Old 11-13-2014, 04:58 PM   #61
Ph3nyx's Avatar
more balls you've got , smoother the diff is (and it's no need te be tighten that much). i use kimbrough most of the time (12 balls).
Speed passion and VBC have a 16 balls spur gear
the first F1 RC resource in french : www.rcf1.fr
Ph3nyx is offline   Reply With Quote
Old 11-13-2014, 05:16 PM   #62
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
I got my bladder shocks from RC Art. They ship fast.
For spurs, I am using Xenon spurs that uses 16 diff balls. I had to ream out the center slightly since the stock SJF01 spur hub part is slightly oversized.
Dan is offline   Reply With Quote
Old 11-14-2014, 01:33 AM   #63
Ph3nyx's Avatar
Do you have a ref ?
Old 11-17-2014, 01:35 AM   #64
malcnz's Avatar
Originally Posted by Ph3nyx View Post
Do you have a ref ?
http://www.petitrc.com/reglages/stre...JF01_PartsList
WDF02 is what you want x2 and you get the bladders, ti shafts etc.
if you want the spring set order WDFSPOx2 as well and if you want the nicer machined pistons order WDFOP1 x1.
SCHUMACHER MI5 EVO/TEAM POWERS/SANWA/DX4R PRO.
SERPENT F110/TEAMPOWERS 21.5.
LOSI 22 2.0/TEAM POWERS 8.5
malcnz is offline   Reply With Quote
Old 11-17-2014, 03:43 AM   #65
Ph3nyx's Avatar
ok thank you , it will solve a lot of pain
Old 11-19-2014, 08:01 AM   #66
OscarF1's Avatar
Are spare parts still made for streetjam?
In The netherlands its hard to get them.
(Speedpassion F1 parts also hard to get)
OscarF1 is offline   Reply With Quote
Old 11-19-2014, 12:13 PM   #67
JayL's Avatar
Yes, everything being made. They didn't expect the car to do as well as it did so they are slow coming.
Most of the replacement parts you'd need are the front end speedpassion parts. I order direct from speedpassion
MOD: A800 R1 Digital-2 HW G2 4.5T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche 2016 R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
Old 11-19-2014, 01:13 PM   #68
malcnz's Avatar
I got a lot of my speedpassion parts from Walter RC in Australia as they had in stock the carbon reinforced parts and the alloy bridge that is so hard to get.
Old 12-07-2014, 11:55 AM   #69
jdawg81's Avatar
I am just about done assembling this kit and after mounting the shocks I noticed the entire rear pod is about 3mm below the chassis. Its as if the shocks are too long. Is this normal?
jdawg81 is offline   Reply With Quote
Old 12-07-2014, 05:23 PM   #70
maybe after you add battery and electronics it might come down? or the shocks are a tad too long? maybe a limiter inside the shock might help. but i would try with a battery and your electronics added and see where it ends up.
dragonracing is offline   Reply With Quote
Old 12-07-2014, 06:40 PM   #71
Ph3nyx's Avatar
i had the same issue. Your caps on your shocks might not be tighten enough , you mustn't see the oring when they are fully tighten. but you'll have to be carefull the plastic threads on the caps are very soft.
the other solution i've found is to cut the ball cup of the shocks with the amount needed (in your case 3mm)
Old 12-07-2014, 08:17 PM   #72
malcnz's Avatar
I would just get the v2 shocks as soo much better and cheap.
Old 12-07-2014, 08:27 PM   #73
malcnz's Avatar
Heres mine all stickered up.
Street Jam SJF01 Formula 1. Niiiiiiiiice!-20141206_004302.jpg   Street Jam SJF01 Formula 1. Niiiiiiiiice!-20141206_000300.jpg   Street Jam SJF01 Formula 1. Niiiiiiiiice!-20141207_132041.jpg   Street Jam SJF01 Formula 1. Niiiiiiiiice!-tapatalk_1417779334656.jpeg   Street Jam SJF01 Formula 1. Niiiiiiiiice!-20141206_004333.jpg
Old 12-08-2014, 05:02 AM   #74
Ph3nyx's Avatar
very nice !!
Old 12-08-2014, 01:24 PM   #75
JayL's Avatar
the pod is supposed to hang down some, its called droop which is tunable to allow weight transfer to the front, did you put the spacers under the piston when you built the shocks?
