Like Tree3Likes
Old 12-16-2013, 10:41 AM   #301
oeoeo327's Avatar
Trader Rating: 70 (100%+)
Originally Posted by Jerry P View Post
I broke an exacto trying to do it the other day. Maybe a carpet knife would work better.
Thanks Mike. I'll order one of those up and get a clamp on hub also. Being that the axle isnt changing there should be no issue with gear mesh like barry mentioned.
Leave it to Mr. "12th scale fo' life" to come up with a solution...
Founding member of the Solid Gold Racing Team - Mediocrity, redefined...
✯Jackson RC✯Horsham RC✯SJCCR✯
oeoeo327 is offline   Reply With Quote
Old 12-16-2013, 12:30 PM   #302
corallyman's Avatar
Trader Rating: 99 (100%+)
So I ran my car fairly box stock this weekend and it was pretty good. Only changes were 15k in the tubes and on the king pins. Ended up running the audi body. I'm not a fan of cutting the bsr rims so I'll be purchasing a bunch of Jaco wheels. I know every makes it sound easy to trim a wheel down but not for me. I guess I'm lame. Foam is easy to remove but plastic rim not so much. I feel like 1/12 is about being very accurate and at this point cutting a rim down in my hands will be anything but accurate. so all in all the car was good out of the box, lots of people took notice. I did end up doing the v2 AE arms.
Originally Posted by dr_hfuhuhurr View Post
I'm with you on the cutting tires. Were you running the VBC or AE center shock?
Don't use an Xacto for cutting the rims, potentially too dangerous. Good for cutting the foam but not good for the rim imo. Use a tire sanding stick instead on the rim. The same stick that you use to radius the tire once cut. Mine has something called a dragon skin on it and it makes this task pretty easy. Course sand paper should work fine as well.
Steve
Team ORCA / ORCA USA / Pro Spec
Serpent America / Team Serpent S411 ERYX / On Point Racing OP12C, S120 / Xceed Products
Hangar 30 / Seattle RC Racers
Fasttrax Racing Series / NORA On Road Series
corallyman is offline   Reply With Quote
Old 12-16-2013, 12:38 PM   #303
Whenever I have narrowed tires/wheels, I have done so using an xacto knife on the truer... I use safety goggles as it can potentially be dangerous, not to mention that some pieces of foam/plastic can fly up.
It is not difficult at all to get an accurate/smooth cut if you have a sharp blade and a quality tire truer.
I also recommend using the fatter xacto blades, not the standard ones... They are much less likely to break or have the tips splinter off. Like so:
JamesL_71 is offline   Reply With Quote
Old 12-16-2013, 12:47 PM   #304
Jerry P's Avatar
Trader Rating: 44 (100%+)
Steve
Thanks guys. For now i'm going to get an irs 3mm offset hub and clamp on hub then i'll be able to adjust the width with shims. Maybe one day VBC will put out some option hubs so my car can match again.
Jerry P
Awesomatixusa - Side Piece Racing - LRP - Sweep Racing Tires - Mike L Designs - TQ Wires - Crispy Critters Raceway
www.awesomatixusa.com
Jerry P is offline   Reply With Quote
Old 12-16-2013, 07:39 PM   #305
ralph m's Avatar
R/C Tech Charter Subscriber
Trader Rating: 31 (100%+)
Jerry,
Most cars have already gone to an offset pod design for brushless motors. There is a good chance that VBC already has a narrow diff hub. Measure the distance from the wheel mounting surface to the diff ring mounting surface and I'll do the same on the IRS 3mm offset hub.
You looked great at Horsham for the first time out with the VBC.
Ralph
tqwire.com
ralph m is offline   Reply With Quote
Old 12-16-2013, 08:30 PM   #306
mike ivy's Avatar
Trader Rating: 50 (100%+)
Hey Jerry,
You wont have any Problems at All. Just re shim the axle that all ya have to do. I've used these 3mm off set hubs on my 12r5 when I ran CRC/BSR tires and had no issues at all.
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 12-16-2013, 09:14 PM   #307
ApexRCProshop's Avatar
Originally Posted by ralph m View Post
Jerry,
Ralph
ok i just ordered one of these hubs... If jerry can drive it so can i...
Apex RC Exclusive North & South American Pro-Spec Distributor
Share & Like Our Page:https://www.facebook.com/ApexRCProshop
ApexRCProshop is offline   Reply With Quote
Old 12-17-2013, 04:17 AM   #308
Jerry P's Avatar
thanks danny..
Jerry P
Old 12-20-2013, 07:57 AM   #309
MAD916's Avatar
Check out the holiday special on the Lightning..... while they last.
http://www.timezonehobbies.com/index...roducts_id=819
Timezone Raceway Park " on-road outdoor european style road course.
Timezone II 60'x100' indoor carpet track. Host of the ROAR 2011 Carpet Nat's.
Timezonehobbies.com your new source for online RC products.
MAD916 is offline   Reply With Quote
Old 12-20-2013, 02:25 PM   #310
corally's Avatar
Hello
a small question...what servo fit ?
corally is offline   Reply With Quote
Old 12-20-2013, 02:36 PM   #311
Default servo for Lightning 12
I am running an Airtronics 94145 servo in my Lightning 12. I know that the JR servo, Savox servo, as well as the Futaba 9650 will also fit in the car
Hope that helps,
Robert
robert s is offline   Reply With Quote
Old 12-20-2013, 02:46 PM   #312
Trader Rating: 24 (100%+)
Send a message via AIM to Max K
thats an awesome deal! good job Mark!
RC America - XRAY - HUDY - Trinity - ORCA - Sanwa - ULTI - PROTOform - MaxFX - Slapmaster Tools - ApexRC - SXT
Max K is offline   Reply With Quote
Old 12-21-2013, 04:47 AM   #313
corally's Avatar
thks Robert
but more servo fit between the mount...problem is axe ...i have one servo,fit between mount..BUT the spline is slight offest to center of car..
This is why ask this info...
Old 12-21-2013, 07:42 AM   #314
Originally Posted by corally View Post
thks Robert
What servo are you using? Ive used both the KO Propo and the JR3650 servo with no problem. Spline is centered perfectly. Ive seen on other cars with Savox servos and the spline is not centered.
Old 12-21-2013, 09:18 AM   #315
corally's Avatar
Hello
I nave some servos..but any fit without offset ...JR servo no found in Italy.
i think futaba 9650 is ok...what lo fit?
