Old 12-17-2014, 05:44 PM   #106
malcnz's Avatar
Originally Posted by evochick View Post
I have the Streetjam diffuser in my hand and it will be interesting to see how it holds up, I should be able to mount it to the plate area below the axle again not effecting ride height. Ill know more when I get to that part of the build
Heres the Streetjam one mounted....yeah being lexan I am not sure how long it will last but looks cool.
Street Jam SJF01 Formula 1. Niiiiiiiiice!-20141218_133643.jpg   Street Jam SJF01 Formula 1. Niiiiiiiiice!-20141218_133700_7.jpg
SCHUMACHER MI5 EVO/TEAM POWERS/SANWA/DX4R PRO.
SERPENT F110/TEAMPOWERS 21.5.
LOSI 22 2.0/TEAM POWERS 8.5
malcnz is offline   Reply With Quote
Old 12-17-2014, 06:00 PM   #107
evochick's Avatar
Yeah I might cut mine down and move it back
UnRetired
evochick is offline   Reply With Quote
Old 12-19-2014, 11:46 AM   #108
fmm
Originally Posted by JayL View Post
it is on top of the pod/chassis plate. The bulkhead ends before it's attachment position. So no ride height change.
It may be a bit much for carpet but it is great for asphalt, makes my car much more consistent
Thanks for the info, I will try it out on carpet and share my impressions.
One more question... Is there any "one-piece" lexan body with the front of the PF13 but a narrower rear end?
fmm is offline   Reply With Quote
Old 12-20-2014, 03:37 AM   #109
Ph3nyx's Avatar
Tamiya F60 maybe ?
the first F1 RC resource in french : www.rcf1.fr
Ph3nyx is offline   Reply With Quote
Old 12-20-2014, 11:56 PM   #110
evochick's Avatar
Someone was naughty and opened her Christmas present early and may have finished it !!
Build was good, no issues,
I had no problems building the V1 shocks, they went together smoothly.
I did a few things that I thought were really obvious like putting grub screws in the back of the steering axles to hold the king pins in that little extra...
now to wait the week to drive it
Beth.
UnRetired
Old 12-21-2014, 12:19 AM   #111
malcnz's Avatar
Beth.
Looks good and be interesting to see how it goes with the direct steering set up and in 180 width..we can run 200 here so set mine up like that.
Thought I could run mine today but the rain had other ideas..blue sky out there now
Old 12-21-2014, 02:13 AM   #112
OscarF1's Avatar
Still waiting fot Santa..............
Has anyone tried bump steering?
One of my F1 competitors has a large amount of negative bump
steering on his F104.
The side that is pressed down steers outward.
He drives no toe out!
And has the best straight line handling.
By choosing the ball connectors on top
or bottom of the steering hub you an create this.
OscarF1 is offline   Reply With Quote
Old 12-21-2014, 05:59 AM   #113
CFRacing's Avatar
has anyone tried this car 0n carpet, mine will be 190mm wide running foam tires 21.5 boosted on a 80x45 medium grip carpet track. any help or advice dialing this car up would be great. that of course when santa show up.
kyosho eM3 evo
Kyosho M3 evo
SpecR R1
STJFO1
turnigy
CFRacing is online now   Reply With Quote
Old 12-22-2014, 08:48 PM   #114
evochick's Avatar
Some more observations,
So I tried installing the Speed passion carbon rear axle, Fail...
After I installed I noticed that the metal part wasn't true to the carbon shaft causing the wheel to wobble, also the diff action was not smooth like it was binding, no issues with the STJ carbon shaft and housing, diff is smooth and tight,
I also tried the new Tamiya 84380 carbon Shaft and housing set, but is 3 mm wider then the STJ diff, so it is possible to use if you want a little extra width. The Clamp hub 54240 will also work to a point. The Carbon axle doesn't extend as far into it as when installed on a Tamiya and does clamp fine but doesn't extend to the grub screw. You will also need about 6mm spacer.
I think ill just stick with the STJ diff and axle for the minute.
UnRetired
Old 12-22-2014, 09:34 PM   #115
malcnz's Avatar
I installed the steel speed passion axle with no issues (dont mind a bit of weight over back axle) but was looking at the carbon axle due to some steel ones bending so cheers for the advice and might just get the STJ one.
Old 12-23-2014, 12:59 PM   #116
JayL's Avatar
SP carbon axle works perfect my and my buddies SJ...yours must be defective, the axle. Mine is super true, much more true than the stock setup.
I have seen three cars total with the sp carbon axle, all where fine
MOD: A800 R1 Digital-2 HW G2 4.5T|||VTA: Awesomatix EVO 1.1 Orca VX3 24K |||F1:
Xray X1 2017 HW XR10 StockSpec R1 21.5|||Futaba 4PX|||iCharger 308Duo
JayL is offline   Reply With Quote
Old 12-23-2014, 03:00 PM   #117
Manny's Avatar
It took less than a week for my SJF01 to arrive from Japan to Hawaii...also picked up some of the extra bits you guys recommended. I wouldn't hesitate to order from RC-Art.
I'm planning on running a Vintage F1 body on this car so I hope that rear end generates lots of grip (without a wing).
Manny is offline   Reply With Quote
Old 12-23-2014, 04:56 PM   #118
evochick's Avatar
I have no doubt, I am not a fan a speed passion quality,
Did you guys also realize the speed passion carbon axle sits in a few mm compared to the STJ axle and needs to be spaced out ??
UnRetired
Old 12-24-2014, 11:51 AM   #119
JayL's Avatar
yes, .4 shims between diff and side pod and the axle measures equal from the center balance dot in the pod to the end of each side of the axle
Old 12-24-2014, 04:53 PM   #120
ta04evah's Avatar
Hi all,
Am thinking of getting a Street Jam car, and have been reading through this forum thread about it.
Was also considering an Xray X1 & a VBC LightningF, but the price of the Xray is obscenely too high, and the VBC has snapping king pins, & front wheel compatibility issues.
From what I have been reading it seems there is nothing but praise about the car, and folks here are willing to share information, experience & knowledge which is always a good thing for both the car & drivers.
Another plus is that I am also a short drive away from a Speed Passion retailer, thus some spare parts can be sourced quickly if needed, including some of the hop ups mentioned.
Got the car and some of the upgrades that are in stock in my shopping cart, and finger is hovering over the buy button, but waiting to see how evochick's car goes on the weekend as we both race at the same club.
One question I do have is, does the Street Jam have a similar motor mount to the Speed Passion SP-1? and would the "540 motor mount" Speed Passion option part fit?
I ask this because we race F1 with 21.5 motors, and getting the right gearing with some brands of motors is not achievable without going to 64 pitch, which is something I don't want to do if I can avoid it.
Cheers
Rob.
BSR BT-4 / Turnigy / Hobbywing / Savox / Trackstar
Castle Hill Raceway Facebook https://www.facebook.com/groups/121817254587521/
FatBear RC Videos https://www.youtube.com/channel/UCjiAhwa-rk5Vas2rv5IBD4A
ta04evah is offline   Reply With Quote
