Ah yes.
Now I see. Thanks for the help.
Old 03-18-2014, 03:48 PM   #1567
cneyedog's Avatar
Send a message via AIM to cneyedog
I looked over the Hudy setup book and im still confused, when you move the inner hinge pins away from the chassis, is this lowering or raising the roll center ? ....... which is better on a high bite asphalt track ? ...... thanks for any help
cneyedog is offline   Reply With Quote
Old 03-18-2014, 03:57 PM   #1568
Moving the pin away from the chassis raises the roll center. You're better to lower the roll center in high grip situations.
Lycan is offline   Reply With Quote
Old 03-18-2014, 05:29 PM   #1569
so has anyone given the alu chassis a good run yet?
What were your finding's??
Andrew S is offline   Reply With Quote
Old 03-18-2014, 06:39 PM   #1570
Trader Rating: 306 (100%+)
Where do they sale the chassis?
Jermaine Mitchell
I laugh at serious racers acting like B****
Free Agent racing team. No sponsors needed.
Mercenary Racer
jmoneym is offline   Reply With Quote
Old 03-18-2014, 07:19 PM   #1571
TimmyMontoya's Avatar
The store in my sig sells them and has 2 left in stock! I have used the chassis and I love it! Makes the car more stable, more consistent, easier to drive!
DiscountRCstore.com new distributor of Xray and Hudy
Xray, Hudy, Schumacher, Fantom, Orca
TimmyMontoya is offline   Reply With Quote
Old 03-18-2014, 07:24 PM   #1572
Trader Rating: 27 (100%+)
Couple of guys at my local track spent a few days testing the ALU chassis on carpet. Our top guy is a consistent A-mainer at Roar and national events and even won in 2012.
He went faster with his ALU chassis and said it was easier to drive. He's gonna keep using it, I believe.
Xray | Airtronics | R1Wurks LiPo | Hobbywing
hyujmn is offline   Reply With Quote
Old 03-18-2014, 07:48 PM   #1573
Good to know.
Just bit the bullet on one.
I race a very smooth, med - high grip indoor ashfelt track.
I know they say it was designed for carpet, but I think it will work well on our track.
Old 03-18-2014, 09:37 PM   #1574
Khador12's Avatar
Apex has them in stock.
http://www.apexrcproshop.com/index.p...roduct_id=2054
Xray T4 14
VBC Firebolt DM 2wd buggy
Khador12 is offline   Reply With Quote
Old 03-19-2014, 03:21 AM   #1575
Originally Posted by Yokomo_Ant3 View Post
The LTC-R is run the lowest on the front out of all of the shells. For example on my car, I use rubber O-rings on the front to adjust the height of the body (same as a diff o ring).
I use no O-rings for the LTC-R, 2 each side for a GX and 3 Each side for a speed 6. Also Alex's shells are very far forward, I personally like mine a bit further back.
LTC-R: 77mm
GX: 74.5mm (this is the same as Alex)
Speed 6: 72.5mm
HTH
Antoni
Thanks for that Antoni, could you please tell me which hole you have the front and rear support pins in? The o-rings are a good idea. I use a bit of thin foam tape in different layers but the orings are a nicer solution for sure.
Fly'n Fish is offline   Reply With Quote
SEO by vBSEO 3.5.0
