Old 11-27-2013, 08:57 AM   #181
dr_hfuhuhurr's Avatar
Trader Rating: 73 (100%+)
Build is great. I had some fitting to do on the front arms to get them to move smoothly. They were a bit tight. A little sanding and then polishing and everything is moving nicely.
I LOVE:
1. The front kingpins! SO glad to be done with e-clips!
2. The shock (though it took a while to get it without a ton of rebound - I would like to hear from the team guys on their shock build process)
3. The diff is SUPER smooth (even better with the slapmaster thrust bearing).
Not so crazy about:
1. No rollover antenna (sorry to keep harping on this, I'm a purist)
Couple of observations/questions
- WOW that rear brace is thick? 5mm is it?
- What are the two empty countersunk holes for just ahead of the rear end?
- I trimmed the outside battery stops and will post pics as soon as the build is complete.
I've owned a LOT of 12th scales over the years. This is my favorite to build.
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 11-27-2013, 09:06 AM   #182
Trader Rating: 15 (100%+)
Glad to hear you enjoyed the build process!
Those two countersunk holes are used for battery stops if you run the battery transverse. Basically, use two short M3 screws with a normal 5.5 mm nut and they will help hold the battery in place and prevent it from sliding backwards.
EDIT: And for whatever little it is worth, I haven't figured out the ideal way to build the center shock yet, either. My first attempt was pretty good, but I would like to refine the technique a little before I post anything.
Chris Hillier | 5280 Raceway | www.5280raceway.com | Racing. Elevated.
Destiny | LRP America | Protoform | Xenon/JFT | Gravity RC | Motiv | Sanwa | Max.FX
LloydLoar is offline   Reply With Quote
Old 11-27-2013, 11:34 AM   #183
JayBee's Avatar
Trader Rating: 31 (100%+)
I have a couple of shocks to experiment with myself.
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 11-27-2013, 11:43 AM   #184
For building the shock...here's what I finally came up with.
- Soak the two internal o-rings in oil for a bit to allow them to swell properly
- Build the shock shaft/piston assembly and install it into the body.
- Add the bottom o-ring, plastic bushing then cap
- Thread on the ball end to the shock shaft
- Fill the shock body with oil removing all bubbles (haven't figured out how high to fill the body yet)
- Add the shock bushing piece to the shock body and push down with an allen driver gently
- Insert the o-ring into the plastic shock cap/seal
- push the shock shaft all the way in and install the plastic cap (oil went everywhere for me so I used too much oil)
- start screwing on the cap allowing oil to seep from the top
- At this point you'll have quite a bit of rebound so to get that out, unscrew the bottom seal and SLOWLY work the piston back into the shock body to bleed the shock
- tighten and repeat the above 2 steps till you get the rebound you're looking for (almost nothing for me, just smooth shock movement)
- add the spring and retainer and install on the car
Not the easiest shock I've ever worked with but at least I didn't strip the cap like I did on my Associated car (that was not a good shock cap)
Old 11-27-2013, 12:52 PM   #185
I'm having trouble imagining how a through-shaft damper with no rebound spring can have rebound. Is the air cavity that the top of the shaft goes into in the cap vented?
-Mike
Old 11-27-2013, 12:55 PM   #186
JayBee's Avatar
You have one of these now Mike?!
Old 11-27-2013, 01:09 PM   #187
Tron's Avatar
Trader Rating: 16 (100%+)
-Mike
Assemble the shock with the shock shaft compressed at the point at which you would like the rebound to be. In a perfect build the air above the piston will compress and expand back to that point at which the shock shaft was held during assembly.
I had no issues, but did use a Tamiya shock pump to vac all the air out of the shock.
Great rear shock, way nicer that the Tamiya RM01x shock. In comparison the RM is a huge disappointment overall.
Brett H - M03, TRF417, RM01x
"Slow Sportsman"
Tron is offline   Reply With Quote
Old 11-27-2013, 01:12 PM   #188
flameoutgarrett's Avatar
Send a message via MSN to flameoutgarrett
Woops
Team fun-Www.rc-trim.com-Team Speedmerchant-Team Orca-Team Br00d
flameoutgarrett is offline   Reply With Quote
Old 11-27-2013, 02:06 PM   #189
No, but I was intrigued by the conversation.
But there are two major purposes for a through-shaft damper:
- Better handling of side-loads by supporting the shaft at both ends.
- Removing the "rebound" effect that comes from the changing volume occupied by the shock shaft as it moves in and out. With the through-shaft damper, the volume taken by the shaft is constant.
My AME T-Shox don't have rebound without a rebound spring. So I'm curious where the rebound comes from. But I could very well be missing something, because I've only looked at the manual.
-Mike
Old 11-27-2013, 03:09 PM   #190
Sixgears's Avatar
Trader Rating: 32 (100%+)
The cap is sealed. Maybe a vent hole is in order?
Dustin Meyer
"Paragon, I choose YOU!"
Sixgears is offline   Reply With Quote
Old 11-27-2013, 03:14 PM   #191
Korey Harbke's Avatar
There is a small dimple on the side of the cap. I drilled mine out. Makes life really easy when building these . I also HEAVILY shock slime up my cap and orings in this shock. It seems to turn out really well then.
Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - Xenon - Xpert - Sanwa - Sweep - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 11-27-2013, 05:48 PM   #192
JayBee's Avatar
Shocks feels much better after those little tidbits. Thanks buddy
Old 11-27-2013, 06:12 PM   #193
Don't you have a job Jaybee? Lmao
You do more wrenching in a day than I do all year!
Old 11-27-2013, 06:18 PM   #194
JayBee's Avatar
Umm yes....yes I do
Old 11-27-2013, 06:54 PM   #195
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
Umm yes....yes I do
ygpm
OVA is offline   Reply With Quote
