Like Tree3Likes
Old 08-18-2015, 07:53 AM   #571
Has anyone use the transverse mount chassis brace for the Associated 12R on your 12L
Reflex makes one http://www.reflexracing.net/RSD-AE-1...it_p_2367.html
Do you think it would work on a 12L
tekin112000 is offline   Reply With Quote
Old 08-21-2015, 02:47 PM   #572
I am building a VBC 12L.
Are the side springs supposed to touch the chassis.
Right now with no battery no electronics the springs don't touch the chassis until I twist the rear pod.
Old 09-06-2015, 08:25 AM   #573
When you mount the battery transverse, dont you cut the battery retaining areas so the battery sits flat on the rear chasis brace?
B5M upgrades AC RC gear
www.shapeways.com/shops/acrcgear
A.C.R. is offline   Reply With Quote
Old 09-06-2015, 08:51 AM   #574
Toyota Tom's Avatar
Yes. I also used a countersunk M3 and nut in front of the battery to prevent it from moving forward. You need to countersink the the area where the screw
is on the battery tape slot so it will sit flush with the bottom of the chassis.
SoCal
P12/17
M-07
Toyota Tom is offline   Reply With Quote
Old 09-06-2015, 09:06 AM   #575
If you modify the chassis brace and cut of the retainers will there be too much weight towards the back of the car?
Will that add to weight transfer and give more steering?
I am going to mount the Lipo transverse just because I like the extra room for RX and ESC, just not sure how far back I want the lipo to sit.
Old 09-15-2015, 02:53 PM   #576
If you want to try a transverse setup, you could use this parts to help the tape to hold the battery on its place.
http://shpws.me/K5Rw
Old 09-15-2015, 05:53 PM   #577
thanks ARC
I just bought one
Shapeway says it will arrive 9/29
I'll update the thread once I get it installed
Old 09-29-2015, 04:53 AM   #578
We had a problem with the first design, there were two left side retainers and none right. It has been corrected and now itīs OK.
If you have received a wrong one, please contact me.
Also, there is free shipping worldwide this weekend.
Old 09-29-2015, 09:38 AM   #579
How did you secure the small rectangle part towards the front? Is it screwed to the chassis?
Old 09-29-2015, 09:47 AM   #580
It holds in its place by pressure, but its better to add a dab of glue to stick it to the chassis.
Old 09-30-2015, 02:39 PM   #581
Toyota Tom's Avatar
I received two left retainers. I have contacted Shapeway, including sending
a picture. Shapeway claims there is no problem and to contact the designer.
Just trying to get the correct parts.
SoCal
P12/17
M-07
Old 09-30-2015, 03:08 PM   #582
Youīve got a PM
Old 10-06-2015, 10:19 AM   #583
DBM
I have a Lightning12 on the way. Going to be running it in 13.5 blinky on spec lilac tires. Any suggestions on a setup to start with? My current car is a crc, so I have crc springs to choose from.
DBM is offline   Reply With Quote
Old 10-17-2015, 02:31 PM   #584
Emaculant's Avatar
I have a brand new factory sealed VBC Lightning 12 V2 for sell.
New VBC Lightning 10 and Lightning 12 V2 (Xray X10 X12, CRC XTI, WGT, 1/12 Pan Car
Emaculant is offline   Reply With Quote
Old 10-20-2015, 05:09 AM   #585
any rumors when the new car will be available?
xps800doo is offline   Reply With Quote
