Old 11-17-2013, 10:30 AM   #121
Hello,
I currently drive the Xray X12(last years edition) and was looking around (ie just looking) and saw this car. I have heard it mentioned at our local track, but have not heard much about it.
Here is what I like about this car, from what I have seen:
front king pins dont use e-clips
front blocks are aluminum
body posts have threaded adjustments
less costly for the car and the parts (although not necessary. I am just looking for best handling car).
I am an intermediate level driver who is trying to improve. I run 17.5 blinky. Here are my questions about this car:
1) my xray is above the minimum weight limit before I put on the body. How does this car do with weight?
2) 1 of the improvements in the new 2014 xray x12 is the use of straight rear side springs, instead of tapered. If this is a good thing, would they fit on the vbc car.
3) how durable is this car? I try to stay off the walls, but sometimes my brain does not react to the car as fast as the car does.
4) How hard is it to remove the battery for charging? I know that most people charge their batteries while in the car, but it is safer to charge the battery in a lipo bag.
5) In your honest opinion, how does this car compare to the Xray X12 2014, Top Rebel, V-design carpet ripper?
thanks.
Colorado On-Road RC Club
www.5280raceway.com
www.facebook.com/CORtrack
Driving: Xray T4 2015, T.O.P. Rebel 12, Durango DEX8T, Durango DEX408 v2, Associated B5M, Associated B44.2
rc_speed is offline   Reply With Quote
Old 11-18-2013, 09:44 AM   #122
MAD916's Avatar
still have (2) in stock sold 8 this last weekend....
Timezone Raceway Park " on-road outdoor european style road course.
Timezone II 60'x100' indoor carpet track. Host of the ROAR 2011 Carpet Nat's.
Timezonehobbies.com your new source for online RC products.
MAD916 is offline   Reply With Quote
Old 11-18-2013, 10:13 AM   #123
Tron's Avatar
Trader Rating: 16 (100%+)
Anyone know what weight the side damper tube oil is that comes with the kit?
Brett H - M03, TRF417, RM01x
"Slow Sportsman"
Tron is offline   Reply With Quote
Old 11-18-2013, 10:17 AM   #124
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
Tried to send you a pm but your box is full.
Looking to see if you have a set of shock ends so I can complete my kit for the race this weekend. It was missing the one the spring retainer sits on.
Rob Jensen
Thanks to the following companies for their support in 2017: Team Associated, Maclan, Fierce R/C Solutions
micrors4guy is offline   Reply With Quote
Old 11-18-2013, 12:59 PM   #125
JayBee's Avatar
Trader Rating: 31 (100%+)
I'm using Shurlube in my dampers tubes. In 17.5, which is closer to what you guys are using....red or green?
Btw, these tubes are the best I've seen on a pan car.
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 11-18-2013, 01:02 PM   #126
MAD916's Avatar
I will look as soon as I get to the track this evening... had a big weekend at the track and sold a lot of lightning parts, but there is a chance. will PM you as soon as I have an answer, and we can ship it out in the morning
Old 11-18-2013, 04:29 PM   #127
flameoutgarrett's Avatar
Send a message via MSN to flameoutgarrett
The car is legit, I sat down at Dave's pit a few times a day and handled it, digging it more every time I look at it, it tq'd the timezone gp in stock, by a good margin, it definetly is a great car, stock and mod. The touring car is awesome too!
Team fun-Www.rc-trim.com-Team Speedmerchant-Team Orca-Team Br00d
flameoutgarrett is offline   Reply With Quote
Old 11-18-2013, 05:42 PM   #128
here is mine minus the shock being connected
Rob Jensen
Old 11-19-2013, 09:49 AM   #129
Trader Rating: 15 (100%+)
I am about to finish building my car this evening and will try to weigh it ASAP. As far as I am aware this car will weigh in similarly to the AE. Don't forget that battery and motor comprise a far larger portion of the overall weight than the chassis (for instance, the Orca being 20g lighter than the D3.5, etc).
The kit VBC spring retainers are very cool machined aluminum, but they are made for the VBC/AE springs and will not fit the xray/speed merchant linear side springs. Keep in mind you can always purchase a second crossbrace with the appropriate spring retainers from Speed Merchant, though, which would let you use the linear side springs on this car. Also note that the linear side springs are not really a clear improvement over the AE/VBC springs, and I would go so far as to mention that there are more top drivers out there who use the standard AE springs than who use the linear springs.
I have not had a chance to run the car, but from what I have seen this car is very durable. I don't believe I saw anyone break parts at Timezone GP this past weekend.
You have to remove the front battery brace and the strapping tape. Two screws and about a minute of work.
While I think the new Xray is much improved over the past iteration, I think the VBC definitely has an edge. The TOP rebel is a very quick car, but doesn't have the same parts availability/standardization that the VBC has. The V-dezign is a very good car, but Vesa basically doesn't make them any more (so you are screwed if you break aluminum) and it uses a CRC front end that is (in my opinion) more fragile than the VBC/AE front end.
Feel free to let us know if you have any more questions, and I will be driving my Lightning at 5280 now that I have it in-hand.
Chris Hillier | 5280 Raceway | www.5280raceway.com | Racing. Elevated.
Destiny | LRP America | Protoform | Xenon/JFT | Gravity RC | Motiv | Sanwa | Max.FX
LloydLoar is offline   Reply With Quote
Old 11-19-2013, 09:55 AM   #130
Moderator
Clegg's Avatar
Originally Posted by LloydLoar View Post
The V-dezign is a very good car, but Vesa basically doesn't make them any more (so you are screwed if you break aluminum or carbon) and it uses a CRC front end that is (in my opinion) more fragile than the VBC/AE front end.
Only point of correction here, is that the carbon parts are available for the V-Dezign, only parts it seems are not are the rear pod bulkheads. But he has stacks of carbon chassis, cross braces, etc...
Joe Kelly - JK720.net
5280 Raceway |5280raceway.com | 5280 Raceway Facebook
Clegg is offline   Reply With Quote
Old 11-19-2013, 10:01 AM   #131
Thanks for the correction, I edited my post to match.
Old 11-19-2013, 02:12 PM   #132
JayBee's Avatar
Default :D
Finally got-r-dun...
Simple...easy...no fuss...and no surprises. Just had to add a .3mm shim under the center pivot assy to have the main chassis sit absolutely flat. Had some annoying flashing on the lower arms around the pivot balls but really not an issue. Besides these MINOR things, this kit was an fantastic build
Putting in my electronics took longer than the build Pretty tight in there, but I made sure to leave enough space to get wrenches in here and there.
Very nice piece of eye candy. Good job VBC
Old 11-20-2013, 11:11 AM   #133
dr_hfuhuhurr's Avatar
Trader Rating: 70 (100%+)
I should be picking my car up tomorrow or Friday and I will be doing what I did on my Associated 12R5.2. You dremel off the outer battery stops. This way the battery can be removed easily.
I did this on my 12R5.2 and never had issues with the battery coming loose without the stops (and believe me when I say I did try).
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 11-20-2013, 02:29 PM   #134
JayBee's Avatar
Is anyone running a rollover antenna on these cars. I haven't notice a hole for one.
Old 11-20-2013, 02:32 PM   #135
There's a hole...if you zoom into the picture above, you can see it.
I would ALWAYS run a rollover antenna, it can save a run.
