Like Tree3Likes
Old 12-02-2013, 07:38 AM   #211
Jerry P's Avatar
Trader Rating: 44 (100%+)
What body are you guys running also?
Jerry P
Awesomatixusa - Side Piece Racing - LRP - Sweep Racing Tires - Mike L Designs - TQ Wires - Crispy Critters Raceway
www.awesomatixusa.com
Jerry P is offline   Reply With Quote
Old 12-02-2013, 08:52 AM   #212
Trader Rating: 15 (100%+)
Depends on the class you are running. I personally will pretty much always run an AMR, but a lot of guys will use the BA Audi r8 for stock. I think the AMR is pretty much the only choice for mod, though, unless you run on really low traction and want to use the TR.
Chris Hillier | 5280 Raceway | www.5280raceway.com | Racing. Elevated.
Destiny | LRP America | Protoform | Xenon/JFT | Gravity RC | Motiv | Sanwa | Max.FX
LloydLoar is offline   Reply With Quote
Old 12-02-2013, 08:56 AM   #213
JayBee's Avatar
Trader Rating: 31 (100%+)
Front End -
Caster: all shims rearward
Camber: 1° (to start)
Toe: 0°
Kingpin lube: 10 -15k (I'm using Shurlube Purple)
Droop: .50 - .75mm
Spring: AE .018 (vbc silver)
Width: 166/7-ish
Tyres: CRC/BSR Black (42mm/rounded) Jaco Black (41.5mm rounded)
Ride height: 4mm
Rear End -
Center Shock: vbc (dimple drilled out. 60-70wt/silver spring) or HB (35wt/AE blue spring)....don't be afraid to go even a bit higher in wt w/the vbc shock.
Shock mount: upper position
Pod Droop (no sag): 1mm over RH
Side Springs/preload: vbc silver or AE black (just touching, then go 1 full turn)
Tube lube: 15k (I'm using Shurlube Green)
Width: 172mm
Tyres: CRC/BSR Gray/Whites (43mm/rounded) Jaco Yellow (43mm/ rounded)
Ride Height: 4mm
Body: My preference is the CRC Black Art R8. A lot of folks like the Proto AMR12 though.
I think that's it. HTHs
And if your racing budget allows, you can go slightly smaller on the tyre size.
Also to get more life outta your front .018's, you can use .018's from AE's 10R5.1 (just use less shims up top)
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
Last edited by JayBee; 12-02-2013 at 04:55 PM. Reason: Front track width correction...
JayBee is offline   Reply With Quote
Old 12-02-2013, 09:12 AM   #214
flameoutgarrett's Avatar
Send a message via MSN to flameoutgarrett
I borrowed a stock ride from erlich on Saturday night and it was absolutely dialed..
Thanks dave! Pure domination lmao
If anyone is running stock you NEED Dave's setup!
Team fun-Www.rc-trim.com-Team Speedmerchant-Team Orca-Team Br00d
flameoutgarrett is offline   Reply With Quote
Old 12-02-2013, 09:21 AM   #215
Jerry P's Avatar
Thanks but I don't think Dave is sharing right now. Oh well... that is the setup I was after but at this point I'm going to try what was just posted.
Jerry P
Old 12-02-2013, 09:22 AM   #216
Jerry P's Avatar
Originally Posted by JayBee View Post
Front End -
Toe: 0°
Droop: .50 - .75mm
Width: 168-ish
Tyres: CRC Black (42mm/rounded) Jaco Black (41.5mm rounded)
Ride height: 4mm
Rear End -
Width: 172mm
Tyres: CRC Gray/Whites (43mm/rounded) Jaco Yellow (43mm/ rounded)
Ride Height: 4mm
Thank you to my fellow shock less tc brother.
Jerry P
Old 12-02-2013, 09:51 AM   #217
dr_hfuhuhurr's Avatar
Trader Rating: 75 (100%+)
How are you not oil less? I didn't even drill it out, just punctured the dimple and the oil is everywhere. Are you re-sealing the hole? how?
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 12-02-2013, 10:02 AM   #218
You have the o-ring guard placed correctly and the various o-rings are fully-seated, right?
Old 12-02-2013, 10:04 AM   #219
Yes, the o-ring in the top cap is in the hole, but that isn't going to seal that section of the shock will it?
Old 12-02-2013, 10:12 AM   #220
Thanks mark that's what I was looking for. You rock man. wish you were on the east coast my friend. I will eventually make it out to your track.. Now let's get Dave or someone to put up some setup sheets.. At this point in my area I know of 2 lightnings and I have 1 of them. We need some support out here. Blake has the other one and he is a 1/12 guy. I'm a shockless tc guy.
I just ordered some of these from lunsfordracing.com to put in my car.
camber turnbuckles
3 x 16mm Titanium Turnbuckles
Code: 1001
Price: $11.50
steering linkages
1 5/8" Punisher Plus Titanium Turnbuckles
Code: 1066
Price: $13.45
Colorado On-Road RC Club
www.5280raceway.com
www.facebook.com/CORtrack
Driving: Xray T4 2015, T.O.P. Rebel 12, Durango DEX8T, Durango DEX408 v2, Associated B5M, Associated B44.2
rc_speed is offline   Reply With Quote
Old 12-02-2013, 10:28 AM   #221
JayBee's Avatar
You shouldn't be oil-less.
I've built 2 of these shocks with the dimple drilled out. 1 with 3 hole piston and the other with the 2-hole. When you fill the shock, you may have oil sitting atop the last white plastic 'hat' piece. Remove all of it. That's what you see coming out of the thru hole. I've had no leakage after I've figured that out. Also I like the idea of soaking those orings as long as you can before assembling then coating the top one heavily with green slime ( as Korey Harbke suggested).
Old 12-02-2013, 12:13 PM   #222
Jerry P's Avatar
camber turnbuckles
Code: 1001
Price: $11.50
steering linkages
Code: 1066
Price: $13.45
Thanks for the help. Going to ask my lhs to pick those up for me.
Jerry P
Old 12-02-2013, 12:48 PM   #223
Shoot, well maybe it's not ready yet, but hen he does post it u guys are in for a treat lol
I think I was the first person to run it on a track other than timezone, so maybe he wanted to see how it worked
Old 12-02-2013, 01:52 PM   #224
Jerry P's Avatar
I sure hope so. I know how it is on the awesomatix side people want setups quickly. especially at first because not many were running the car. The lightning isnt being run locally either. I purchased one after picking up a Flash. If you can get Dave to post it up that would be great. In my part of town most people run 17.5. Lot's of fast dudes running Top Rebel 12's and i wanted to go against the grain.
Jerry P
Old 12-02-2013, 03:00 PM   #225
I run the top car, I wanted to see how the vbc drove, in stock it was just super easy to drive , very predictable.. Lots of corner speed, overall I was impressed. Tires let out in the main but still got the W
