Like Tree2Likes
Old 01-31-2014, 05:58 AM   #376
avs
avs's Avatar
Originally Posted by Nanoframe View Post
Greetings everyone!
I got my self the Lightning12 about 2 weeks ago and was impressed by the quality of the build and how well it handles. I do have a small issue though, did anyone encounter any rubbing of the turnbuckle cup on the inner rim of the front wheels?
This happens when the steering is close to full lock. My steering endpoint is currently set at 70 both sides on the S9650 servo. Wheels are RB Speedlines.
Any suggestions would be most welcome.
different front wheels have different offset, so if you shim to get the same front width, you should have the same clearance between the rim and turnbuckle.
you might check your front width to others' (I am not familiar with RB's wheels, they may produce a narrower front)
a picture from above might help to verify you don't have some other issue
Tony Shimko
avs is offline   Reply With Quote
Old 01-31-2014, 06:16 AM   #377
Kenny L's Avatar
Trader Rating: 16 (100%+)
Here is setup I've run. Going to run next weekend make few more small changes car is super smooth and easy to drive
Team Tekin, Ko Propo America
Kenny L is offline   Reply With Quote
Old 01-31-2014, 06:20 AM   #378
LonnyJ1950's Avatar
If you're running the Yellow RB wheels, it's one of the smallest diameter front wheels on the market. If it's rubbing the turnbuckle itself at lock, I think you may have too muck steering travel.
Lonny
LonnyJ1950 is offline   Reply With Quote
Old 01-31-2014, 07:23 AM   #379
Nanoframe's Avatar
@ avs: Thank you so much for the suggestion, I will take a picture and post it soon.
@LoonyJ1950: That's what I thought too, I will try toning down the travel and see if it helps. My only worry is that I have to lower it so much so that I lose steering in the tighter corners around the track. For the sake of testing, I tried fitting a yokomo wheel and it yielded the same problem as well.
Nanoframe is offline   Reply With Quote
Old 01-31-2014, 07:43 AM   #380
Kenny L's Avatar
What size track and how big are lanes? How is traction?
Old 01-31-2014, 09:50 AM   #381
dr_hfuhuhurr's Avatar
Trader Rating: 73 (100%+)
You will probably want to tone down the travel. I believe I'm setup at 55-60% max. If you're not able to get around the tighter corners you'll probably want to check the setup.
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 01-31-2014, 09:59 AM   #382
flameoutgarrett's Avatar
Send a message via MSN to flameoutgarrett
Yeah 85% is my max, if it's hitting the turnbuckle something else is the problem, can you post a pic of your servo? Maybe you need a spacer to get a little more angle on your links
Team fun-Www.rc-trim.com-Team Speedmerchant-Team Orca-Team Br00d
flameoutgarrett is offline   Reply With Quote
Old 01-31-2014, 06:15 PM   #383
Nanoframe's Avatar
Thanks! I'll turn down the end-point further and work from there. I'll have a look at the setup as well.
The track is fairly small approx 30+ meters (98+ ft) by 15 meters (49+ ft) with the long straight running the length of the track. The width is about 3 lanes wide along the straight and narrows down to 2 in the corners. Traction is close no none on the smooth epoxy surface.
Thanks! Here are a few pictures;
The Servo
The Front End
Full Lock Left
Full Lock Right
Do excuse the poor quality of the pictures taken. ^^;
Click the picture for the full size resolution.
I really appreciate the help that everyone has given so far. It can be challenging when you're the only one playing with pan cars in the midst of drifters. So thank you all!
Old 01-31-2014, 07:20 PM   #384
Kenny L's Avatar
The Servo
The Front End
Full Lock Left
Full Lock Right
looks like you missed the arkerman shims as flameoutgarrett had mentioned
Old 01-31-2014, 08:12 PM   #385
Yep there's your fix!
Old 01-31-2014, 08:22 PM   #386
Nanoframe's Avatar
Great! Thanks everyone!
EDIT: I added the Ackermann spacer and most of the rubbing is now gone. The inner rim is still rubbing at extreme steering lock which I believe can be remedied with the reduction of the steering endpoint. I did not expect the omission of that part would have such a big impact on the steering. Looks like I still have a lot to learn.
Old 02-01-2014, 09:08 AM   #387
Kenny L's Avatar
I couple things I missed on sheet was full front end ae but with Vbc mounting blocks to get shortest upper arm. Also using ae ball cups in full front end too
Old 02-01-2014, 12:06 PM   #388
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
I know brian made a center spring chart, but is there one comparing various side springs? I see most people use ae but how do the crc springs compare. They are easier for me to get without making an internet order.
Only changes to stock I've made so far were ae titaniun turnbuckles in upper arms, spec r steel for steering links and tamiya ballcups throughout.
Hope it stays together better this time.
Regret buying spare vbc balcups lol. Ill never use them. The side springs kinda neh too. Getting them on/off the keepers is a challenge.
My stuff
| Team Associated - Reedy - Reflex Racing/RSD - ProAMPS RC |
My RC
www.irocc.ca - www.wcics.ca - www.vrcworld.com - http://proampsrc.com/ - www.teamassociated.com
valk is offline   Reply With Quote
Old 02-01-2014, 10:56 PM   #389
rayan's Avatar
Default esc
What esc you guys using? Gonna be running a 17.5 or 13.5 motor
ActivRC.com
rayan is offline   Reply With Quote
Old 02-02-2014, 12:48 AM   #390
valk's Avatar
tonight went much better. qualified 7th overall and finished there. i changed batteries for the bump to the amain "5car mains" but all the speed i had to win the B was gone in the a.
I set the car up with max's front end and tried a few different things with the rear. ran crc magenta/green combo all night with 3k in the tubes, 50wt in the middle on 3 holes. this seems to work very well for magenta/green but i tried black/greylow and the car was on ice.. soooo pushy. I think the stock springs might be a touch too stiff in the front for that tire combination, which i ran all the time with my associated. ill be picking up a full set of front and rear crc springs next race day, and trying to get the car to work with black/greylow again as its pretty norm for our track on a club race.
the setup i ran tonight should work very well for the mod car though on our carpet. the car had TONS of traction, pretty much on rails all night but this might have cost me some time in corners. i tried putting stiffer lube in the tubes but made the rear end washout unexpectedly. stayed with 3k all night.
i also tried magenta greylow but that was way way too much front end bite. maybe softening the rear more would have helped.
for my driving style the mod tires worked well, but maybe for stock ill need to adjust my driving style. which is difficult.
next week off. hopefully the following week i can sort the car out on the standard stock tires and figure out rollout/timing for my hobbywing 1s and reedy mach2 13.5. havent had a lot of tracktime on carpet this year and havent really figure out what that motor likes yet. last year was 17.5 boost and i had that pretty well figured out.. i went from top 3 to struggling to make the top 8..
im also going to try running transverse. my best results in stock was with my onpoint 5.1 conversion which was transverse. when i went to the 5.2 inline i had some trouble getting the same corner speed. which sounds strange but meh. all about tracktime i guess. the transverse seemed to corner better on 135s and similar where the inline was better in chicanes obviously. usually we have more 135 in series but not always a chicane.
meh. I still noob.
My stuff
My RC
