VBC Lightning 12
#91
Hi Kody!
Its basically the same as my 13.5 setup...
5 degree caster block setting
thick shim back, thin shim forward
6 degree caster (measured with the Slapmaster caster gauge)
no brace
stock length upper arm
stock lower arm width
AE .20 front spring
High position on shock mount
2mm shim under rear shock
35wt oil in center shock
AE blue spring
Side Springs in standard position on pod
AE silver side spring
Half turn preload
10K in the tubes
max rear width (172mm)
Pink front
Pink rear
Protoform AMR
no brace
AE .20 front spring
AE blue spring
Half turn preload
10K in the tubes
Pink front
Pink rear
Protoform AMR
#93
#94
Hi Kody!
no brace
AE .20 front spring
AE blue spring
Half turn preload
10K in the tubes
Pink front
Pink rear
Protoform AMR
no brace
AE .20 front spring
AE blue spring
Half turn preload
10K in the tubes
Pink front
Pink rear
Protoform AMR
#96
Hi Kody!
no brace
AE .20 front spring
AE blue spring
Half turn preload
10K in the tubes
Pink front
Pink rear
Protoform AMR
no brace
AE .20 front spring
AE blue spring
Half turn preload
10K in the tubes
Pink front
Pink rear
Protoform AMR
Also - what do you run for toe? Same for stock and mod?
#97
yes it was on low bite. I dont run stock very much. Those are the only tires I had. Ehrlich is running stock this weekend in Minnesota. He will post his setup when he gets back. I hear a lot of people are running Black front and orange rear.
#98
Max thanks for the info, can you clarify the stock length upper arm setting - the kit calls for the 1.5mm upper arm spacer and a 4mm gap between the upper arm and upper arm eyelet. I'm not sure what that equates to in camber but do you keep those same measurements or do you readjust the upper arm turnbuckle to keep camber at a specific measurement (when running the upper arm spacer or not)?
For toe I try to run as close to zero as I can get
#101
kits are shipping from distributor to us today....
#105
Should have our order Tomorrow..... we will put them up on the site as soon as we get our hot hands..... got a few pre-orders already. so there may only be a few kit's available in this first order
