Like Tree2Likes
Old 11-25-2013, 07:50 AM   #166
MAD916's Avatar
a few kits back in stock along with more parts... I'll get the rest of the parts up tonight.
More kits on the way.... the three online will go quick...
Timezone Raceway Park " on-road outdoor european style road course.
Timezone II 60'x100' indoor carpet track. Host of the ROAR 2011 Carpet Nat's.
Timezonehobbies.com your new source for online RC products.
MAD916 is offline   Reply With Quote
Old 11-26-2013, 02:16 PM   #167
dr_hfuhuhurr's Avatar
Trader Rating: 73 (100%+)
I know there are a few similarities between this car and the Associated.
Can anyone confirm:
1. Will bodies from the AE fit the VBC?
2. Will the AE Shock mount/carbon piece fit on the VBC?
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 11-26-2013, 02:24 PM   #168
Does anyone know how to get ahold of VBC racing? Have a part problem I'd like to email them about.
Will the 12r5.2 lower arms work on the lighting?
bama racer is offline   Reply With Quote
Old 11-26-2013, 02:25 PM   #169
I am 99% sure they are a direct replacement.
Old 11-26-2013, 02:38 PM   #170
Trader Rating: 15 (100%+)
The 12r5 arms (both the original v1 and the v2) will work on the lightning. The only other part you will need are a set of the lower pivot balls for the r5 front end, as the Lightning ones are the same size as CRC/older AE and thus won't fit without binding.
Sorry, I should clarify that the v1 r5 lower arms will only work if you have some of the aftermarket lower arm inserts, such as those manufactured by CEFX. If you don't have those inserts, I would recommend using the v2 r5 arm.
If you want to PM me with the issue I will forward it along to Dave, although I am 99.9% sure I already know what you are encountering
Chris Hillier | 5280 Raceway | www.5280raceway.com | Racing. Elevated.
Destiny | LRP America | Protoform | Xenon/JFT | Gravity RC | Motiv | Sanwa | Max.FX
LloydLoar is offline   Reply With Quote
Old 11-26-2013, 03:20 PM   #171
JayBee's Avatar
Trader Rating: 31 (100%+)
Nice build
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 11-26-2013, 03:28 PM   #172
Sixgears's Avatar
Trader Rating: 32 (100%+)
JR Servo?
Dustin Meyer
"Paragon, I choose YOU!"
Sixgears is offline   Reply With Quote
Old 11-26-2013, 03:55 PM   #173
Airtronics
Old 11-26-2013, 04:16 PM   #174
Tron's Avatar
Trader Rating: 16 (100%+)
Originally Posted by JayBee View Post
Nice build
Looks like your servo is a tad off center....I used a Spektrum H5020G from a heli I had laying around and was 1mm off of center in my v1.0 build.
What is the effect of having the servo off center a tad? Steering different left to right?
Brett H - M03, TRF417, RM01x
"Slow Sportsman"
Tron is offline   Reply With Quote
Old 11-26-2013, 04:26 PM   #175
JayBee's Avatar
Yeah it was off a tad; just had to loosen up the servo mounting screws and push the servo over. Issue resolved...thanks
Old 11-26-2013, 06:58 PM   #176
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Originally Posted by corallyman View Post
Hey AWD,
I had a good look at a friends car yesterday. If you are looking at keeping the lightening's shock which seems really nice, Serpents s120's center shock springs look like they would fit if you were looking for more choices. I think there are 5 springs.
Steve
Thanks guys. I appreciate the help.
AWD
Old 11-27-2013, 08:27 AM   #177
pbr
What an easy build fit & finish is as great
pbr is offline   Reply With Quote
Old 11-27-2013, 08:31 AM   #178
Sixgears's Avatar
Has anyone installed a JR 3650 with the Ackerman spacers? The LF arm mount interferes. Removed a good 1/8" with a pencil grinder
Dustin Meyer
Old 11-27-2013, 08:38 AM   #179
JayBee's Avatar
Sup pbr...howya been bruh?
Old 11-27-2013, 08:44 AM   #180
I originally had a JR 3650 installed in my car, but removed it and replaced with a KO. If the servo hits the arm mount you can always just remove some of the ackermann shims at the servo mounts and then try to shim at the servo saver.
