Old 09-26-2013, 08:41 PM   #16
It may sound stupid but have you calibrate the throttle range for the esc yet? And when the motor stop at full throttle do you have any steering? If you do have steering in some very rare case the transmitter signal have gone pass the range the esc can read so it cuts off itself..... Try to calibrate the throttle again, if it does not work try to lower the throttle travel to around 80% and try to calibrate the throttle again..... Give it a try and hope it work...... If you donot have any steering at cut off it seems like something is overloaded..... Try higher C lipo and play with the gearing.
roche.hk is offline   Reply With Quote
SEO by vBSEO 3.5.0
