Like Tree2Likes
Old 12-05-2013, 09:28 PM   #256
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
Originally Posted by JayBee View Post
Stop answering a question I didn't ask!
Okay NO
OVA is offline   Reply With Quote
Old 12-05-2013, 09:31 PM   #257
OVA
OVA's Avatar
Okay NO.
Old 12-06-2013, 03:36 AM   #258
Very nice! What class were you running?
blinky 17.5 on medium bite carpet.
vafactor is offline   Reply With Quote
Old 12-07-2013, 07:47 PM   #259
JayBee's Avatar
Trader Rating: 31 (100%+)
Refreshed....
VBC Lightning 12-lightning12.jpg   VBC Lightning 12-lightming12-2.jpg   VBC Lightning 12-lightning-12-3.jpg
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 12-07-2013, 09:39 PM   #260
OVA
OVA's Avatar
Refreshed....
Refreshed look good.
What jaco tires are you using ? Did you races today?
Old 12-07-2013, 10:08 PM   #261
JayBee's Avatar
Thanks.
Black/Yellow. No, couldn't get out of a commitment.
Old 12-08-2013, 01:54 PM   #262
Wanted to let everyone know that CRC and BSR tires will also fit, just have to trim a little off of the outer edge in rear so not to wide. I ran chrome fronts and Greylow rears at the U.S. Indoor champs in 17.5 blinky and won my main with the first time out witht he car
robert s is offline   Reply With Quote
Old 12-09-2013, 03:55 AM   #263
Default upper arm turnbuckle
One slap into the outer board = 1 bent aluminum upper arm turnbuckle. The tiny little turnbuckles are so short that it just didn't seem possible that they could or would bend. But I can now attest they can and they do. Thankfully the steel ones from AE work. Or, even better, the titanium Lunsford ones that were recommended earlier in the thread. Either way, I found out this weekend that indeed the little aluminum upper arm tunbuckles are seceptable to bending. The hit that bent mine (and the first time that my car has experienced any sort of impact at all) wasn't all that hard. Aside from that one little issue caused by pilot error that spoiled my main, the car was excellent again. Lessons learned......don't brush the inside of the sweeper and launch in to the outside board at full boogie........either that or fit stronger turnbuckles to the upper front arms.
Old 12-09-2013, 08:20 AM   #264
Trader Rating: 15 (100%+)
Club racing yesterday at 5280 Raceway with a number of us running this car. Still figuring out a good setup that suits my driving style, but some initial impressions include the following:
- The shock is very angled if using the box stock setup/shims, so I would recommend removing some of the shims on the upper pod plate if the car feels difficult to drive with too much steering.
- Even with the softest center spring the car has a lot of steering, which is good, but you really need to run heavy shock oil to keep the shock from feeling 'bouncy'. With the kit 350cst the piston will just blow through the oil, which makes the car feel a little weird. I ran 50wt AE and will likely go heavier.
- Put 1mm shims between the aluminum shock mount and the carbon piece the shock actually attaches to. This will help place the shock in a straight line along the chassis.
- Use 2.5mm shims on the crossbrace standoffs if you want to run the springs on top of the links.
I am going to try some more things next weekend and then try to get some setups posted.
Chris Hillier | 5280 Raceway | www.5280raceway.com | Racing. Elevated.
Destiny | LRP America | Protoform | Xenon/JFT | Gravity RC | Motiv | Sanwa | Max.FX
LloydLoar is offline   Reply With Quote
Old 12-09-2013, 10:07 AM   #265
Jaybee, Who makes the foam bumper are you using?
bama racer is offline   Reply With Quote
Old 12-09-2013, 02:08 PM   #266
JayBee's Avatar
bama, I wish I had a clue. I found it sitting in a BMI parts box that I have.
Old 12-09-2013, 02:39 PM   #267
ByteStream's Avatar
It's a CRC 1/12 bumper.
RCAmerica | Xray | Hudy | KO Propo | Hobbywing HWNA | R1Wurks | BSR Tires
5280 Raceway - www.5280raceway.com
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
ByteStream is offline   Reply With Quote
Old 12-09-2013, 05:49 PM   #268
LonnyJ1950's Avatar
This is it
http://www.teamcrc.com/crc/modules.p...prodID=7719045
Lonny
LonnyJ1950 is offline   Reply With Quote
Old 12-09-2013, 05:58 PM   #269
JayBee's Avatar
Yeah, that's it. Thanks guys
Old 12-09-2013, 07:48 PM   #270
dr_hfuhuhurr's Avatar
Trader Rating: 73 (100%+)
The Associated 12R5.2 bumper should work as well.
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
