Old 01-16-2015, 05:07 AM   #211
rcmax2's Avatar
Rob it was nice to be in the same pit as you to day and I hope you go well on Sunday ps the Car looked Good at thend of the day .
Xray T4/15 XB4 Northen Beaches Hobbies HEI Walter Hobbies / Castle Hill Raceway
rcmax2 is offline   Reply With Quote
Old 01-16-2015, 07:19 AM   #212
NutDriver's Avatar
Trader Rating: 14 (100%+)
On the F1R thread, someone posted a pic of a Durango droop screw that is 3mm with a head on it. It also has hexes on both ends so it can be adjusted from top it bottom with a 1.5mm
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 01-16-2015, 07:22 AM   #213
NutDriver's Avatar
My question about the Extoek front end might be better addressed on the F1R thread, but I'll ask it here. When the F113 came out, it was said to not be legal for UF1 races due to the shocks being outside the bodywork (as well as other factors). I've wondered how this front end is legal for UF1 when the F113 isn't.
USVTA member #111
Old 01-16-2015, 09:26 AM   #214
OscarF1's Avatar
my axle was not straight.
made a tool to measure it.
after some hammering made deviation from 1/10 mm to 1/100 mm
the steel is quit hard , needed a lot of force.
OscarF1 is offline   Reply With Quote
Old 01-16-2015, 01:20 PM   #215
Jerad8's Avatar
Trader Rating: 102 (100%+)
Originally Posted by malcnz View Post
I think you have it covered..not much to an f1 car...maybe get some carbon reinforced hubs and some king pins and the rear spring set for setups.
others have covered the ballstud/ballcup thing and looks like they are prity universal.
I got the SJ body and very happy with it..theres no cutouts for front arms so just be carful here but its nicely detailed and cheap and comes with 2x diff noses plus helmet. I also got the rear diffuser .
Was thinking about trying the SJ F12014 body but the SMP48 (yours) just looks so simple and clean (also easy to paint).
Jerad8 is offline   Reply With Quote
Old 01-16-2015, 01:25 PM   #216
It's not the fact the F113 shocks are outside the body, there's nothing wrong with the F113 shocks. In fact the shocks are one area that's legal. It is illegal because the wishbone mounting points are outside the body, and that it's 200mm wide.
terry.sc is offline   Reply With Quote
Old 01-16-2015, 01:32 PM   #217
NutDriver's Avatar
Gotcha. Thanks, Terry.SC
USVTA member #111
Old 01-16-2015, 01:50 PM   #218
malcnz's Avatar
Thats right they do a more modern body but i like the 80s/90s bodys and the modern i think comes with seperate noses which can look a bit stuck on.
SCHUMACHER MI5 EVO/TEAM POWERS/SANWA/DX4R PRO.
SERPENT F110/TEAMPOWERS 21.5.
LOSI 22 2.0/TEAM POWERS 8.5
malcnz is offline   Reply With Quote
Old 01-17-2015, 12:13 PM   #219
fmm
Originally Posted by ta04evah View Post
Well I finally got to run the car today, things didn't start off too well with the car wanting to swap ends if I went anywhere near the brake before the turn.
To make matters worse it bounced & skipped over any bumps on the track surface making it unstable & almost impossible to drive.
I was almost ready to give up on it there and then, trying to drive a car out of the box that had horrible handling, and with the memory of the terrible build still fresh in my mind, I had the ebay app open on my phone ready to sell it off for what ever I could get for it.
But......
A friend who had also been watching it, suggested a different weight oil in the shocks to address the skipping issue, and after changing the oil the car was a little better to drive. So what next? my thought turned to spring rates, and decided to try the medium soft springs, the result was also an improvement in handling, but still very nervous going into the turn, and quick corrections of opposite lock was needed.
The next 2 changes also improved the cars handling, one of them I just thought of doing for "shits & giggles" being reducing the amount force of brake in the esc from 75% to 67%. The other change was going 1 tooth less on the pinion gear as it was a very warm day and the motor was coming off very hot after the practice sessions.
After those changes, the car transformed into something that was very fast, very smooth, and had handling that almost resembled a touring car with the same motor (21.5t).
During further practice runs the lap times came down to the point that I was demoralizing some of the 21.5 touring car drivers, by not only catching them, but also passing them on the outside, & turning into the corners faster than they could.
Later in the day I had the chance to pace my car against evochick's, and 2 things were very apparent from having the battery mounted up front.
The first was that my car was "pushing" out of the tighter turns which meant my exit speed was slower, and the second was that evochick was able to get on the power quicker out of the tighter turns with having the extra weight over the back wheels.
The front to back balancing point on the 2 cars were not much, but the result was greater, so before the race meeting on Sunday, I'll be swapping the battery to the back, and the esc up towards the front of the car.
At the end of the day I was a much happier person, because I felt less like I had wasted my money on a car that I perceived was bad. One thing I did notice as the handling of the car improved, is that I had to be more "aggressive" with my driving style because it improved when I did so. Sure, it's not perfect, but I doubt any car is, and my driving is very far from perfect too, but now I feel confident it will improve when I make the changes to it, and that it will be even better with the bladder shocks (when I can get them).
Another point I want to share is that the car took some very hard hits today, including getting the front wing wedged under a bolted down metal track barrier, which took the use of a crowbar to get it free and nothing broke, which is always a good thing so there is a degree of durability in the car.
So, hopefully the racing gods will be kind to us come Sunday, and I'll be able to keep up with evochick to make it a 1 & 2 for Street Jam on the day in the F1 class.
Regards
Rob.
Hi Rob
Could you please share your setup? I am curious about the shock oil, etc.
And then for someone who can answer. which is a good starting oil with the the type two shocks and the 4-holes machined Pistons? I am using 700 now and I a pretty satisfied... But I was wondering what people are using with the machined pistons
Thanks a lot
fmm is offline   Reply With Quote
Old 01-18-2015, 02:52 AM   #220
evochick's Avatar
Woot ..StreetJam tq and 1st and 2nd on debut at NSW F1 series At IMCC cup.
Video up next couple of days when i get back home.
UnRetired
evochick is offline   Reply With Quote
Old 01-18-2015, 06:35 AM   #221
xevias's Avatar
How's the SJF01 on carpet?
Any setups?
xevias is offline   Reply With Quote
Old 01-19-2015, 12:05 AM   #222
ta04evah's Avatar
Originally Posted by fmm View Post
Hi Rob
Thanks a lot
I used the setup that evochick put up in this post - http://www.rctech.net/forum/13744959-post129.html
The two differences from evochick's car to mine was a different body, and front wing. I was using a low down force wing, which meant I had to brake harder to turn into the corners, which scrubbed of a good amount of corner speed.
Our StreetJams debuted with a 1st & 2nd at an event yesterday. At first the car didn't feel any faster than my old car, but once I changed the settings to resemble as close as possible to the above setup sheet, the car felt a lot more settled & smoother to drive.
Also during the course of the day, the car underwent some "durability testing" from me crashing it from my own fault, and crashing from slower lapped cars suddenly deciding that they wanted to drive into me, but the car stood up to some sizable impacts so good news on that aspect.
Is it quicker or better to drive than my F113 - I'm not totally sure at the moment, I'm still not 100% convinced that this car is the best car for me & my driving style, so I'm going to withhold judgement for now until I race it a few more times so I can gain a better comparison.
Regards
Rob.
BSR BT-4 / Turnigy / Hobbywing / Savox / Trackstar
Castle Hill Raceway Facebook https://www.facebook.com/groups/121817254587521/
FatBear RC Videos https://www.youtube.com/channel/UCjiAhwa-rk5Vas2rv5IBD4A
ta04evah is offline   Reply With Quote
Old 01-19-2015, 02:02 AM   #223
evochick's Avatar
Rob was a little unlucky in this first A final, but bounced back with good results in the next 2 finals. My car is the yellow with the white wings out in front
http://youtu.be/HNstpHrI79c
Beth.
UnRetired
Old 01-19-2015, 04:23 AM   #224
malcnz's Avatar
well done on first and second girls and guys.
Trying to set my back end up with the sp carbon axle as thats the only carbon one i have and got the qteq hub for lh side and to get the 190 set up with ride tyres as dont have yet do i need to space the diff side and if so how much? and do you need to have equal lengths axle each side of the centre point on the chassis as in some pics haras car looks like its wider on the diff side?..and confuses me..cheers
Old 01-19-2015, 08:38 AM   #225
OscarF1's Avatar
Yesterday 1rst try-out with the Streetjam.
Car feels realy good on the carpet track with the Ride R1 tyre.
Rear is a bit bumby (need harder oil)
No timed laps yet, but the car is verry forgiving and predictable,
like someone said before like a touringcar.
This is my steering solution:
SEO by vBSEO 3.5.0
