Old 02-23-2015, 12:36 AM   #361
evochick's Avatar
Originally Posted by aussierevo View Post
well I think I've found the problem but not sure how to fix.
Why would I have almost 1 degree rear camber on right rear?. Bend standard axle maybe or hub carrier. The car has never been run so just bad luck? Spacers are the same both side, using the 2.0 axle holders.
I've ordered a carbon one anyway and hope that solves the issue, but by the process of elimination and and entire rebuild that's the only thing I can point to that isn't quite right.
If you had a bent axle when you spin the wheels one or both the wheels would wobble dramatically, it would be unrideable. If you remove the pinion and spin the axle assembly what does it look like ??
UnRetired
evochick is offline   Reply With Quote
Old 02-23-2015, 02:09 AM   #362
aussierevo's Avatar
Trader Rating: 14 (100%+)
to me the axle seems ok. I've rolled it along the setup board and it doesn't appear to have a wobble.
I rebuild the entire rear pod and checked a few other things and no matter what I do it sit's 'tweaked' on tires and the setup station.
Speed Passion F1.
Hobbywing ESC and Motor, SMC Batteries
Meakin Park Club Member
Team ARGO RC - Like us on Facebook
aussierevo is offline   Reply With Quote
Old 02-23-2015, 02:39 AM   #363
evochick's Avatar
if it doesn't wobble then its probably not bent then. If you had camber on one side then you would have had the opposite value on the other side if the axle was out. Which also doesn't make sense.
If all the front shims are equal and you haven't missed any can you do me a favour and wind the front springs nearly all the way in on the kingpin so there is almost no suspension travel but still make them equal. Then check the tweak chassis tweak. To me it still sounds like something is not right in the front end of the car.
UnRetired
Old 02-23-2015, 04:03 AM   #364
InZane's Avatar
Default New ride
Everything went together smoothly - decided to keep the kit shocks as they feel OK. A very pleasant build - first tests will be later this week.
The Street Jam F120-14 Body Set fits snugly over the chassis - low but still adequate room for links, shocks and wiring.
Special thanks to Evochick for your splendid support!
Does anyone have a decent starting set up for carpet (medium/good grip, tight layout, 21.5 blinky & Ride R1)?
more pics ...
InZane is offline   Reply With Quote
Old 02-23-2015, 12:34 PM   #365
aussierevo's Avatar
well I slept on it and after waking up it is what I thought. The chassis is tweaked at the front end.
i rebuilt the entire front end last night and just checking the height of the axles afterwards it was clear it couldn't be anything more.
guess I'll have to get another chassis in due course and for the time being stick to the exotek F1R2.
thanks everyone for your suggestions.
Speed Passion F1.
Old 02-23-2015, 01:24 PM   #366
evochick's Avatar
Sigh, typical StreetJam quality, its a shame they are so hit and miss....
I would still be putting the chassis on the setup board to confirm its twisted.
InZane the body doesn't look bad at all.
UnRetired
Old 02-23-2015, 03:29 PM   #367
aussierevo's Avatar
i've order a new chassis and fingers crossed I get a decent one. If not, then I'll part it out.
Cheers
Speed Passion F1.
Old 02-23-2015, 03:31 PM   #368
JayL's Avatar
are you sure you didn't screw in the kingpins different amounts left and right?
MOD: A800 R1 Digital-2 MM Fleta ZX 5.0T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche 2016 R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
Old 02-23-2015, 03:47 PM   #369
aussierevo's Avatar
it's the chassis. you can see the twist when laid flat on the setup board. The left hand side sits up just enough to annoy.
Speed Passion F1.
Old 02-24-2015, 12:21 AM   #370
InZane's Avatar
If you mount it really low the rear wing will get clean air.
Old 03-01-2015, 06:36 AM   #371
Default Got this recently
I have gotten this kit recently. I have a question about the reaer wing. I noticed that there are three levels of holes you can insert the wing, what are the differences that the different wing height make toward the car's performance?
arekpowalan is offline   Reply With Quote
Old 03-01-2015, 09:12 AM   #372
mtveten's Avatar
Trader Rating: 27 (100%+)
Rear downforce, the higher the wing the more efficient the wing should be.
In my testing however when running running hard plastic wings I haven't encountered a noticeable difference between the settings
mtveten is offline   Reply With Quote
Old 03-02-2015, 05:05 AM   #373
CFRacing's Avatar
Test and tune sesión yesterday went great , now really flying, changed to tamiya front w exotec upper
arms ,1200 weight shock oil,(4 hole v2 shocks)yellow springs,black front springs,7°caster,2°camber,
4mm ride height, tamiya soft rear,hard front, best lap 12.04. Then changed the rear upper link to the stock
Position and even the 1/12 guys coudn't belive the results, 11.6s average with fast lap of 11.42, that's w
Practice trackstar motor,not geared right to the track.(undergeared).
kyosho tki 4
Kyosho M3 evo
SpecR R1
Exotek F1R3
CFRacing is offline   Reply With Quote
Old 03-02-2015, 10:17 AM   #374
JayL's Avatar
Where did you have the rear upper link before you changed it to 'stock' position?
Old 03-02-2015, 03:52 PM   #375
CFRacing's Avatar
it was above the rear mount like hara,s setup. now it rotates way better,we run carpet on foam tires,will try harder compound rear tires or springs to try to free up the rear a little bit more.
kyosho tki 4
Kyosho M3 evo
SpecR R1
Exotek F1R3
