Old 12-20-2013, 12:14 PM   #466
trackdesigner71's Avatar
Send a message via AIM to trackdesigner71 Send a message via Yahoo to trackdesigner71
I posted this in the LMP1 discussion but I wanted to ask it here since it best fit this segment:
What do you think of having LM1/LMPC serve as kind of an entry level class and have performance markers for racers in order to move to the more open LMP1 class. One Idea I threw out in the other thread was having the track champion (maybe top 3 or 5 in points) promoted to the full P1 class the next season. Ideas?
trackdesigner71 is offline   Reply With Quote
Old 12-21-2013, 05:38 PM   #467
gsxr0311's Avatar
Trader Rating: 18 (100%+)
one more video of my LM-1. Once again low grip but drivable.
http://www.youtube.com/watch?v=SfpRpkcieww
Special Thanks to: RC Target, Ko Propo USA, O'Donnell glow plugs, A Main Hobbies-SWORKz USA, R1 Wurks, and Absolute Hobbies.
Capricorn: LAB-C802, LAB E801, LAB-C03, TE03, and P01 235mm. SWORKz: S350BK1 EVO II, S104EVO, S12-1M. Top Rebel 12.
gsxr0311 is offline   Reply With Quote
Old 12-21-2013, 05:56 PM   #468
celt's Avatar
Default wow...
I can't imagine running on a track like that.
http://www.youtube.com/watch?v=Q5FFaUj_t8Q
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 12-21-2013, 09:07 PM   #469
NutDriver's Avatar
Trader Rating: 14 (100%+)
Man, I gotta spend some time building mine tomorrow. Wonder if I can give folks IOU's in lieu of Christmas gifts?
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 12-22-2013, 02:07 AM   #470
howardcano's Avatar
Trader Rating: 35 (100%+)
That works okay for a while, but they start to catch on after you do it for the third year in a row when you still owe them for the first.
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 12-23-2013, 07:05 AM   #471
liljohn1064's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to liljohn1064 Send a message via MSN to liljohn1064 Send a message via Yahoo to liljohn1064
I'm waiting on 16ga wire. Sad but true, the local shops don't keep it in stock. Nothing like pre-soldered wires 2" shorter than you want them. I still have to paint, nothing like dragging my feet.
John Higgins
liljohn1064 is offline   Reply With Quote
Old 12-23-2013, 07:10 AM   #472
We can dream Stan.
John Higgins
Old 12-24-2013, 10:18 AM   #473
I'm thinking, as I cut out my first LMA body, that if I leave the forward section of the tail long, I can cut a notch out of top and turn it into a tab once the pieces are joined, then cut a slot in the back of the cockpit where the tail would normally touch and slip in the tab before sticking it down to the main body. It closes up the gap in the standard fitting and gives the tail an additional anchor to the body.
Good idea/Bad idea?
John Higgins
Old 12-24-2013, 11:11 AM   #474
Post pics once you are done John...what do you think of my idea at the top of the page?
Old 12-24-2013, 11:16 AM   #475
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Good idea/Bad idea?
Just use shoe goo to hold it on then it wont go anywhere.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 12-24-2013, 11:48 AM   #476
I always think that if you have the skill you should advance and at least be competing with drivers at or above your skill level if you want to improve. I don't have an issue with this as our local race director sorts by talent for the first heat, then resorts on laps for the second and third. If we have 30 guys show up wanting to run this class, then maybe a second class is in order. Nationally, it would depend on how many cars register for a large event. I would not mind running this kit as a spec class until the backing and interest are in place.
John Higgins
Old 12-24-2013, 11:53 AM   #477
Without question on the shoe goo. Holds and stays flexible forever. I was thinking more for dress. I'm being picky. I just don't like the gap.
John Higgins
Old 12-25-2013, 09:52 PM   #478
I agree wholeheartedly. I will be saving my money and try to get one for this summer and get it shown at the outdoor track near my parents' house this summer, but I really think building the LM1/LMPC class is important at this critical juncture
Old 12-27-2013, 06:05 AM   #479
For giggles I put the carbon battery brace on with the spring perches in the wide position and moved just the pod side of the links to the wide setting. Then I put a 1 mm shim under the front link ball in the inner hole with a longer screw. Now I have angled links and still no binding, rubbing or pinching between the pod and the main chassis and no drilling. I've also added an extra 2 mm of spacers to the front plate and there seems to be enough thread to hold it, but a 2 mm longer screw should go in there regardless. Then I added 3 mm under each post with longer screws for the steering rack and went to the 2 mm rear height adjusters. The link ends were making a little contact with the lower A arm with the stock setting, now the steering is free for the full range of motion with the extra 1 mm. I'm at just over 4 mm in front and a tick over 4.5 in the rear for ride height. The center line of the motor is now under the center of the rear axle. All else is box stock.
John Higgins
Old 12-27-2013, 08:37 AM   #480
Trader Rating: 36 (100%+)
Yes Please!!!
Here is a shot of my car with old school M. Schumacher colors
Nice Kev.
That will look good in my fleet
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
