Like Tree3Likes
Old 10-24-2013, 01:52 PM   #46
Team VBC Racing's Avatar
Default Release of the VBC Lightning 1/12
VBC Racing is happy to announce that pre orders are now being excepted for the new VBC Lightning 1/12th car! Cars will be shipping as early as late next week! The price will be under $200!
The Lightning 12 made it debut at the 2013 IIC race in Las Vegas with a couple strong finishes. VBC drive Max Keunning finishing 3rd place in modified 1/12th and 5th place in 13.5 1/12th.
Don't get left out on the first run of cars. Pre order with your local hobby shop or at www APS-Racing . com VBC Racings north America's importer.
Dave Ehrlich
Team Manager
VBCracingusa.com
North & South America
Canada
Team VBC Racing is offline   Reply With Quote
Old 10-24-2013, 07:37 PM   #47
Cars should be here anytime now. All the pre-ordered guys will be ship as soon as we get the cars with free shipping and the VBC t-shirt.
www.beamcat.com
beamcat is offline   Reply With Quote
Old 10-24-2013, 09:28 PM   #48
JayBee's Avatar
Trader Rating: 31 (100%+)
VBC or AE? Damn decisions
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 10-25-2013, 03:33 AM   #49
To be honest. If you had seen the VBC in person. VBC for sure. Not just because I am selling it but the quality is miles ahead of the AE....... The CNC job, carbon and plastic parts, really top class.
www.beamcat.com
Old 10-25-2013, 06:28 AM   #50
T-Hawk's Avatar
Come down to TZ Saturday and see Ehrlich's in person. Top notch quality
-Ryan Newbury-
TomAHawk Racing - On-Time Services - XRay Racing - Sweep Racing - RoseCityScaleRacing.com -
T-Hawk is offline   Reply With Quote
Old 10-25-2013, 06:33 AM   #51
JayBee's Avatar
I'm in Mt. Vernon this Saturday at NORA's debut. I've asked Kody to put in a pre-order for me.
When are spares gonna be available?
Old 10-25-2013, 07:40 AM   #52
Timezone hobbies will have spares. You might talk Kody into bring some in also. When I'm up there I'll have spares also.
Dave Ehrlich
Team Manager
VBCracingusa.com
Canada
Old 10-25-2013, 08:12 AM   #53
Trader Rating: 24 (100%+)
Send a message via AIM to Max K
The tuning options on the front end of the Lightning 12 are far superior to the AE. Laser cut carbon shims for shimming lower arm width, upper arm length, and ride height. A lot easier and more precise. Having the option to run the side springs inboard on the pod or outboard on the link is another great tuning option especially if you run modified and spec classes. The rear pods being supported by a 5mm carbon brace across the back protects it from side hits and prevents motor plates from bending. I took some hard hits in vegas and I didn't break/bend anything on the car.The price isnt too bad either!
I will post my setups if anyone is interested
RC America - XRAY - HUDY - Trinity - ORCA - Sanwa - ULTI - PROTOform - MaxFX - Slapmaster Tools - ApexRC - SXT
Max K is offline   Reply With Quote
Old 10-25-2013, 09:28 AM   #54
Tron's Avatar
Trader Rating: 16 (100%+)
Please post the setups, I would really like to see them!
Would you or someone be willing to spend some time discussing why to use the inboard or outboard side springs and how they can be used as a tuning aid for particular driving styles?
There is some limited information out there - Front caster is adjustable or fixed?
Does the manual have tuning details on what different settings do for this car?
Brett H - M03, TRF417, RM01x
"Slow Sportsman"
Tron is offline   Reply With Quote
Old 10-25-2013, 02:37 PM   #55
Paul Ohlsen's Avatar
Send a message via Yahoo to Paul Ohlsen
Dave you have PM.
Viper R/C Solutions | Team ARC USA | Express Motorsports | Xpert USA | Max.FX |Blitz / Team Titan | Hiro Seiko
Maxim 39-There is a difference between spare parts and extra [parts]. From The Seventy Maxims of Maximally Effective Mercenaries
Paul Ohlsen is offline   Reply With Quote
Old 10-25-2013, 02:48 PM   #56
MAD916's Avatar
We got in the first round and have 10 kits in our first order will update as soon as we get them in
Timezone Raceway Park " on-road outdoor european style road course.
Timezone II 60'x100' indoor carpet track. Host of the ROAR 2011 Carpet Nat's.
Timezonehobbies.com your new source for online RC products.
MAD916 is offline   Reply With Quote
Old 10-25-2013, 02:54 PM   #57
JayBee's Avatar
Got mine pre-ordered You have spares coming too Mark or is that later on?
Old 10-26-2013, 01:34 AM   #58
13.5 Setup
5 degree caster block setting
thick shim back, thin shim forward
6 degree caster (measured with the Slapmaster caster gauge)
no brace
stock length upper arm
stock lower arm width
AE .20 front spring
High position on shock mount
2mm shim under rear shock
35wt oil in center shock
AE gold spring
Side Springs in standard position on pod
AE silver side spring
Half turn preload
30K in the tubes
max rear width (172mm)
Pink front
Pink rear
Protoform AMR
Mod Setup
Thick shim forward, thin back
4 degree caster (measured with the Slapmaster caster gauge)
no brace
1.5mm upper arm spacer
standard lower arm width
AE .20 front spring
low position on shock mount
4mm shim under rear shock
40wt oil
AE Blue center spring
Side springs on links
AE Black side spring
Just touching
20K in tubes
Max width rear (172mm)
Pink front
Blue rear
Protoform AMR
Side spring location has been something me and Ehrlich have been doing a lot of testing for. When the side spring is moved to a more inboard location (on the Pod closer to the center pivot) it requires a stiffer spring. Since you are moving the leverage point inboard it takes more force to stop the pod from pivoting. This is better for spec since you need more steering and a more "twitchy" feeling car. When you move the springs outboard (on top of the link further away from the center pivot) the force required to stop the pod is less. Therefore you can run a softer spring making the car slower off center and easier to drive. Ehrlich and I both prefer this for Modified. It calms the car down just enough. For tuning aids for different types of driving styles I'm not sure how this will help. I think that outboard springs are defiantly the best for Mod since the calm the car down and make it smoother. If you want your car to steer and be aggressive enough for spec racing I would lean you towards running inboard springs. But thats just my personal preference.
Front caster is adjustable just like the Associated front end. One hole in the rear of the caster block allows the block to pivot to 3 different caster locations, 0, 5, and 10 degree. Then you also have the upper arm shims to finely tune the caster.
Im not sure about the manual having tuning aids. You can just ask on here and any of the VBC factory drivers would be happy to answer your questions!
Old 10-28-2013, 06:46 PM   #59
Default Lightning 12
Cars are starting to ship! Who's ordered one?
Dave Ehrlich
Team Manager
VBCracingusa.com
Canada
Old 10-28-2013, 08:30 PM   #60
RCBuddha's Avatar
Trader Rating: 35 (100%+)
Any chance to see the manual?
RCBuddha is offline   Reply With Quote
