Old 01-08-2015, 10:59 AM   #166
malcnz's Avatar
Originally Posted by fmm View Post
I have installed the servo in laydown position, but I have seen that the steering links hit the upper arm. I have cutters the lower chassis and still hit the arms. Are you using spacer between the servo saver and ballstuds? How many?
Thank you in advance!
I presume you are using the bellcrank set up?
i have mine layed down..kopro lowprofile servo and have the sp alloy servo arm and alloy bridge only so no servo saver and running 3x 2mm spacers but you could run 2x 2mm and 1x 1mm and heaps of clearance.
SCHUMACHER MI5 EVO/TEAM POWERS/SANWA/DX4R PRO.
SERPENT F110/TEAMPOWERS 21.5.
LOSI 22 2.0/TEAM POWERS 8.5
malcnz is offline   Reply With Quote
Old 01-08-2015, 12:15 PM   #167
evochick's Avatar
I run my servo at a slight down angle, I think it helps the ackerman angles a little, you can sort of see it in this photo,
I only have to run 1X 2mm shim with a Tamiya servo saver
Beth.
UnRetired
evochick is offline   Reply With Quote
Old 01-08-2015, 12:39 PM   #168
CFRacing's Avatar
well guys just finished my stj build great one. just have one or two questions:what would be the effect (handling wise)of changing the pod angle? more flat=? more angle=? any help would be great. will be testing this sat. i will report back how she goes. will be tested on carpet on foam tires 185 wide.
kyosho tki 4
Kyosho M3 evo
SpecR R1
Exotek F1R3
CFRacing is offline   Reply With Quote
Old 01-08-2015, 01:24 PM   #169
fmm
Beth.
Thank you very much for both replies!
Are you using a lot of Ackerman?
With the the servo completely flat (parallel to the chassis), I think I will not have problems with 3mm spacer, but not sure the effect on the Ackerman. Can someone help me to properly setup the Ackerman in a F1?
Thank you very much in advance!
fmm is offline   Reply With Quote
Old 01-08-2015, 01:55 PM   #170
evochick's Avatar
I wouldn't say it a lot of ackerman, its certainly less then the yokomo ran,
Its honestly a trial and see if you like it thing, with the servo angled you should get a slightly increased angle on the inside wheel,
Regarding CFRacing for the pod angle, all the setups I have seen have the pod sitting flat or with only a very slight angle.
Just use Hara's setup, you cant go wrong.
UnRetired
Old 01-08-2015, 02:35 PM   #171
CFRacing's Avatar
thanks evochick for your reply.with hara"s setup the pod ends up with .50mm lower ride height at the front of the pod than the rear.
kyosho tki 4
Kyosho M3 evo
SpecR R1
Exotek F1R3
Old 01-08-2015, 09:35 PM   #172
evochick's Avatar
StreetJams now out of stock again
looks like you have still got to be quick if you want one
UnRetired
Old 01-09-2015, 07:05 AM   #173
CFRacing's Avatar
does anybody knows the weight of the factory shock oil? thanks in advance.
kyosho tki 4
Kyosho M3 evo
SpecR R1
Exotek F1R3
Old 01-10-2015, 06:52 AM   #174
ta04evah's Avatar
Just finished building my Street Jam, and I have to say that I was expecting something better than what I had bought.
Between the vague & ambiguous instruction manual, missing parts, super soft plastic material, parts not lining up, and incorrectly bagged parts, I honestly cant give this kit any higher rating than 5/10 for a building experience.
Of note was the included shock absorbers, which were a nightmare and tedious exercise to build. Those tiny "e" clips that bent, or flew off in different directions when you tried to ever so gently snap into place on the shock shaft almost had me to the point of abandoning the build completely.
Fortunately I found a way to hold them in place while gently clipping them into place in the grooves, so I persisted with the rest of the build.
The plastic rear axle inserts that would not fit in, without a considerable amount of force, which in turn transferred pressure onto the outer race of the bearings, that made the bearing feel tight & "notchy" is also worthy of a mention.
The only way that this could be rectified, was to dremel off some of the plastic at the top of the insert, so that it could easily be inserted snugly into the aluminum housing with a minimal amount of pressure, yet stay tight enough so there was no play between it & the housing.
Will be installing the electrics over the next day or so, along with mounting body & wings, and will hopefully have it ready to race for next weekend.
Have followed, and setup the car to evochick's recommendations, and sincerely hope it's performance on the track will be a more positive experience to make up for the negatives so far.
Regards
Rob.
Castle Hill RC On Road Facebook https://www.facebook.com/groups/121817254587521/
FatBear RC Videos https://www.youtube.com/channel/UCjiAhwa-rk5Vas2rv5IBD4A
ta04evah is offline   Reply With Quote
Old 01-10-2015, 08:13 AM   #175
fmm
Originally Posted by OscarF1 View Post
Soldering is no solution ( already did that )
I will try to tap 2 new m3 thread holes in de motor front plate,
that should help.
Regulations are this motor only at one of the circuits I tend to race.
Hope they don't mind the extra holes!
Hi again!
I found the solution. The only thing you need do is unscrew the three screws of the front motor plate, turn the motor plate clockwise to the next position (when the hole of the screws align again) and screw the screws!
As simple as that! I have now my hobbywing motor perfectly fitted into the car.
Hope this helps
Old 01-10-2015, 10:11 AM   #176
Professor's Avatar
Regards
Rob.
Wow that's not good rob,there is nothing worse than a new car that in some way does not quit come up to ones expectations, hope your right & it's performance is better than the build
VBC RACING AUS--HOBBYWING--MAD GRAPHICS--BITTY DESIGN
Professor is offline   Reply With Quote
Old 01-10-2015, 10:54 AM   #177
OscarF1's Avatar
Did make some extra m3 holes in the front motor plate (HW Xerun)
Wiring:
OscarF1 is offline   Reply With Quote
Old 01-10-2015, 11:02 AM   #178
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
Yup, the build was pretty crappy after being spoiled by Tamiya F1 cars. The front end annoyed me with the lower plate and all the damn shims. Parts quality sucked too. I ended up ordering so many upgrades to get it right.
Luckily the car shows promise. I need more track time with it but with a little more tuning, I think I can get it faster than my normal link F1 cars.
Dan is offline   Reply With Quote
Old 01-10-2015, 12:14 PM   #179
evochick's Avatar
Wow Rob i didnt experience any of that..
yep the eclips were small but mine went on ok. Also yes i sanded the ride height inserts a little so they were less tight. But i didnt dremil mine just a little sanding on the edge that tapers. Sorry for not mentioning it. But other then that you just must have got a lemon kit which is always dissapointing ..
Perhaps after a couple of years of building associated kits to me any kit quality is an improvement
UnRetired
Old 01-10-2015, 01:21 PM   #180
malcnz's Avatar
yeah same mine was all good and yeah the eclips are tricky but every kit has tricky bits and if they didnt lets face it it would make the build boring.
my inserts were fine and bearings were fine so as said maybe a lemon but a bit of sanding here and there is expected and better than being loose.
