Old 03-16-2014, 03:58 PM   #91
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
If your'e in the States, use the contact info on their website and talk with one of their CS reps. They should be able to get you straightened out.
http://www.rcamerica.com/
AWD
Old 03-16-2014, 04:18 PM   #92
im in Australia. what do they do anyway, just give you more, or have they got an after market version?
Andrew S is offline   Reply With Quote
Old 03-16-2014, 05:27 PM   #93
Trader Rating: 57 (100%+)
I would find the xray distributor for oz. I googled it and come up with http://www.hobbyexpress.com.au/. Try to contact them and I'm sure they will get you squared away.
PROMODVETTE is offline   Reply With Quote
Old 03-16-2014, 06:45 PM   #94
Questions??
Originally Posted by tnewlon View Post
Hello all,
I am on the fence between this car and the serpent. Seems there is some issues with the pivot balls.
Would love feedback on pro and cons of this new Xray and if anyone has had any experience with the serpent. Thanks!!
I'm currently running the S120LTX for 17.5 blinky and is having trouble finding small enough spur gear. While PRS makes a 71T, it doesn't appear to be available. The Serpent has a pillow ball upper arm so camber adjustment does not require a different wrench. The servo mount is very close to the arm mount so you might have to modify the servo mounting ears. The body posts can be a bit tricky to thread but the fine adjustability is nice. You might have to do some modification to get the bottom pod plate to be leveled with the main chassis. It's as if they went to a thinner carbon fiber without updating the pivot mount. Manual is ok but not at the xray level. For 17.5 blinky, I'd probably go with an Associated 12R5.2.
I'm building a X12 2014 for mod and have completed the frontend. The composite bottom pivot ball makes for smooth kingpin movement. The top one can be tricky but there are ways around it. First, polish the kingpin. Second, put the kingpin in ice water. Third, if you still need more clearance, put the upper pivot ball in hot water. Assembly should then be smooth. I haven't seen it myself but heard from local racers that finding a small enough spur gear for 17.5 blinky will also be a challenge. I like that it has a thrust bearing for the diff. Great manual. Of course, one drawback is high parts price.
SpeedSecrets is offline   Reply With Quote
Old 03-17-2014, 07:44 PM   #95
tnewlon's Avatar
Trader Rating: 15 (100%+)
Thanks everyone!
After much thought, I have decided to go with the Xray. The fact that I have access to a factory Xray driver helps too!
This makes two Xrays and an Associated being ran out of my household (my two sons are learning to race!!
tnewlon is offline   Reply With Quote
Old 03-18-2014, 06:57 AM   #96
Skiddins's Avatar
Olly Jefferies in the last round of the UK BRCA nationals.
He qualified 1st;
+ YouTube Video
Setup sheet;
http://forum.teamxray.com/xform/inde...setup=x12_2014
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 03-29-2014, 03:07 PM   #97
I just ordered this car,it's my very first car from Xray so i'm very curious about the quality and how it handles.
addicted2blue is offline   Reply With Quote
Old 03-29-2014, 07:21 PM   #98
Car Breaker's Avatar
The metal pivot ball at the frint kingpin may be the only issue. Other than that, the kit should be perfect in quality. Get some spring and oil as the stock setup may not suit everyone
Xray X12 2015
ARC R10 ATS
Car Breaker is offline   Reply With Quote
Old 03-30-2014, 02:20 AM   #99
Would it help to install the graphite pivot ball instead of the metal one?
Or do they have a different size?
Do the side springs and the front springs from associated fit directly on this car or do i need other parts aswell to be able to mount the asso springs?
Old 03-30-2014, 06:06 AM   #100
Some people enlarge the hole in the metal pivot ball to fit kingpin in. Other replaced it with composite pivot ball. spring wise, you will need the older style or ae/crc spring hilder for other side spring. The front spring is about the same as ae. Crc front spring is too short
Xray X12 2015
ARC R10 ATS
Old 03-30-2014, 11:27 AM   #101
Thanks for the tips
Old 03-30-2014, 02:28 PM   #102
An AE side spring fits fantastically if you turn it upside down...
Old 04-06-2014, 01:35 PM   #103
Trader Rating: 21 (100%+)
I have about 1mm of up and down movement in the rearpod its coming from play in the pivotball for the pod. Anyone else notice this?
VA_Racer is offline   Reply With Quote
Old 04-06-2014, 01:48 PM   #104
you shouldn't have this much play in it.
Have you tried tightening all 3 screws and nuts on the pivot mount?
Mine are all done up tight, then I get no play.
Old 04-06-2014, 02:06 PM   #105
yep made sure they were all tight and still have the play
