Old 03-14-2014, 01:51 PM   #1546
ronP617's Avatar
Thanks guys
ronP617 is offline   Reply With Quote
Old 03-14-2014, 01:52 PM   #1547
Warren Weaver's Avatar
Trader Rating: 46 (100%+)
Originally Posted by jlfx car audio View Post
Lightspeed is amazing gears. U can het them thru EAmotorsports. Fast shippimg also.
serpent and prs also make spurs that fit but not sure if either of those r 48p
Those are Leespeed and EA does carry them
R1 WURKS-AWESOMATIX USA-LRP-BITTYDESIGN-TQ WIRE-PROTOTYPE RACING-SWEEP RACING-TXDSKINGRAPHIX-HOBMAX-THE RUG-TEAM EZDUZIT
R.I.P. MY FRIEND JDUB MISSED BUT NEVER FORGOTTEN
Warren Weaver is offline   Reply With Quote
Old 03-15-2014, 05:50 PM   #1548
Originally Posted by Skiddins View Post
Alex Hagberg posted this on the Xray forum;
This is how I measure it. The center of the body post to the bottom edge of the front windscreen. I usually mount my body quite a bit forward for more steering overall. I use these measurements:
LTC-R: 74.5mm
SP6: 71
GX: 74.5
Damn, I have another question about the LCTR body on the T4 '14..... how high should it be? Does someone know how many holes up the post the support for the LCTRs are on Hagbergs car. I put mine on the same height as for my speed6 mazda protoform body and it looks a bit high.
thank you
Fly'n Fish is offline   Reply With Quote
Old 03-15-2014, 06:58 PM   #1549
Send a message via Skype™ to martinskarin
thank you
The roof line should be no lower than 115mm from the ground when fitted on the car. The wing cannot be higher than the roof line nor hang over more than 10mm in the rear.
That's common for most races I think.
I noticed the same Mazda gx is lower than ltcr so leave one hole on the posts when you cut them.
Martin Skärin
Shanghai
Roche
Destiny
PROAMPS
martinskarin is offline   Reply With Quote
Old 03-16-2014, 06:36 PM   #1550
Thumbs up
2014 Canadian On Road Nationals Report from Welland Ontario.
Congratulations to Paul for his MOD TC TQ. Thanks for coming.
Congratulations to Rob Say for his Stock TC TQ and dominate win with his Xray. Stock TC had 81 entries.
Number 49 Lou's Speedway Canada, Honda House www.hondahouse.com
ElliotCanada is offline   Reply With Quote
Old 03-16-2014, 11:30 PM   #1551
alecladanga's Avatar
as suggested by others
Lightspeed
Panaracer
and
Spec-R
HPI
Xenon
the modification to fit other "thick" spur gears is to sand the spur gear spacer (I used 200-300 grit to fit a RW spur gear).
But you wont go wrong with any of the brands above
Old 03-17-2014, 01:10 AM   #1552
daleburr's Avatar
thank you
I drop the front 2 holes from the speed6 position. Rear stays where it is. Then just trim the bottom of the shell if it drags.
Team Xray
Old 03-17-2014, 07:50 AM   #1553
ronP617's Avatar
Hey guys, what are good gear ratios for 13.5? Running on med sized track.. How do you determine what size spur to use for what size track?? Have any info on gear setups to read on?
Old 03-17-2014, 09:38 AM   #1554
daleburr's Avatar
Boosted or blinky? Boosted around 6.5 FDR, blinky more like 4.5 FDR.
Once you've chosen your FDR you can choose the pinion/spur using the table here:
The New Xray T4 '13
If running 48dp then choose a spur/pinion combo that adds up to around 110 teeth; this will put the motor in the centre of the mounting holes and give loads of adjustment for gearing up/down.
Team Xray
Old 03-17-2014, 10:51 AM   #1555
Team EAM
EAMotorsports's Avatar
Trader Rating: 78 (100%+)
Send a message via AIM to EAMotorsports
Lightspeed
Panaracer
and
Spec-R
HPI
Xenon
Its LEESPEED. There is no Lightspeed gears.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | ProSpec America | Killer Concepts | AVID.
EAMotorsports is offline   Reply With Quote
Old 03-17-2014, 02:15 PM   #1556
ronP617's Avatar
The New Xray T4 '13
It's for 13.5 blinky
T4'14
Old 03-17-2014, 02:26 PM   #1557
Trader Rating: 13 (100%+)
T4'14
I run on a 120' x 60' and I run 100 spur and 44 to 46 pinion.
https://www.gofundme.com/ncontrol
Joe Maxey is offline   Reply With Quote
Old 03-17-2014, 04:28 PM   #1558
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
thank you
The LTC-R is run the lowest on the front out of all of the shells. For example on my car, I use rubber O-rings on the front to adjust the height of the body (same as a diff o ring).
I use no O-rings for the LTC-R, 2 each side for a GX and 3 Each side for a speed 6. Also Alex's shells are very far forward, I personally like mine a bit further back.
LTC-R: 77mm
GX: 74.5mm (this is the same as Alex)
Speed 6: 72.5mm
HTH
Antoni
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 03-17-2014, 08:26 PM   #1559
ChadB.'s Avatar
Trader Rating: 21 (100%+)
LTC-R: 77mm
Speed 6: 72.5mm
HTH
Antoni
Do you use these same positions when running on asphalt?
Chad Burdick
*Mugen Seiki*Flashpoint Racing Products*9th Annual Timezone Grand Prix July 13th-16th 2017*Unique Air Design*TimezoneRacing*RoseCityScaleRacers* Daves RC Track
ChadB. is offline   Reply With Quote
Old 03-17-2014, 10:51 PM   #1560
EA
Thanks for the correction EA! Didnt notice that!
