Like Tree3Likes
Old 10-22-2015, 12:35 PM   #586
Originally Posted by A.C.R. View Post
We had a problem with the first design, there were two left side retainers and none right. It has been corrected and now itīs OK.
If you have received a wrong one, please contact me.
http://shpws.me/K5Rw
Also, there is free shipping worldwide this weekend.
ARC I was able to order the second version, there is a left and right.
However they don't fit
The chassis brace is 3.51mm thick, it seems like the battery retainers are made for thinner carbon fiber, maybe 2.56mm thick like the other chassis parts.
tekin112000 is offline   Reply With Quote
Old 10-22-2015, 01:18 PM   #587
Chassis brace is 3mm thick, and retainers have a space of 3.1mm.
Laser sintered parts have higher tolerances than machined or molded parts, but it still should fit with a small amount of pressure or with a little bit of sanding.
Please try again. Mine fitted.
B5M upgrades AC RC gear
www.shapeways.com/shops/acrcgear
A.C.R. is offline   Reply With Quote
Old 10-22-2015, 04:28 PM   #588
I measured with calipers, the chassis brace is 3.51mm thick, I have the second version of the kit. Maybe you have the first version
I agree that the space in the battery retainer is 3.1mm but that is not enough space to fit on the chassis brace.
I was able to sand the retainer and remove enough material to squeeze the retainers on the chassis brace
Old 10-23-2015, 12:03 PM   #589
Archie10's Avatar
Trader Rating: 18 (100%+)
Does anyone know whats the FDR for this car?
Archie10 is offline   Reply With Quote
Old 10-24-2015, 02:04 AM   #590
DBM
Will the vbc pivot balls work with the AE lower arms, or do I need to buy the AE balls?
DBM is offline   Reply With Quote
Old 10-24-2015, 01:03 PM   #591
DBM
Changed out the ball cups for tamiya ones. Much better. Now it is obvious that there is a lot of slop in the steering knuckles. I think I'm just going ti swap out all of the mushy vbc plastic parts for AE or Xenon parts.
Edit: I'll probably order the aluminum steering knuckles from the lightning 10.
Old 10-28-2015, 12:04 PM   #592
Tell us how it works out with the L10 knuckles.
It seems like my front has a lot of slop, what Tamyia ball cups did you use?
Old 10-28-2015, 12:42 PM   #593
DBM
Tamiya 53601low friction adjuster. They say 5mm, but they are 4.7mm. They are a common upgrade used on spec-r touring cars which use 4.7mm ball studs.
Old 11-07-2015, 11:27 AM   #594
Thanks DBM I tried the Tamiya cups they seem to have taken up some of the slop in the front end.
I checked out the L10 knuckles, they look nice, but $26 is more than I want to spend.
I was able to tighten up the stock 12L knuckles a bit by adding a king pin shim to the screw that holds the axle into the knuckle.
Old 11-07-2015, 11:34 AM   #595
Can anyone give some guidance for setting pod sag and pod droop?
How much pod sag is recommended?
How much pod droop is recommended?
I can rotate the collar on the shock, is that the only way to change the shock length, or should I screw the ball end further on the shock shaft?
The instructions never mention the correct length of the shock or the correct rebound.
Old 11-07-2015, 04:20 PM   #596
EDWARD2003's Avatar
Pod sag - you can run 0~0.5 mm of sag. I usually run 0~0.2 mm.
Pod droop 1.0~1.5 mm
You'll have to adjust both the collar and ball end to achieve the desired pod sag and droop.
Check out my YouTube channel for 1/12th scale and 1/10th Touring maintenance tips!
YouTube Search https://www.youtube.com/c/EdwardPickering?gvnc=1
                 VBC 12M - D08 - FX
EDWARD2003 is offline   Reply With Quote
Old 11-07-2015, 07:15 PM   #597
Thanks Ed, I watched your video on the subject, as well as many others you have posted on youtube.
Not to dispute what you say, but those seem like very small numbers. To me .5mm is hardly any sag at all.
1/12 are very sensitive but I did not realize how sensitive, and how small the tolerances are
Old 11-07-2015, 11:36 PM   #598
EDWARD2003's Avatar
Glad you like my videos.
Remember, these are 1/12th scale cars. Every small detail matters, even down to 0.2 mm.
                 VBC 12M - D08 - FX
Old 11-09-2015, 06:01 PM   #599
There is slop in the knuckles, I can't figure out how to tighten them up.
I did replace the stock front wheel bearings with new ones from avid it seems like that has taken up a bit of slack in the wheel.
So, better but still a bit sloppy. So much so that I don't think getting a set up station would be worth it. Setting camber would be frustrating
Old 11-18-2015, 06:53 AM   #600
celt's Avatar
Default Looking for some sanity...
Hey guys, need some help here.
Absolutely love this center shock. It's build and design quality is second to none in my opinion. Just can't seem to keep oil in in for the life of me. I studied the manual to make sure I've got the bits in the right orientation.
I've tried;
new o-rings
shimming behind the o-rings
green slime
venting cap
non-venting cap
soaking the o-rings
Really, really dig the shock, but it has to keep oil in it for more than one qualifier...
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is online now   Reply With Quote
