Old 02-25-2014, 01:38 PM   #766
nrtv20's Avatar
Do you need to add spacers to your steering rack? Do you have extra spacers under the arms?
http://www.trautengineering.com/ http://www.toledooneeighthracers.com/
http://www.youtube.com/user/nrtv20
One Eigth Racers of Toledo; Hobby Stop West Track; "The Gate" NORCAR
FUTABA 2.4G FASST, Spec-R S1, Speed Passion SP-1, Sakura D3 FWD, Kyosho Evolva M3, Team Losi XX-4, Caster EX1.5R, HPI Wheelie King Crawler, Quanum Aquaholic, Joysway Wildcat
nrtv20 is offline   Reply With Quote
Old 02-25-2014, 04:24 PM   #767
Norman2's Avatar
Originally Posted by dcs155 View Post
What was the name of the decal place in Hong Kong?
Hi. The name of the hobby shop is R2 Hobbies HK. Look under Decals and find
WRT Audi R8 Drift Car decals. I thingk they are 11.88 but you will have to wait
about ten days. I will post a photo soon for you. Regards
Norman
On the Top of the page in the search box under accessories for cars look for decals and find the ones for WRT Drift Speedhunters decal set. Attached
photo. Hope this helps. Regards
Norman
Speed Passion brand new Spec Racing LeMans car - The LM1-r2-hobbies-decals-wrt-audi-drift-car.jpg
Norman2 is offline   Reply With Quote
Old 02-26-2014, 12:38 AM   #768
Norman
Norman
I've been looking at some of these stickers and kept wondering about the quality. How do they compare with the Tamiya stickers?
salvine is offline   Reply With Quote
Old 02-26-2014, 06:23 AM   #769
Originally Posted by Rich Valente View Post
Sorry if it has been covered earlier...I am having problems with the steering linkage 'hanging up/getting stuck' when turning. It is getting caught on turnbuckles (see enclosed pic in the red circle area).
Is there a fix or did I mess up something during assembly?
Thanks,
-Rich
You will have to add the same amount of additional shims under the steering posts that were added to the arm mounts.
I added 2mm of shims to compensate for the additional shims I put under the arms.
Team Novak,Gravity RC,
ercwhtsd is offline   Reply With Quote
Old 02-26-2014, 06:48 AM   #770
Norman2's Avatar
Hi, These decals are just as good as Tamiya's. Regards
Norman2
Old 02-27-2014, 06:06 AM   #771
celt's Avatar
Thanks,
-Rich
A simple way to look at it;
Kit height calls for 4mm (2x2mm) shims between the ride height plate and the arm.
For every mm shim you add, simply add that shim also, to the bottom of the steering posts.
All you are doing is keeping the steering system in the same plane as it's default location.
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 03-05-2014, 10:19 PM   #772
Cgolf's Avatar
Hey all just putting my car together and wondering if you all sand the center hole of the spur gear to allow the diff to work properly or does it wear in?
Chris
Cgolf is offline   Reply With Quote
Old 03-06-2014, 05:25 AM   #773
celt's Avatar
Chris
Chris, correct...
Just take a pinch of with a reamer or similar.
Stan Garvin
Old 03-06-2014, 08:05 AM   #774
JLock's Avatar
Does anyone here know how wide the front and rear foam tires are for this car?
Texas 5
It's not what you know; it's what you can prove.
The only thing that is for sure is that nothing is for sure!!!
The needs of the many outweigh the needs of the few, or the one.
There are 2 things in life that are infinite: the universe and stupidity.
JLock is offline   Reply With Quote
Old 03-06-2014, 08:47 AM   #775
liljohn1064's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to liljohn1064 Send a message via MSN to liljohn1064 Send a message via Yahoo to liljohn1064
Originally Posted by howardcano View Post
Rears are 39.6mm wide, fronts are 30.5mm. Yes, that's narrower than the old pancars, but reflects the current trends in full-sized racing cars. CanAm and 70's F1 cars had huge rear tires!
Here you go!
John Higgins
liljohn1064 is offline   Reply With Quote
Old 03-06-2014, 09:45 PM   #776
Cgolf's Avatar
Is the 10 degree castor block a good starting point as shown in the directions?
Also hit a sticking point with the kingpin pivot balls on the front lower arms. Even without the screws in the arms the pivot balls were not very free. How do you free these up. It binds up the steering.
In the directions they show 3 mm from back of arm to bottom of kingpin for spring load. Picture shows a lot of spring, while reality you see very little spring at 3mm, is this value right?
Cgolf
Old 03-07-2014, 06:59 AM   #777
Cgolf
Run the 5* caster block, all shims back.
Those lower pivot balls really are snug. With the ball in the lower arm, slip in the kingpin and press arm to the ball a couple times with a padded pliers. Rotate the ball and repeat a couple times to form the arm around the ball. Another trick is to put a mild abrasive in, like tooth paste and spin the ball in the arm with a hand drill, then rinse and oil with very light machine oil.
Spring preload: Ignore the instructions. Put the king pin in until the spring touches the lower perch and is not floating free. Adjust preload and front droop from there. 3mm is too tight. It should be more like 4mm to start. Droop should be in the .5 to 1mm range.
John Higgins
Old 03-07-2014, 03:38 PM   #778
Cgolf's Avatar
Turns out when I took it apart it is the steering pivot ball in the steering upright. Working it by hand loosened it a lot, it should work in with running, or so I hope. Thanks for the info
Old 03-07-2014, 10:27 PM   #779
wholeshot's Avatar
Default things have changed.
so after a recent trip to my local hobby store that advertized they had two carpet tracks .............. ( i took a 4 year hiatus from the hobby been doing this for almost 20 years now)
there i was sitting in a room with about 20 people at benches with all these blinged out aluminum and carbon fiber cambered out plastic wheeled cars.. that slide around at about 2mph .. and im sitting there thinking to my self like .. " so this is it .. this is cool now"..."wow none of these people know how to drive"
there is no scene .. where i live to my knowledge and i want one of these cars to race with in a class so bad
wholeshot is offline   Reply With Quote
Old 03-07-2014, 10:29 PM   #780
wholeshot's Avatar
one thing i wanted to ask about the lm1 is that the body .. are there certain parts held together by double sided tape or do you use a screw and bolt ?
SEO by vBSEO 3.5.0
