New XRAY X12 All new 2014 >
Like Tree1Likes
Old 12-13-2013, 10:11 AM
  #61
Trader Rating: 70 (100%+)
Originally Posted by Andrew S
Loving the way my x12 drives! Impressive car!
Still getting the right gear combo for 13.5 blinky though!
I am up to 78 spur and 52 pinion for a roll out of 92 mm! Indoor ashfelt track.
Anyone else have an gear knowledge in 13.5??
80-85mm rollout seems the norm. I run about 81mm on a fairly tight technical track with a 12.5HT D3.5.
PROMODVETTE is offline
Old 12-13-2013, 01:01 PM
  #62
Thanks!
I'm running the fantom 3.5 as well, boost all the way up. With the gearing above, it's coming off at around 50 deg Celsius.
The track is large by 1/12 standards (pretty good size for even T/C)
With 86mm roll out, I was getting top speed 3/4 on straight, which is why I will try 91mm next!
Andrew S is offline
Old 12-13-2013, 01:05 PM
  #63
Originally Posted by SLOWINSLOWOUT
I find the composite balls have more slop, but they are lighter. I run the composite ball in the top, as well as titanium camber link turn buckle to reduce unsprung weight.
Once the car is set up well, it is on rails, very easy to drive. The slop in the front end is the one thing that drives me nuts about this car, but it does not seem to affect the way the car handles in a negative way.
I know what you mean! Mine handles fantastic, even with all the play! My T4's are the same!
I have the track record in 13.5 with mine!
Andrew S is offline
Old 12-27-2013, 01:38 PM
  #64
Mikkel_R's Avatar
This is my first time running 12th and ive bought this car to run. Ive a couple of questions if anyone can help me.
Are all the 12th servos the same dimensions as ive got the Savox one and I cant get the horn in the centre line of the chassis which means the steering arms are different lengths.
If they arent which servo do I need so I can get it into the centre.
Cheers Mike
Mikkel_R is offline
Old 12-27-2013, 02:21 PM
  #65
haura415's Avatar
haura415 is offline
Old 12-27-2013, 05:35 PM
  #66
andrewdoherty's Avatar
Trader Rating: 49 (100%+)
Buy a Futaba 9650. The car was designed around the dimensions of this servo.
andrewdoherty is offline
Old 12-28-2013, 01:19 PM
  #67
Originally Posted by JiuHaWong
Does the "Aluminum active front brace" work with the new car?
JiuHaWong is offline
Old 12-28-2013, 05:45 PM
  #68
ByteStream's Avatar
I'd say it was actually designed around the KO PDS-951/949 (it's pictured in every one of their 1/12 kits) but the Futaba fits just fine as well.
ByteStream is offline
Old 01-02-2014, 01:22 PM
  #69
Hey guys,
Anyone that has been interested in tamale pods for your car should grab one before they are gone. We are no longer going to carry them and there are only 4 left. once gone they are gone.
http://www.teamspeedmerchant.com/sho...smrtt7015.html
JoelV is offline
Old 01-02-2014, 07:17 PM
  #70
Ph3nyx's Avatar
Hey guys , do you thinks it's possible to use the new rear with the double damper of this x12 on a x10 link ?
Ph3nyx is offline
Old 01-27-2014, 03:03 AM
  #71
Skiddins's Avatar
Just built my first Xray 1/12, the quality, compared to my CRC Xi, is far better on the Xray.
While messing around last night fitting the servo I noticed that the mounting holes in the chassis are not the same distance apart, ie, when mounted on the right, the holes are slightly closer together than mounting on the left, can't remember whether it was 0.5mm or closer to 1mm.
So if the servo doesn't quite fit comfortably on the side you want, try the other side.
Skiddins
Skiddins is offline
Old 02-11-2014, 07:55 PM
  #72
Car Breaker's Avatar
what is the advantages of straight spring vs. conical with similar C rating ? why is there only c1.2 in straight while conical goes up to c 1.7 ?
I ran in medium traction asphalt track where are Xray X12 )non-2014) uses conical 1.7 to reduce the coning of front tyre.
Car Breaker is offline
Old 02-19-2014, 02:49 PM
  #73
Hi Guys,
Just wondering if anyone on here knows if any other cars side links would fit onto the xray X12?
Aceracer1
aceracer1 is offline
Old 02-19-2014, 07:02 PM
  #74
Team EAM
Trader Rating: 79 (100%+)
Originally Posted by aceracer1
Hi Guys,
Aceracer1
No they will not. Xray uses a unique length on the links.
EA
EAMotorsports is offline
Old 03-03-2014, 06:14 PM
  #75
Team EAM
My ROAR Carpet Nats Winning setup is posted on Xrays Site. The car was an absolute dream to drive and was the best 12th I have ever driven.
EA
