Like Tree8Likes
Old 11-25-2013, 07:59 AM   #256
Mr.juarez's Avatar
Trader Rating: 37 (100%+)
Drove mine yesterday but traction was not there so it was all over the place. Need to finish putting all the decals and try to take all the slop out of it. Going to order another body and replicate the real car or wait for paintlabs to do some.
texastc likes this.
TRF-417, KYOSHO SCR-SP
Mr.juarez is offline   Reply With Quote
Old 11-25-2013, 08:24 AM   #257
Solara's Avatar
Trader Rating: 16 (100%+)
Originally Posted by Ed Delgado View Post
I thought most 1/10 F1 cars were 270mm wheelbase. Hmmm...
Wheel base can be adjust on F1...at least on our Sp1 can be adjust.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 11-25-2013, 08:26 AM   #258
Solara's Avatar
Originally Posted by NutDriver View Post
How did lap time compare with F1?
F1 is 21.5....LeMan is testing on 17.5...can't compare. But of both running 21.5...you can tell the different is RUBBER TIRES vs FOAM TIRES...foam always faster.
Eric was running 9.3 lap, 4WD TC 17.5 stock = 8.3
Old 11-25-2013, 02:32 PM   #259
gsxr0311's Avatar
Trader Rating: 18 (100%+)
Originally Posted by ercwhtsd View Post
This one I believe has a 4mm ID versus the kit supplied 6mm. I changed to the 4mm ID today, much better and more consistent.
Niiiiice. Thanks for the info. I'll definitely do that.
Special Thanks to: RC Target, Ko Propo USA, O'Donnell glow plugs, A Main Hobbies-SWORKz USA, R1 Wurks, and Absolute Hobbies.
Capricorn: LAB-C802, LAB E801, LAB-C03, TE03, and P01 235mm. SWORKz: S350BK1 EVO II, S104EVO, S12-1M. Top Rebel 12.
gsxr0311 is offline   Reply With Quote
Old 11-25-2013, 02:38 PM   #260
mikel33's Avatar
Trader Rating: 2 (75%+)
The car looked to have a LOT of potential with foam tires and 17.5. Eric had not done a whole lot of set up work and the tires had not been trued. On trued tires and some time to develop the set-up these things should be rockets.
also, fastest TC laps were sub 8 seconds, not that it matters.
Michael Larson.
Village Idiot Racing
mikel33 is offline   Reply With Quote
Old 11-25-2013, 02:58 PM   #261
Mr.juarez's Avatar
I have no experience with foam tires but how do you prep or do you apply anything at all? Anyone can give or post sort of a set up or some sort for low traction track?
I put the included grease in the dampers went with 27.5 shock oil and included spring.
Old 11-25-2013, 03:58 PM   #262
robk's Avatar
Trader Rating: 22 (100%+)
1> apply Paragon from the white bottle, "FXII", let soak in , usually 10 -20 minutes
2> apply sunscreen over the Paragon, and let set until race. Wipe tires clean before you heat.
Old 11-25-2013, 04:37 PM   #263
gsxr0311's Avatar
I would first run it with no additive to see if it has good grip. If not I would apply full additive to the rear and 1/4 to the front. Then increase additive to the front as you need it. If you add too much too soon you could traction roll.
Old 11-25-2013, 04:57 PM   #264
NutDriver's Avatar
Trader Rating: 14 (100%+)
RobK,
Is there a particular brand/SPF/whatever preferred? I am serious in this question. I was out of RC for about 10 years and I recall that some folks have preferences.
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 11-25-2013, 05:19 PM   #265
gsxr0311's Avatar
White paragon is for rubber and black is for foam tire.
Old 11-25-2013, 09:00 PM   #266
Come on now. :-) I got a few 8.9's. Traction roll seems to be the issue now. I went with wide links at the front and CRC green springs at the pod. Change the rear tube to 300k and lengthend the shock by 3mm in the center hole. You will have to use a 2mm shim under the shock ball at the battery holder
It's better.
Team Novak,Gravity RC,
ercwhtsd is offline   Reply With Quote
Old 11-25-2013, 09:43 PM   #267
gsxr0311's Avatar
It's better.
did you traction roll with or without sauce? these tires seem pretty soft already. another option is to true the tires to a lower mm.
Old 11-26-2013, 07:35 AM   #268
robk's Avatar
RobK,
I just use generic 50 spf. White paragon is typical for asphalt but when it starts to get cold black can may work better.
Old 11-26-2013, 07:52 AM   #269
I have done it both ways. I settled on no sauce for the front and full for the rear. Ride height is a little high as well, so we will work on that sometime today.
At this point, tire wear seems to be minimal on carpet, it may be higher on asphalt.
For me, I always try and emphasize try, to run the kits as supplied first. It is hard to get someone to "buy" into a class when you tell them, "oh, by the way...", plus, I like the challenge
Old 11-26-2013, 07:56 AM   #270
Norman2's Avatar
Smile Speed Passion LM-1
Hi, Just got my body yesterday and had very minor problems in fitting it to
my Tamiya F104. I used Tamiya front bumper used in their Le Mans cars and
just spaced the mounting post a little farther apart. Also had to move the
antenna mount to make it easier for the exit hole. Presently painting Silver, Gun Metal Gray, and black and will use the Audi Bilstein Livery as they are the only decals I can get that I like. Will Post photos as soon as I get my tires. I am off
about 2mm on the wheelbase but it still will look good. Regards
Norman
Norman2 is offline   Reply With Quote
