New XRAY X12 All new 2014
#46
Should be building my new car tonight. What is a good starting point set-up wise, will be running 13.5blinky on med/hi bit carpet. Also, this car gives the option of running the battery across the chassis or inline, what is the advantage/disadvantage of each configuration?
#48
Does the "Aluminum active front brace" work with the new car?
#51
looks like it is a common issue, Anyone from Xray here ? please report this problem.
#53
Gotta say my car fell together!
Lovely build :-)
Lovely build :-)
#54
finished, no problems on mine
#58
Loving the way my x12 drives! Impressive car!
Still getting the right gear combo for 13.5 blinky though!
I am up to 78 spur and 52 pinion for a roll out of 92 mm! Indoor ashfelt track.
Anyone else have an gear knowledge in 13.5??
#59
So are you guys running all composite balls to reduce slop in front end?
#60
Once the car is set up well, it is on rails, very easy to drive. The slop in the front end is the one thing that drives me nuts about this car, but it does not seem to affect the way the car handles in a negative way.
