Like Tree3Likes
Old 02-13-2015, 06:47 AM   #541
dr_hfuhuhurr's Avatar
Trader Rating: 75 (100%+)
Originally Posted by Korey Harbke View Post
I use AE's really cool Ti-Nitride ball studs, and the open end ball cups from the 12R5. I think they are used on their touring cars too. Just trim as needed to get the amount of droop you need.
-Korey
Thanks...appreciate it.
Blake
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 02-13-2015, 10:23 AM   #542
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
Tried the spec r plastic bodies shocj with yokomo black. Overall shock weight 12 grams vs 10 for the vbc so insignificant. Car definitely held more corner speed but was much more fiddly in thw transition from on to off throttle. Letting off in the sweeper ect.
Went back to factory with 70wt ae but reduced reactive to mid setting. Much better overall but still off pace a little.
Next time ill this this front end on the transverse car. Yokomo 2.5 ws prob too stiff but vbc black prob pretty close to where I'd need to be. Similar to ae gold?
My stuff
| Team Associated - Reedy - Reflex Racing/RSD - ProAMPS RC |
My RC
www.irocc.ca - www.wcics.ca - www.vrcworld.com - http://proampsrc.com/ - www.teamassociated.com
valk is offline   Reply With Quote
Old 02-14-2015, 12:30 PM   #543
Trader Rating: 24 (100%+)
Send a message via AIM to Max K
Unfortunately the AE gold is quite a bit stiffer than the VBC black, but of the VBC springs black is the stiffest. From what I've learned over the past years of running spec, and ever since Cyrul started running spec again. You have to set up your car so its on the verge of spinning out. Which means your car has to be super edgy. That fiddlyness that your feeling between on and off power is almost what your looking for in terns of carrying more corner speed. By the way... When are you ever off power in a spec class? Keep that thing strapped!!!
Another thing to add. When you put the Touring car shock on make sure that the angle of the shock is the same as what it was with the VBC shock. Angle of this can cause the shock to act stiffer/softer than it actually is.
RC America - XRAY - HUDY - Trinity - ORCA - Sanwa - ULTI - PROTOform - MaxFX - Slapmaster Tools - ApexRC - SXT
Max K is offline   Reply With Quote
Old 02-14-2015, 12:49 PM   #544
valk's Avatar
its kind of a bad habbit from practicing so much mod i guess that now i suck ass at stock lol.
we run a fairly small track of 3 rolls with 6ft lanes. quite a lot of 180s. usually i only let off like 1/4 of the way. 13.5 spec though. we wouldnt touch 17.5 for pancar lol.
hard to say what i like though. just going down to middle reactive caster made a pretty big difference to corner speed.
My stuff
My RC
Old 02-18-2015, 08:44 AM   #545
Thats what me and Dave Ehrlich have been playing with a lot recently. Caster adjustments seem to be a very big change even if your just changing it about 2 degrees!
Old 02-18-2015, 08:54 AM   #546
AE .020 vs AE .018 springs...
Since the beginning of time I've always run .020 springs as a standard. With our lighter cars these days (my L12 weighs in at 734g) does .018 make more sense? What's the consensus on these? I have a set I think I'll try on Saturday.
Old 02-18-2015, 08:59 AM   #547
wingracer's Avatar
In low bite, yes. High bite, oh hell no
Unless you're running some brick of a front tire.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 02-18-2015, 09:00 AM   #548
Takes steering away. If your having problems with your car being too edgy or traction rolling go to 18 front springs.
Old 02-18-2015, 09:20 AM   #549
On power I can see it taking away some steering but off power it would add steering right? The softer spring would allow the weight to transfer quicker or am I off?
(things I think about when I should be working - HA!)
Old 02-18-2015, 09:22 AM   #550
I ran 17s at snowbirds with a blue front in 13.5
Old 02-18-2015, 09:23 AM   #551
On and off power steering depend on center shock oil and spring. Doesn't really have anything to do with front springs.
Stiffer front spring = more steering (to a point)
Softer spring = less steering
Old 02-18-2015, 09:26 AM   #552
Thanks for the clarification. On your setup sheet below you're running SM 18 front springs, where do those fit compared to the AE springs?
Old 02-18-2015, 09:27 AM   #553
Basically the same. they measure out on the calipers to .18. They are just a hair longer. Not sure what the longer spring does tho. I was just using what found first in my box!
Old 02-18-2015, 09:32 AM   #554
Thanks, I'll see what I end up doing this weekend.
You or Korey coming to the Carpet Nats @ Horsham?
Old 02-18-2015, 11:07 AM   #555
No. Neither of us will be going. We will be going to MHIC in Denver though! Such a great race!
