Need parts for HPI RS4 Sport2
Hi,my son needs theA192 shaft with both A490C&A490D gears as well as the three Z251 spring pins. The shaft boke while at full speed one gear was trashed the other was never found thanks to the dark asphalt and it was getting late. Can anyone help with this new or used does not matter just cant see throwing this car in the trash because of a couple of parts thanks,Scott
TRY THE SPRINT AS WELL. VEHICLES ARE VERY SIMILAR
hpi sprint 2?
No NorCalLump it is different than the spint 2 or sprint 2 flux it is HPI RS4 Sport 2 Model any help would be great!!!
do a little research and you'll see that the RS4 sport 2 and the Sprint 2 are very similar, meaning you'll likely be able to use some parts from the Sprint 2 platform on your RS 4. That is what NorCalLump was getting at.
Bot everything is interchangeable, but some parts are and some parts may work with little modification.
I ordered a kit for the sprint 2 as I thought it was the same as well. The shaft on the sprint 2 is longer and the drive belt gears are about 3/4 an inch apart. On my sport 2 the gears are almost touching my rear shaft is 4x40mm the sprint 2 is longer, I am wondering since I have the kit for the sprint 2 if i changed the rear Diff maybe that would make up for the longer shaft any suggestions?,
what are the part # you are looking for. The local hobbyshop may have it. They have a lot of older stock.
NorCalLump here they are theA192 gear shaft 4X40mm with both A490C 32t gears with the 490C cups that glue to the sides of the gears usually they come together. Last I need the three Z251 spring pins. I hope you or someone can find them can't even find a roller for a RS4 Sport 2 and I keep looking!!. Thank you for all your help, Scott
Anyone have parts for this car or a good roller to sell?? I would take a RS4 sport 2 or a sprint 2 thank you!!!
We have searched everywhere you go Electronic fresh being the first at this time I am unable to also get a used component which is upon the number!! Absolutely no dash either the child is bumming.
