Old 03-12-2014, 02:00 PM   #1516
Moderator
Clegg's Avatar
If anyone is looking for a T4 2014, PM me, I have one with ECSs, carbon arm stiffeners, and Front diff I am looking to sell.
Joe Kelly - JK720.net
5280 Raceway |5280raceway.com | 5280 Raceway Facebook
Clegg is offline   Reply With Quote
Old 03-12-2014, 08:10 PM   #1517
Default mounting an LCTR body: F R positioning question
Hi all,
Am I right in assuming that the front wheels should be in the centre of the front wheel cutouts in the Protoform LCTR body? I run my '14 on medium traction asphalt modified, medium speed kind of layout.
Also, any tips for the wing setup? Forward position, back, cut down??
Thank you
Fly'n Fish is offline   Reply With Quote
Old 03-13-2014, 03:15 AM   #1518
Send a message via Skype™ to martinskarin
Originally Posted by Fly'n Fish View Post
Hi all,
Thank you
There's a recent post with picture answer from Alex in the Xray forum.
My position is with the wheel to the back of the cutout (more forward mounted body) I tried center mount but think it lacks steering. However both works depending on grip level etc.
Martin Skärin
Shanghai
Roche
Destiny
PROAMPS
martinskarin is offline   Reply With Quote
Old 03-13-2014, 03:43 AM   #1519
Trader Rating: 57 (100%+)
This post http://forum.teamxray.com/viewtopic....33d19d1d16dc96
The first picture is mine, shown from the center line of the wheel opening. It is the same as Alex has posted below just a different view. (74.5mm from windshield line)
PROMODVETTE is offline   Reply With Quote
Old 03-13-2014, 03:44 AM   #1520
Skiddins's Avatar
Hi all,
Thank you
Alex Hagberg posted this on the Xray forum;
This is how I measure it. The center of the body post to the bottom edge of the front windscreen. I usually mount my body quite a bit forward for more steering overall. I use these measurements:
LTC-R: 74.5mm
SP6: 71
GX: 74.5
Xray T4'16, T4'14 (Wet Car)
Xray X12 2016
Xray X1'16
RCDisco.co.uk
Old 03-13-2014, 03:45 AM   #1521
Skiddins's Avatar
Out of interest, what car have you changed to?
Xray X12 2016
Xray X1'16
RCDisco.co.uk
Old 03-13-2014, 09:19 AM   #1522
erchn's Avatar
LTC-R: 74.5mm
SP6: 71
GX: 74.5
Well, that's interesting. My typical mount is about 4 to 4.5mm back from that, closer to body flush with RSD bumper, I should try this. Can anyone speak to the difference it makes and where (i.e. low speed, sweepers, etc...)? I suspect mostly in the higher speed sections.
Serpent ; Desoto Racing ; Team Powers USA ; Reflex Racing ; Bezerk RC
Old 03-13-2014, 10:37 AM   #1523
Originally Posted by chasingthepack View Post
itll be interesting to see how that affects the handlng,whats the weight of it?
It's 3.8 gram. Haven't got the chance to try it at the track so i can't tell how it feels.
jack_lee is offline   Reply With Quote
Old 03-13-2014, 11:38 AM   #1524
CristianTabush's Avatar
Trader Rating: 11 (100%+)
My take on it is the fact that by moving the body forward, you are essentially making the rear overhang of the car shorter (and the wing come forward as well). This should allow for the car to rotate much quicker in the middle to the exit of the corner. In contrast, the longer front should make the car have a smidge more turn-in, but it will have a harder time coming back to center due to the increased inertia of the body.
In a perfect world, I guess if I were designing a body, I would make a shorter front overhang with more downforce and a shorter rear overhang for more rotation. This would allow for quicker rotation (from less overhang in the rear) and quicker direction change from a shorter front end.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is online now   Reply With Quote
Old 03-13-2014, 01:20 PM   #1525
I would suspect, that mounting the Body more to the front changes the Downforce distribution between front and back towards less rear df and more front df. In rc words: more steering. Especially in high speed turns.
Worst87 is offline   Reply With Quote
Old 03-13-2014, 04:17 PM   #1526
Clegg has photos off the xray for sale and what I assume to be the replacement awesomatix on his website....
Old 03-13-2014, 04:27 PM   #1527
LTC-R: 74.5mm
SP6: 71
GX: 74.5
Thanks skiddins. Alex Hagberg, I guess he knows what he is on about so I will go with that
Old 03-13-2014, 04:56 PM   #1528
Does anyone have the exact spacings for the body posts handy. If Alex Hagberg has given us the front overhang then just need to get the body post spacing to finish the job perfectly. I could measure them but it won't be as neat as having the exact spec, precise kind of work. Also I am wondering how accurate my body reamer is, I mean if you ream from a spot is it exactly centre of should I make a cross hair to make exactly sure. I know I can put a bit of pressure on a side to get it to run that way....
Old 03-13-2014, 05:09 PM   #1529
Dadaman's Avatar
Trader Rating: 20 (100%+)
Does anyone know where I can get a good explanation of the new roll centers on the '14? The old setup book only still covers a pretty old model.
Xray XB4 '16
Yokomo Dogfighter YZ-10 870c
Xray T4 '14
Dadaman is offline   Reply With Quote
Old 03-13-2014, 06:08 PM   #1530
How many cutting blades does your reamer have? I have a single blade dynamite that doesn't stay centered well, and I have a TRF one with two blades that seems to center nicely.
-Mike
