Old 03-03-2015, 03:59 AM   #376
aussierevo's Avatar
Trader Rating: 14 (100%+)
Well I'm pleased to say that a new chassis has restored my confidence in the Street Jammer.
Got a new chassis plate in the mail today and tonight the car has been built up as close to Hara's setup as possible and it's all good. No tweak and easy to setup all round.
Hope to give it a run this weekend. Couple of things I'd like to clarify with those running from Hara's setup for asphalt medium grip.
1. Hara setup shows front end on 200mm inserts yet gets a measurement of 192.5mm? Is this correct
2. The setup shows toe in on the front of 1 degree. Ive also run toe out to help with straight line stability and initial turn in. Anyone running the toe in and if so any thoughts of one over the other.
3. What spurs are you running. I normally run 48p. Its a tight fit running 66 Spur and 29 pinion with the unknown brand I have. Any suggestions.
Speed Passion F1.
Hobbywing ESC and Motor, SMC Batteries
Meakin Park Club Member
Team ARGO RC - Like us on Facebook
aussierevo is offline   Reply With Quote
Old 03-03-2015, 03:29 PM   #377
evochick's Avatar
Yep I noticed that on mine as well, with the mounts used towards the outside hole it will be about 192-195.
Go toe out
I am also running a 66/30 and yep its a super tight fit. I have some Zenon 64P about to go in to give me some more range for larger tracks, I think I got 82 and 84T spurs.
hope that helps
UnRetired
evochick is offline   Reply With Quote
Old 03-03-2015, 06:41 PM   #378
aussierevo's Avatar
cheers, thanks for that. I know it was Hara so just wanted to make sure I wasn't going mad.
Speed Passion F1.
Old 03-04-2015, 04:32 AM   #379
CFRacing's Avatar
Originally Posted by Dan View Post
The IFS has a noticeable difference on asphalt, but this is on my F1R2. I just slapped it on my SJF01 too.
On carpet, my F1R2 with IFS was easy to drive but I don't think I had much advantage, if any to the traditional front end setup. This is just my opinion, and I consider myself to be an average racer. Outdoor asphalt season starts up soon at my local track, so we'll see how how the SJ does.
Have you tried the IFS on the street jam on carpet? Would like to try it out.
kyosho tki 4
Kyosho M3 evo
SpecR R1
Exotek F1R3
CFRacing is online now   Reply With Quote
Old 03-04-2015, 09:41 AM   #380
mtveten's Avatar
Trader Rating: 27 (100%+)
Default ifs
I've tried the ifs on several cars including the street jam on carpet and although it was easy to drive it was never as quick as a conventional front end.
mtveten is offline   Reply With Quote
Old 03-04-2015, 10:24 AM   #381
CFRacing's Avatar
Talking
Thanks mtveten,is there a way to get rid of the rear steering? What about different pod angle? Anyone tried that? ANY comments or suggestions greatly appreciated.I'm super happy with the car but a little more is going to hurt someone else's feelings.
kyosho tki 4
Kyosho M3 evo
SpecR R1
Exotek F1R3
Old 03-04-2015, 06:21 PM   #382
mtveten's Avatar
if i remember correctly mounting the links on the top of the rear pod with a 1mm shim under the upper deck link will result in zero rear steer. The stock setting though rotates much better through the middle of the corner.
Old 03-05-2015, 02:59 AM   #383
CFRacing's Avatar
The stock settings is under the the top of the rear pod right? If you rise or lower the angle of the rear links will affect traction like rising or lowering the shock in a conventional f1?
kyosho tki 4
Kyosho M3 evo
SpecR R1
Exotek F1R3
Old 03-05-2015, 07:43 AM   #384
mtveten's Avatar
Yes the stock setting is on the underside of rear pod. The pod link angle doesn't work like touring shocks, it changes how car rolls. Lowering the rear link will cause the chassis roll to slightly increase the outer wheelbase and shorten the inner wheelbase creating a rear steering effect. Roll the rear pod with the different link positions and bottom plate gaps change as a link straightens
Old 03-05-2015, 08:34 AM   #385
CFRacing's Avatar
Thanks mtveten this thing has so muchos crear grip, have you tried battery in front?
kyosho tki 4
Kyosho M3 evo
SpecR R1
Exotek F1R3
Old 03-05-2015, 08:37 AM   #386
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
Have not tried out the SJ with IFS on carpet yet. Carpet season is ending here soon but hopefully I can squeeze in one more race until the fall. I'll be testing out the SJ IFS this weekend on asphalt.
Dan is offline   Reply With Quote
Old 03-05-2015, 11:22 AM   #387
gsxr0311's Avatar
Trader Rating: 18 (100%+)
Originally Posted by OscarF1 View Post
Please help me to find this !
I have two sets of carbon reinforced arms, and steering uprights I could sell you if you like. LMK
Special Thanks to: RC Target, Ko Propo USA, A Main Hobbies-SWORKz USA, R1 Wurks, and Absolute Hobbies.
Capricorn: LAB-C802, LAB E801, LAB-C03, TE03, and P01 235mm. IGT8. SWORKz: S350BK1 EVO II, S104EVO, S12-1M. Top Rebel 12.
gsxr0311 is offline   Reply With Quote
Old 03-05-2015, 11:27 AM   #388
Dan
Dan's Avatar
Trevor, did you get IFS too?
Old 03-05-2015, 11:36 AM   #389
gsxr0311's Avatar
Old 03-05-2015, 05:54 PM   #390
mtveten's Avatar
I started with the battery in front and found a higher rear weight bias to produce better steering into the corner. The streetjams pod design doesnt produce as much weight transfer as a conventional setup.
