Like Tree3Likes
Old 03-21-2015, 10:33 AM   #556
dr_hfuhuhurr's Avatar
Trader Rating: 73 (100%+)
Does anyone have pictures of the car setup with the battery transverse?
What do you need to make this happen? I ran the TOP car last week and wonder if the transverse battery really makes that big of a difference as I was 3 tenths faster on the same track with the TOP car.
dr_hfuhuhurr is online now   Reply With Quote
Old 03-23-2015, 10:07 PM   #557
Korey Harbke's Avatar
I've been playing with a transverse setup for a while. No special parts needed really. I just run a small piece of double sided tape (think stuff... like double sided scotch tape) under the battery to help keep it still in addition to the normal battery strapping tape.
Setup changes I found helpful with transverse setups:
- Softer side springs are good to keep the car from lifting and being overly aggressive. Generally I run the side springs on the links. Associated black springs are a little stiffer than I'd like. CRC .45's are pretty solid though. You have to tweak the spring a bit to fit our spring cups better though. I've heard some are having success with some speed merchant and yokomo springs as well
- Softer front springs are also important. AE .018s or Speedmerchant 0.019s are pretty solid. They just help smooth the car out and keep it from getting all lifty in the corners when coming in hot!
Attached pic is an example of one of my car's that has a few aftermarket goodies on it for experimentation. Team prime shock is used mainly to use the blue AE spring (little stiffer than the VBC black), and the xenon front end to play with some additional options like kingpin inclination. The stock VBC L12 V2 front end is what I have on my inline car right now.
Seido Speed Works - Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 03-24-2015, 09:51 PM   #558
Trader Rating: 24 (100%+)
Send a message via AIM to Max K
I finally got to run the car transverse this past weekend. It defiantly has a lot more natural steering than the inline car. Im defiantly going to run it transverse in modified at the MHIC in a couple weeks!
SM 18 front springs
10 degree reactive caster
thick shim back
1.5mm on lower arms
2mm shim on upper arms
-1 degree camber
Steering links swept back (calms the car down)
Hot Bodies center shock
AE Blue
50wt
1mm droop
4mm under rear of shock
Upper hole on shock mount
20k in tubes
SM 18 side springs
Pink/ Soft Green
Protoform AMR
3.5mm ride height all around
RC America - XRAY - HUDY - Trinity - ORCA - Sanwa - ULTI - PROTOform - MaxFX - Slapmaster Tools - ApexRC - SXT
Max K is offline   Reply With Quote
Old 03-25-2015, 07:47 AM   #559
Thanks for the info!
1.5mm on the lower arms, what do you mean here?
2mm shim on the upper arms, this is the kit setup right?
SM 18 front springs
thick shim back
1.5mm on lower arms
-1 degree camber
AE Blue
50wt
1mm droop
20k in tubes
SM 18 side springs
Pink/ Soft Green
Protoform AMR
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
Old 03-25-2015, 11:02 AM   #560
1.5mm spacing the lower arm out.
I think 1.5mm is stock but I'm not 100% sure.
Old 07-27-2015, 10:47 PM   #561
Prototype 1/12th from VBC Racing!
Old 07-28-2015, 02:47 AM   #562
very sexy
Ted Su(TW) is offline   Reply With Quote
Old 07-28-2015, 06:53 AM   #563
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Good looking car with some interesting twist
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 07-28-2015, 08:38 AM   #564
EricPF's Avatar
How does it handle on granite?
Eric Epp
PROTOform // racepf.com
EricPF is offline   Reply With Quote
Old 07-28-2015, 08:46 AM   #565
Trader Rating: 15 (100%+)
Early reports say it lacks forward bite.
Chris Hillier | 5280 Raceway | www.5280raceway.com | Racing. Elevated.
Destiny | LRP America | Protoform | Xenon/JFT | Gravity RC | Motiv | Sanwa | Max.FX
LloydLoar is offline   Reply With Quote
Old 07-31-2015, 03:02 PM   #566
RacinJ's Avatar
That prototype looks sweet.
Is the VBC going to have some of the same features as the 2015 Hiro Factory kit or are they going in separate directions?
RacinJ is offline   Reply With Quote
Old 08-03-2015, 08:59 PM   #567
No, they are going in different directions and are developing their own cars!
Old 08-06-2015, 06:27 PM   #568
Swampracer's Avatar
Trader Rating: 69 (99%+)
Default Lightning 10 battery position
Max,
Sorry thread drift, but I'm building a Lightning 10 WGT. What is the best battery position?
Are people mounting the batteries now with double sided tape? If so what brand do you recommend?
The 12th scale kit looks amazing
Swampracer is offline   Reply With Quote
Old 08-14-2015, 10:22 AM   #569
My kit just showed up in the mail. I am excited to start building it.
I have never built a pan car.
Does anyone have any suggested locations for screws with locktite?
Any suggestions for transverse mounting the Lipo, what holds it in the chassis?
Any other suggestions for a first time pan car builder?
tekin112000 is offline   Reply With Quote
Old 08-14-2015, 11:35 AM   #570
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
Originally Posted by Swampracer View Post
Max,
Try transverse
**Team Scream**Parma/PSE**TQ Wire**Roche**Pemberton**BSR**Graupner/GM**SXT**
sg1 is offline   Reply With Quote
